[ Active Members: 3 | Guests: 205 ]  [ Total: 208 ]  [ Newest Member: Rleemorris ]
 Regal Owners
 Thru hull transducer Regal 2960
Blum587 Posted - May 20 2019 : 17:45:50
Hello all,
I am replacing my thru hull which is located just forward of my starboard engine. Does anyone know what angle I need? That is my main question.
I have an 1.5 inch hole and will hook it up via Nema200 network. Any recommendations? Thanks in advance!
Bart
7   L A T E S T    R E P L I E S    (Newest First)
shall0521 Posted - Jul 23 2019 : 10:17:50
I had mine replaced by the boatyard. I believe it was 19 degrees.
Blum587 Posted - Jun 16 2019 : 16:36:06
Thanks for the replies. I ended up findin it to be a cored hull, opening it up to a 2 inch hole (bigger on the inside layers), and made an epoxy cavity to seal it between the layers. Then installed a garmin intelliducer, and putting it on my NEMA2000 network. Works great
Kellyg Posted - May 22 2019 : 00:53:31
Regal hull is solid fiberglass
sugilbert Posted - May 21 2019 : 19:43:23
If you've got the time, out of the water, just measure the old one with a cheap protractor.
Bob J Posted - May 21 2019 : 18:47:43
Originally posted by Blum587
Also, would mine have a cored hull, or solid?
That w/b a great question to boat mfg!
BOB J
Bob J Posted - May 21 2019 : 18:47:40
BOB J
Blum587 Posted - May 21 2019 : 17:46:48
