[ Active Members: 2 | Guests: 46 ]  [ Total: 48 ]  [ Newest Member: horwoodlk1 ]
 Trailer Emergency Brake Question
Author Previous Topic: Cruising Essentials? Topic Next Topic: WaterPack Dinghy- Updated Photos
justgotaboat
RO# 31427
Posted - Feb 17 2010 :  19:32:26  Show Profile  Reply with Quote
Another trailer related question. I work for a commercial dive company. We have a handful of trailers set up with all the necessary dive gear and tools to do most jobs. We typically park the trailers on site while we do the job. As we were hitching up to leave our last site, my superviser tested the emergency brakes on the work trailer by having one guy in the truck put it in drive and roll forward slowly. He then pulled the emergency brake cable to the trailer and popped the pin out. The truck came to a stop as it should since the trailer brakes engaged. He then plugged the pin back in and off we went with full confidence that the trailer brakes and emergency brake mechinism work. The trailer has an electric brake system and is a tandem axle cargo trailer that you see most contractors or lawn care guys with.
Question is.... On a trailer with surge brakes, can you test the emergency mechinism by giving a heave on the emergency brake cable? Or are the mechinisms on surge brake trailers a one time use kind of thing, where once you pull it and it engages, the brakes are on for good? It seems like the cables that run from the trailer emergency brakes to the truck are small enough that they are intended to snap after engaging the brakes and are not meant as a extra way of holding the trailer to the truck. And it is my understanding that these emergency brakes are meant to engage if the trailer becomes detached from the truck in an severe accident or malfuntion. I was just thinking that it would be nice to be able to test my emergency brake mechinism, but I certainly do not want to throw the brakes on perminantly while sitting in my driveway loaded and ready to hit the road for the weekend, or have to pay someone to figure out how to unlock the brakes. (and yes I did ask the superviser if he knew if this worked for other kinds of trailers with either surge or electric brakes, and smartly enough he said.... "I know it works for THIS trailer... ")
Homeport: nj
rbmitchell
RO# 3641
Posted - Feb 18 2010 :  05:39:06  Show Profile  Reply with Quote
The surge brakes emergency lever stays engaged after it is activated. You have to manually reset it. If you park the trailer on a slope, you can "set" the brake by pulling the cable. The cable on my trailers has a 480 pound test break (1/16 diameter galvanized) and would be expected to break after setting the brakes.
The electrical brake requires power to operate even in an emergency mode. Therefore, you have to have a battery on the trailer. I suppose you could use the brakes for parking but I have no idea how long the battery would last.
justgotaboat
RO# 31427
Posted - Feb 18 2010 :  16:37:33  Show Profile  Reply with Quote
how do you manually reset the brakes after the cable has been pulled?
rbmitchell
RO# 3641
Posted - Feb 19 2010 :  05:23:04  Show Profile  Reply with Quote
On my LoadRite, the cable pulls a lever forward which latches in the forward position. You just have to push it back to the released position.
There is a label on it which says something about not moving the trailer in the locked position.
This page took 0.61 seconds to load
