[ Active Members: 3 | Guests: 88 ]  [ Total: 91 ]  [ Newest Member: Rleemorris ]
 Regal Owners
 IPS Drives
Freedom 45 Posted - Mar 11 2008 : 22:46:04
We've been contemplating purchasing a used 2007 Regal 4460 with IPS drives. With 2007 being the first production year for IPS drives, I'm wondering how sound the new drive technology is. Has anyone had any negative experiences with IPS drives that they'd be willing to share? Is it advisable to stay away from IPS drives for a couple of years, to let any mechanical or electronic "gremlins" get sorted out?
22   L A T E S T    R E P L I E S    (Newest First)
CurrentSea Posted - Dec 11 2012 : 12:20:27
Thanks Joe.
I am another one in my sights with diesel and IPS.
Will know by this Friday if it is a go/no-go!!! :)
van lafermine Posted - Dec 11 2012 : 12:18:15
Dave,
After reading the post I wrote almost 5 yrs ago I have 560 hrs and I am as happy now as I was the day I ordered the boat!
enough said!
DogDaze Posted - Dec 11 2012 : 11:14:25
Hey CurrentSea,
Saw on the ROF that you lost your beautiful Regal in Sandy.. So sorry.. our friends have a brand new 2012 Cruisers 430 w/IPS and LOVE it so far!! Be sure to stop by and see us on the new COF.. you can find the link to the 'Official' BLOG and Forum on the Cruisers Yachts website.. :) btw, I do happen to know where there IS another just like your Regal.. only in Black.. one owner with maybe ~120 hours.. spotless!! Belonged to good friends.. and also ROF member K Squared.. (you know them too) The boat is at South Shore Marine in Huron, Ohio.. so, a freshwater boat... (they traded on a CY's)
j-d Posted - Dec 03 2012 : 12:30:45
I have a half-update from a year ago. Thanksgiving weekend 2011 a nearly-new Tiara hit one of the lighted buoys in the St. Johns River shipping channel. Damaged the IPS but didn't knock it off. They went the last 20NM home on one engine and I was amazed how fast they moved on one. I don't know what the IPS series was.
I can add that in the ongoing series between Fiberglass and Steel, Steel remains undefeated.
CurrentSea Posted - Dec 03 2012 : 10:59:24
This post is 4 years old, curious to hear from some of these IPS owners 4 years later. Drives still has good as you say? Any issues?
Thanks.
Freedom 45 Posted - Mar 30 2008 : 11:25:41
Thank you everyone for you feedback. I've now tested a couple of 4460's with IPS drives. In one case it was in very choppy and windy conditions. As everyone has indicated, the handling is second to none. Docking in the choppy conditions was also not a problem. I wouldn’t consider buying a 4460 that doesn’t have the IPS drives. It's also comforting to hear that nobody has experienced any mechanical or electronic failures with their IPS drives.
commonmedic Posted - Mar 15 2008 : 12:59:49
I will give my dealer a jingle and make sure of the changes.Thanks for the info.
DDL Posted - Mar 15 2008 : 09:19:28
Originally posted by commonmedic
What changes did you make for the anodes,I am in fresh water on the upper Mississippi.Most boats come with ZINC and we change over to Magnesium.But the dealer said I do not need to do this with IPS.What would your input be.
Thanks Dave
Your new 4060 should come with aluminum anodes on the transom. Additionally, Volvo doubled up on the cast iron anodes in the drive. As I recall the bulletin on the increased anode protection came out in the spring of 2006 so I can only assume that boats built after that date have the updated protection.
commonmedic Posted - Mar 14 2008 : 11:46:05
Thanks Dave
DDL Posted - Mar 14 2008 : 09:46:37
I've have over two years experience (300 hours) on my IPS boat and have absolutely 0 problems with the drives. The joystick has a learning curve but I found if you apply power in short bursts it works just fine. Corrosion was an early problem for some units but the addition of increased annode protection has taken care of that issue. Quite honestly, I've had more problems with the D6's than with the drive. I've had to replace an alternator, a transmission cooler,a couple of engine gaskets and most recently all the injectors on the STBD engine to cure an annoying vibration. All the engine related problems were handled promtly by Volvo under warranty, although it took six months to chase down the vibration problem as everyone (Volvo and Tiara) kept insisting it was a prop or shaft problem. I kept telling them I hadn't hit anything but eventually pulled and re-conditioned the props and had the shafts checked with a dial indicator before the techs began looking elsewhere for the vibration problem.
