[ Active Members: 4 | Guests: 201 ]  [ Total: 205 ]  [ Newest Member: wfandel ]
 a random shore power question
williamabernathy Posted - Feb 08 2018 : 20:11:02
Hi, All,
Can anyone tell me if shore power receptacles (boat or dock side) are supposed to be oriented a certain way, such as ground at 12 o'clock or ground at 6 o'clock, anything like that? I am guessing there is an industry standard, but I can't recall how mine are oriented.
Many thanks for your help.
V/R
7   L A T E S T    R E P L I E S    (Newest First)
williamabernathy Posted - Feb 11 2018 : 18:05:25
I just checked out web sites for Marinco and that online cartage company in Connecticut, and this is what I found (all 30 amp, L5-30):
(1) Furrion, boat side assembly w/cover (male prongs) -- ground at 4 o'clock
(2) Marinco, boat side assembly w/cover (male prongs) -- ground at 7 o'clock
(3) Marinco, dock side assembly w/cover (female receptacle) -- ground at 7 o'clock
(4) Marinco, dock side, bare receptacle only w/o assembly (female receptacle) -- ground at 12 o'clock (printed text on the receptacle would orient it to 12 o'clock, but I suppose it could go at 6 o'clock, too)
(5) WM video that showed twin 30 amp dockside receptacles' grounds at 3 o'clock (just like the pictures in this thread)
(6) A YouTube video that showed twin 30s on the dock with both grounds at 12 o'clock
Dang. Now I'm really puzzled. (And I guess I could have done this search before posting my original question. Pardon me for not having done so.)
I do appreciate everyone's input.
MichaelNJ Posted - Feb 11 2018 : 17:43:24
Commercial 20A receptacles are usually ground up for the reason that Mike mentioned. Not only would something hit the hot, it could also bridge hot and neutral causing a short.
JoLin Posted - Feb 10 2018 : 22:22:30
Originally posted by pdecat
You do raise a good question. I have never seen any definition of how the sockets should be oriented but have always followed the example of the drawings. I do note that the 15/20A three prong plug common in homes is opposite the three prong shown on the drawing above.
3 years ago I installed a complete 30-amp circuit in my boat to power the A/C that I also installed. I used that (or a similar) pictorial to orient the wires. I've had no issues with power or reverse polarity at any of the 7 or 8 different marinas I've hooked up to since, using both 30-amp outlets and a 50-amp outlet with a splitter. I'll also note tht the old exising 30-amp circuit on the boat was wired up the same way.
Net-net, I believe that there IS a standard, and it's shown in that pic.
mdoherty Posted - Feb 10 2018 : 13:33:43
The home electrical code recently changed from ground down to ground up, reasoning if something fell onto a loose plug it should hit ground before live.
pdecat Posted - Feb 10 2018 : 13:03:09
williamabernathy Posted - Feb 09 2018 : 22:43:46
Michael,
Yep, I've seen that diagram, which is similar to Figure 12 in ABYC E-11. I'm still puzzling whether these show the industry standard for receptacles (for 30a / L5-30) or if that's just how they happened to be shown in those diagrams for no particular reason.
I do appreciate your feedback. Thanks.
MichaelNJ Posted - Feb 09 2018 : 09:45:20
Here's a guideline
https://www.21cii.com/ITStudio/Content/Appendix/Plug%20&%20Power%20Guide.htm
