[ Active Members: 6 | Guests: 220 ]  [ Total: 226 ]  [ Newest Member: Jim_In_Calif ]
 Cruisers Yachts Owners
 bilge pump failing
blue horizon Posted - Apr 14 2010 : 16:25:57
Forward bilge pump in 280 cxi not pumping. Just getting a hum. Bought a new one same problem. Any ideas on where to look for the problem? It's a Johnson 2200 gph.
blue horizon Posted - Apr 16 2010 : 19:05:28
Thansk guys. Delayed the launch I'll get in there over the weekend.
abalmuth Posted - Apr 15 2010 : 02:57:02
5 years of being exposed to salt water can do a lot to wiring, connectors and the float switch
Try hooking the Pump(s) directly to a battery and see if it/they run.
blue horizon Posted - Apr 14 2010 : 23:52:31
I wondered about the wiring, but the boat is a 2005 so it shouldn't be bad. I will def. check the hose next. Any other thoughts?
Robyns Nest Posted - Apr 14 2010 : 18:05:26
Is the hose clear and not obstructed?
Wiring good?