I wouldn't hesitate to recommend IPS drives based upon my experience.
RamSport47 Posted - Mar 13 2008 : 18:18:42
You are correct Van. The 1" increase I was quoting was for a "pocket free" boat. We sell Carver where I work, and their 43 SS drafts 1" more than the same boat with inboards (Carver does not use pockets)
van lafermine Posted - Mar 13 2008 : 15:05:17
I have just ordered a Regal 4460 with the IPS. I compared the draft with straight drives and it goes from 35" to about 42" The straight drive had pockets and the IPS does not. Still 42" is not bad. My old Silverton was 46" and that was straight drives.
As far as Zeus vs. IPS The Zeus just looks more conventional. The IPS is a little awkward looking but performs better on consumption and is quicker on plane because the props are forward. Very little lift out of the hole. Anyway, thats what I keep telling myself!
Jsheaffer Posted - Mar 12 2008 : 15:12:16
I took delivery of my 5260 in mid January, I really am impressed with the IPS system. First there is a lot more room in the Engine room, they are very quiet, fast out of the hole and the boat is really manuverable. Best of all the fuel economy is much better than my 4460 with Yanmars. The Joy Stick is great for final docking but it is not as easy as everyone makes it seem. You still have to know how to handle a boat including compensating for wind and current I use shifters in and out the marina and the Joystick just to dock. All in All I am really pleased with how the system works.
John S
KiDa Posted - Mar 12 2008 : 13:52:26
IPS went through 15 years of testing before is went to market. The sheer off thing was the result of a really nasty accident in NC.
RamSport47 Posted - Mar 12 2008 : 13:23:27
Why not wait and compare the Volvo Joystick stern drives to the Axius? It's due fairly shortly
mayerf Posted - Mar 12 2008 : 12:06:35
Anyone compared IPS with Axius stern drives?
commonmedic Posted - Mar 12 2008 : 11:08:34
With the forward facing props the water is cleaner and more efficient and better lift.Also IPS has the patent so Zeus had do so it differently.With props so far back, Zeus had to incorporate the trim tabs to help lift the boat out of water,the trim tabs move automatically to compensate. With the prop coves for Zeus it added more wet surface area for more resistance.I found most of this info on boattest.Just my 2 cents take it for what its worth.
BJL Posted - Mar 12 2008 : 10:41:26
Now if only I could afford the boats that have it!!!
RamSport47 Posted - Mar 12 2008 : 10:30:44
The IPS drives draft about 1" more than standard inboards. The forward facig props add more benefit than risk IMO. We've sold several here on Lake Erie and have had only one mishap, and that was with myself running the boat. New props, and we were done, and we hit HARD...the drives stayed on so they're not as tender as everyone seems to think.
mayerf Posted - Mar 12 2008 : 10:09:11
I have no personal experience but have been reading a lot about joy stick drives. Does the forward propeller concern anyone? Seems like the props would get the worst of hitting anything. IT also seems that the IPS pods hang lower than normal requiring more draft. Anyone compare either IPS or Zeus with Merc's stern drive Axius system? Frank
commonmedic Posted - Mar 12 2008 : 04:32:05
If you want to see the best video that demonstrates the IPS advantage,google FOURWINNS IPS.Then click on the Fourwinns site with IPS video.What the video demonstrates is what I experienced.Also I stumbled across several videos where engineers talk about IPS on Boattest.com.Very interesting.If you want to chat let me know.
To Bad Regal has not done a demo video this good.
commonmedic Posted - Mar 11 2008 : 23:18:48
I just purchased a new 4060 with diesel IPS.I read article after article and could not find any significant failures.I refused to purchase until I did a sea trial at a boat dealer show this past winter.I Sea trialed a 4060 and drove across the coast to Sea Ray and trialed a 44 Sundancer with the Zeus system.After playing with both boats their was not one bit of hesitation about buying the IPS.It performed great,very quiet and no vibration.Now Zeus was very dissapointing so I will not badger their product.
My wife who never would consider taking the boat out,is looking forward to going out with her girlfriends.I dont fear the boat,just that she gets confused with starboard and port.
The systems have been around a long time on commercial ships, and has a few years under its belt in Europe and Australia.I could be wrong but I feel very comfortable with my decision.
