| T O P I C R E V I E W |
| Ocean Spray |
Posted - Jan 26 2008 : 19:30:00 So far so good, MM has been repairing the engine oil leak as planned. just as I suspected, it was the rear main oil seal that was leaking. Good news is they do not have to pull out the engine to get to the seal, they just pulled the tranny back to exspose the seal. Should be all buttoned up next week.
Hopefully everything will go back together good as new. |
| 12 L A T E S T R E P L I E S (Newest First) |
| KiDa |
Posted - Feb 13 2008 : 21:19:55 Glad to hear it. I wonder...was it the negative posts or the quelling of the negative posts that got Meridian off their collective dead arses.
Rhetorical...no answer necessary.
If this pisses anybody off.....I am having a bad day1 |
| Ocean Spray |
Posted - Feb 13 2008 : 20:59:18 Funny you said thatya go! |
| Captain Buddha |
Posted - Feb 13 2008 : 12:47:45 Good to hear! Make sure to send a note/email to the MM guys letting them know you posted about a POSITIVE experience! (you know, keep it fair/balanced) Of course, they may already know that you did, as they are probably reading this... |
| MichaelNJ |
Posted - Feb 13 2008 : 10:12:44 Glad to hear it. Good luck going forward. When you get a chance, please let me know how you made out with the SmartCraft info on your 6000i. Can you see water and waste tank levels? |
| walterv |
Posted - Feb 12 2008 : 21:07:45 Great, happy to hear this :):):):):) |
| PascalG |
Posted - Feb 12 2008 : 19:50:44 good news... hope your problems are over ! |
| Ocean Spray |
Posted - Feb 12 2008 : 19:23:07 Happy to report we got the boat back and all is well! Engines ran good, no leaks, and they even cleaned out the bilge and put new diapers in. Lets see how long we can run the boat before something else breaks! |
| walterv |
Posted - Jan 27 2008 : 12:08:26 Sure glad they did not have to pull the engines.
Good Luck
Walter |
| MichaelNJ |
Posted - Jan 27 2008 : 07:35:11 Glad to hear it OS! Make sure they clean the bottom of the bilge there before they move the transmission back. |
| giolic |
Posted - Jan 26 2008 : 20:58:27 Glad to hear things are going better |
| Ocean Spray |
Posted - Jan 26 2008 : 20:10:19 LOL! No problem, I know how you feel, I rant on here more than most, it does feel good to let it go once in a while doesn't it?! |
| muddkatt |
Posted - Jan 26 2008 : 19:45:48 That engine is ruined. Being that I am fairly close to you, I will do you a favor and haul it off for you. :-)))
I hope they get it repaired the first time. My Volvo had a leak, it was the front timing chain cover. It was made of plastic and cracked at the pan gasket. I have the engine in about 1000 pieces in the garage right now. I missed Gasparila, can not find a machine shop that can acid wash the block and heads.....generally upset at the whole thing. Sorry for the rant, but it made me feel better. |
