[ Active Members: 5 | Guests: 90 ]  [ Total: 95 ]  [ Newest Member: cepaul ]
 Hull Deadrise For Transducer (1989 Santego)
Author Previous Topic: Suggestions For Santego Radar/GPS Antenna Mounting Topic Next Topic: Misery loves company... my list
hawkeyes01
RO# 31963
Posted - Apr 23 2010 :  16:46:46  Show Profile  Reply with Quote
Hi everyone,
I currently have a transducer mounted on the starboard side of the middle line of the boat, about 10 feet from the back. It is in the same compartment that houses the V-Drive if anyone is familiar with the setup of an '89 38 ft. Santego.
I'm going to replace this transducer. The transducer I want to purchase has two models to select from depending on the deadrise angle of the hull where it is mounted. Options are:
1. 0 - 12 degree deadrise
2. 13 - 24 degree deadrise
Anyone have any idea which one I need to purchase?
Homeport: WA
hawkeyes01
RO# 31963
Posted - Apr 23 2010 :  16:50:15  Show Profile  Reply with Quote
One note, in the specs on the Carver website for the 89 Santego, they state the hull has a 12 degree deadrise at the transom. Did I just answer my own question? Or do I need to figure out the specific angle at the location where I want to mount the transducer?
Homeport: WA Go to Top of Page
imspacemancraig
RO# 31301
Posted - Apr 27 2010 :  11:06:40  Show Profile  Reply with Quote
You are going to want to measure the deadrise at the specific location of where you want to install the transducer. I just had a new transducer mounted on my Mariner. I went to ACE Hardware and bought a angle measuring tool called a Magenetic Angle Locator that you hold level and tilt the tool up and then count the degrees to get the proper measurement. Cheap tool (12.99) that I will use once most likely, but got the deadrise which was a bigger angle than I had imagined. I ended up getting the 13-24 degree transducer as mine was 18 degrees where it was mounted.
Go to ACE Hardware's site and do a search for a "Magnetic Angle Locator". When you are about to spend some coin on a transducer, might as well get the right one.
Homeport: Winneconne, WI Go to Top of Page
