[ Active Members: 3 | Guests: 266 ]  [ Total: 269 ]  [ Newest Member: Rleemorris ]
 Before I call - Westerbeke Genny Troubleshoot?
Author Previous Topic: Electricians?  Stray current- Conclusion Topic Next Topic: Vacuflush switch failure
footloose
RO# 6963
Posted - May 30 2007 :  09:32:08  Show Profile  Reply with Quote
My gas 6.5 KW genny ran pretty well this weekend but got flakey from time to time. Sometimes it ran 2 hours with heavy load of A/C hot water heater, battery charger and such going...other times it ran for an hour and stopped on it's own.
I suspected fuel filter so I changed it out....no real difference and a tiny bit of water in the fuel. Temps are normal so it is not an overheat cut out. Oil normal so not an low oil or oil PSI problem. Water coughing all the time so not cooling.
After one stall out, I disconnected the fuel line at the carb and it was almost dry. Can the electric fuel pumps be intermittent/flakey?
Other than check for a air leak in the fuel system, what can I test/try to figure this one out?
Might get the carb rebuilt.....but I'm grasping a straws. Ideas?
Frosty Point Ice Cream Parlor in LHP is running as so is the Harley.
Homeport: Florida
Posted - May 30 2007 :  11:35:48  Show Profile  Reply with Quote
if you find the carb is out of fuel, then the fuel supply seems to be the problem...
could be the fuel pump or it could be a problem in the wiring to the pump. bad wire, contact, etc... i don't think an air leak would allow it to run fine for a long time, it woudl shut down sooner...
try comparing how much fuel you have in the line when you shut it down manually...
coudl also be a faulty oil press/temp sensor..
i hate intermittent problems, they're a PIB !
psugar
RO# 8116
Posted - May 30 2007 :  11:40:50  Show Profile  Reply with Quote
When is the last time you changed the plugs? My Westerbeke was very sensitive to fouling plugs. One thing it really didn't like was sitting running without a load....it would foul plugs. Other than that it ran perfect, but if it got flaky I would change the plugs and no issue.
If you haven't changed in a while, they are cheap, quick to change, and you should change them anyway.
Homeport: Chesapeake City, MD Go to Top of Page
SLW
RO# 2186
Posted - May 30 2007 :  14:36:51  Show Profile  Reply with Quote
I'm quick to call "fouled plugs", but fouled plugs have very distinct symptoms: cloudy exhaust and/or a sheen on the water from the unburned fuel, surging, reduced RPM's, an inability to carry heavy loads and an uneven exhaust note.
I'm betting on a fuel issue too.
Homeport: Cedar Pt, Oh / Mi / Miami Go to Top of Page
seahawk215
RO# 15005
Posted - May 30 2007 :  21:46:37  Show Profile  Reply with Quote
I had an Onan MCCK that would run an hour or so and shut down. After setting for about 20 minutes would run again. Drove me nuts,knew it was a fuel issue, would dribble afew drops into carb and would fire right up. It was the electric fuel pump. Would work for a while and would quit. Changed fuel pump and she was fine after that.
Randy Arline
1986 Chris Craft 360 Commander
Miss KimberLeighann
1971 Boston Whaler 13'
Homeport: Dania Beach, FL Go to Top of Page
bajasport
RO# 25728
Posted - Jun 14 2007 :  12:47:28  Show Profile  Reply with Quote
I am experiencing the same problem where the generator would run but would not run the air conditioner. The marina look at it and told me the capacitors were weak but not bad enough to replace. He suggested once the generator is running turn on the hot water to "energize" the capicators then the air conditioner. Worked great last weekend.
footloose
RO# 6963
Posted - Jun 14 2007 :  15:23:17  Show Profile  Reply with Quote
I'll try both - fuel pump is the original I think so .... could be flaking out. Also plugs couldnt hurt. BTW- load or no load - still dies after a varying amount of time. Wierd.
