[ Active Members: 7 | Guests: 195 ]  [ Total: 202 ]  [ Newest Member: Steve717 ]
 Cruisers Yachts Owners
 transom shower problem
blue horizon Posted - Mar 27 2008 : 19:59:29
Spring is here and time to fix a problem! I have a 2005 280cxi. The hose to the transom shower has broken off at the fitting. This is in the engine room below the shower box in the cockpit. It looks to be a nylon elbow shaped fitting with a female 3/8 in connection and a spring loaded valve. The other end appears to be a larger female connection that actually split and broke off. Where to do we go from here. Is this fixable or are we looking at a whole news shower system?
blue horizon Posted - Sep 13 2008 : 19:38:59
Originally posted by LexScript
I have the exact same problem. Were you able to find the fitting? Where? What is it called?
Many thanks,
Lex
Hi Lex. I ended up having to replace the entire shower. I ordered the new one from Cruisers. Apparently they don't make a replacement fitting. Good Luck
LexScript Posted - Aug 12 2008 : 11:44:37
Many thanks,
Lex
abalmuth Posted - Mar 28 2008 : 01:42:30
Chek here
http://www.boatfix.com/catalog/552.pdf or here http://www.boatfix.com/catalog/553.pdf
if the part it not listed call the Cruisers owners desk at: 866 734 2770?
Ask for parts and ask them for the oem vendor and or the part
