[ Active Members: 7 | Guests: 119 ]  [ Total: 126 ]  [ Newest Member: gtex50 ]
 how to measure shaft packing size
Author Previous Topic: RG6 Switch  box?  Multiple satellite antennas Topic Next Topic: A Tight Squeeze
Posted - Oct 28 2009 :  15:08:51  Show Profile  Reply with Quote
Okay, here is a really basic one. I want to install gore packing on my shafts. I've replaced packing countless times. Usually, I take the old packing to the store, physically match it to the nearest size and buy a bunch of that. I don't pay attention to measurements or what it says on the package.
Once upon a time, I actually took out a ruler to confirm the measurements when in a store. I don't recall the story, but it went something along the lines that the physical measurement of the packing can be different than the stated size. The net of the conversation was to be careful about stated packing sizes. I got what I needed and left and since forgot any further details.
So today....I have some old packing. I measure it. It averages more than 1/4 and a little less than 3/8. Lets call the physical measurement 5/16, but of course one side is a little larger than the other because its old used packing. Do I have 5/16 then? Or does the old story I recall have some bearing?
I have not had time to take it down to the store, match it up and then leave without buying anything...
I'm also aware and have recommended countless times that depending upon your gland, you can actually buy packing a little large and flatten it a little. But....I generally only do that when I have a reason and with flax packing, its so cheap you can buy a couple different sizes and use what you need. With the gore...I want to buy it once and be done!
So...any of this make sense to anyone? Are there actually any peculiarities in how packing is sized and measured?
I have 2" shafts and don't recall the maker of the gland.
Homeport: Everett Wa
Posted - Oct 28 2009 :  15:37:11  Show Profile  Reply with Quote
Use a drill bit to measure the space.
dkjbama
RO# 25654
Posted - Oct 28 2009 :  16:55:51  Show Profile  Reply with Quote
(Inside diameter of shaft log - shaft size)/2; or use Bill's idea and measure with a drill bit.
DKJ in Alabama
2002 Lowe 19' Deep-Vee FM195WT
"People do weird things to boats" - Unknown
Homeport: Wilson Lake, Tenn. R.at Florence, AL Go to Top of Page
L. Keith
RO# 1615
Posted - Oct 28 2009 :  17:01:04  Show Profile  Reply with Quote
What Capt. Bill said, I for one think that's worth a twenty. Get the store that sells the Gore packing to send/lend you a small sample to check the fit. I have a 2" shaft and just converted to Gore packing and used 5/16".
rbmitchell
RO# 3641
Posted - Oct 28 2009 :  17:18:38  Show Profile  Reply with Quote
You adjust the size, somewhat, anyway. If the packing is too big, you squash it a bit so that it will fit into the housing. If the packing is too small, then tightening the housing screws wads the packing up so that it stops the leak. You just don't want to do the adjusting any more than necessary.
Posted - Oct 28 2009 :  17:38:24  Show Profile  Reply with Quote
Ditto the drill bit. It so simple that nobody thinks of it!
Bob J
RO# 181
Posted - Oct 28 2009 :  18:01:05  Show Profile  Reply with Quote
Re: drill bit measurement: be sure shaft is centered or readings w/b different around diameter of shaft. Even if off somewhat; shouldn't be off enuff to take you to next diameter of packing.
Bob J
navman
RO# 16259
Posted - Oct 28 2009 :  20:08:44  Show Profile  Reply with Quote
Brett , bet ya a beer your 5/16 with a 2 inch shaft.
Homeport: Tacoma Go to Top of Page
Posted - Oct 29 2009 :  00:04:15  Show Profile  Reply with Quote
You guys are right. I should just measure the gland and forget measuring the packing.
hooks
RO# 13083
Posted - Oct 31 2009 :  09:11:44  Show Profile  Reply with Quote
Use at least 2 drill bits(the same size) to be sure you maintain concentricity with the shaft... 180 degrees apart.
Regards, Jim
Edited by - hooks on Oct 31 2009 09:12:19
Homeport: Deforest,Wisconsin..La Crosse, Wisconsin Go to Top of Page
jmas
RO# 4313
Posted - Nov 02 2009 :  20:11:06  Show Profile  Reply with Quote
Once you determine the correct size, write it down in your maintenance log, or somewhere.
wish I had done that.
Joe M.
Luhrs 340 Express Fish
Homeport: Pompano Fla. Go to Top of Page
Posted - Nov 03 2009 :  10:44:36  Show Profile  Reply with Quote
gosh, just go and add insult to injury here
maybe I should write it down in my maintenance log right next to where the hours of the last oil change should have been written down
Jeez, I'm getting complacent...I think I sense a "I learned from that" story coming up soon
rblochli
RO# 644
Posted - Nov 03 2009 :  18:56:44  Show Profile  Reply with Quote
or look here http://www.buckalgonquin.com/pages/ProductPages/drivetrain/PB_standard_spud_page.html
PartyTime
Homeport: Forked River, NJ Go to Top of Page
Posted - Nov 03 2009 :  19:09:12  Show Profile  Reply with Quote
Bob, that table won't work for all. My shafts are 1 1/4" and the packing size is 3/16".