Homeport: Florida Go to Top of Page
footloose
RO# 6963
Posted - Jul 02 2014 :  14:57:34  Show Profile  Reply with Quote
Looks who's back ... I know it's been a while
Time for some Genny work:
1) Looking to replace the fuel pump on my late 80's Westerbeke 6.5KW gas genny. I have the manual and can identify the Westerbeke part but chaaaaching badabing shwing ... there has to be a marine grade replacement for that thing out there somewhere.
2) Also looking to see if there is a kit out there to convert the points based distributor with electrical from say maybe the 1990's?
any experts out there who can lend some helping advice?
Be well all and Happy 4th!
Posted - Jul 02 2014 :  20:44:54  Show Profile  Reply with Quote
Hey foot....good to hear from you. What's the latest?
footloose
RO# 6963
Posted - Jul 02 2014 :  21:18:08  Show Profile  Reply with Quote
Thanks cwms - been crazy for the foots this past year, started a new business,a new job, new grand babies, and kids moving into new homes has consumed every moment so boating has been taking a back seat .... bu thope to change that soon.
OLD HOUSEBOATER
RO# 9099
Posted - Jul 03 2014 :  10:07:14  Show Profile  Reply with Quote
Westerbeke fuel pumps are known for your problem.Change it out.
OLD HOUSEBOATER
The French fries are cold so we gave you extra.
Homeport: GULF SHORES AL. Go to Top of Page
footloose
RO# 6963
Posted - Jul 03 2014 :  13:03:13  Show Profile  Reply with Quote
thanks OH - any alternatives to the OEM units....VERY pricey and for all I know they just need 4-6 PSI like a generic boat pump?
OLD HOUSEBOATER
RO# 9099
Posted - Jul 04 2014 :  08:20:59  Show Profile  Reply with Quote
Check out Advance Auto
OLD HOUSEBOATER
Posted - Jul 04 2014 :  08:46:13  Show Profile  Reply with Quote
Any substitute pump needs to be ignition protected. One would think any gasoline pump would be rated as such, just make sure.
Bill Lentz
sabrejocky
RO# 12195
Posted - Jul 04 2014 :  09:03:49  Show Profile  Reply with Quote
Summit-racing part # PFS-10701
"Pretty Penny"
1990 50' High Tech Euro
Wellington, Florida
You ain't much if you ain't Dutch
Homeport: Miami, Florida Go to Top of Page
footloose
RO# 6963
Posted - Jul 11 2014 :  10:34:32  Show Profile  Reply with Quote
you guys/gals ROCK! Thanks
footloose
RO# 6963
Posted - Jul 11 2014 :  10:37:30  Show Profile  Reply with Quote
In looking at summit part - should I use the 4psi unit or the 2?
OLD HOUSEBOATER
RO# 9099
Posted - Jul 11 2014 :  16:32:32  Show Profile  Reply with Quote
Suggest 4
OLD HOUSEBOATER
footloose
RO# 6963
Posted - Jul 13 2014 :  12:36:58  Show Profile  Reply with Quote
Worth a shot - thanks
Stay Frosty My Friends
footloose
RO# 6963
Posted - Jul 13 2014 :  13:06:26  Show Profile  Reply with Quote
Doug Doty
RO# 33654
Posted - Jul 16 2014 :  06:59:21  Show Profile  Reply with Quote
I just came across an original 1984 anti siphon valve coming out of my tank doing something similar. These little pumps on the Generators are very poor suckers compared to the diaphragm style pumps the primary engines use so the anti siphon valve being clean and limber is a big deal. They also won't pump air so pull the fuel line off the carb and cap it with your finger to get it to prime as well, not sure why this works but it does. (Thanks to a buddy for all of this info and he was right on)
1984 Marinette Sedan
440's and Beke 9.0 kw
Edited by - Doug Doty on Jul 16 2014 07:00:07
Homeport: Indiana Go to Top of Page
footloose
RO# 6963
Posted - Jul 16 2014 :  12:41:16  Show Profile  Reply with Quote
Thanks! thinking of replacing it and moving the pump elsewhere. Where it is now is about the same level as the top of my fuel tanks and about 4 linear feet away from the fuel manifold that direct fuel to 4 tanks and 2 primaries and the genny....not ideal
This page took 0.58 seconds to load
