[ Active Members: 6 | Guests: 306 ]  [ Total: 312 ]  [ Newest Member: GrecRI2 ]
 Plastic Rivet Removal
damaib Posted - Aug 18 2017 : 11:52:00
I need to remove the plastic rivets that fasten the white cockpit panels to the stainless rails on my '97 325 Aft Cabin. Is there a secret tip that makes these things easy to remove?
6   L A T E S T    R E P L I E S    (Newest First)
damaib Posted - Aug 20 2017 : 11:03:57
How do you replace them?
As for drilling them out the should be easy this is how i would remove all rivits mental as well.
The new/unused rivets push in to the holes and they have a long mandrel (?) protruding from the head. You gently tap it in with a mallet or some kind of hammer until it is flush with the head. I works kind of like a wall anchor with the sides of the rivet spreading out inside the rail as the mandrel is pushed in.
Audrey II Posted - Aug 20 2017 : 06:16:58
damaib Posted - Aug 18 2017 : 22:26:54
Originally posted by DeeVee
Just use small flat punch and punch it thru.
I talked to Carver tech support this afternoon and they said to just drill them out, even though they are plastic (or nylon).
DeeVee Posted - Aug 18 2017 : 19:14:23
pdecat Posted - Aug 18 2017 : 17:00:07
what Dave said
Audrey II Posted - Aug 18 2017 : 13:13:30
Plastic rivets? Can you post pictures? Are you sure they aren't screw cover caps that just pop off to reveal the screw head?
