[ Active Members: 3 | Guests: 185 ]  [ Total: 188 ]  [ Newest Member: Rleemorris ]
 Formula Owners
 VP XDP water pickup
Author Previous Topic: Volvo IO? Topic Next Topic: Vintage Formula Website
eyehooker
RO# 12027
Posted - Sep 26 2009 :  20:37:35  Show Profile  Reply with Quote
Finally found someone to say is was ok to remove water pickup from the out drive on VP XDR however he stated they do with Bravo all the time-- several ways -- usual method is installed scoop pickup with a strainer 1/4 ball valve and they block the hole in the transom sheild and reroute the water for a drive shower (optional)-- going to try just to get the water pickup out of the transom sheild area-- already remove the exhaust bellows hopefully this will correct the pinching of the bellows and leaking-- on 3 set of bellows and gimbal bearing and seal!!!!
Homeport: walnut creek pa
Posted - Sep 27 2009 :  06:10:53  Show Profile  Reply with Quote
You might get a better response over on the engines forum.
