[ Active Members: 6 | Guests: 195 ]  [ Total: 201 ]  [ Newest Member: E350 ]
 Wellcraft Owners
 trouble shooting my windless
Author Previous Topic: Wellcraft for sale Topic Next Topic: update - plastic water holding tank. Bad Business
RBD
RO# 16247
Posted - Aug 05 2010 :  14:04:07  Show Profile  Reply with Quote
I have a 1999 wellcraft 3600 martinique with a lewmar anchor windless that is not working.
I was wondering if anyone has a step by step procedure on how to investigate the problem.
The first step in the operation of the windless is to turn on a accessory switch on the panel next to the driver. It should show a red light in the switch to show it has power. It does not indicate power. I transferred the wires to a switch that i know is good ,still no power to the switch.
I do not have a schematic
Homeport: Buffalo, NY
Posted - Aug 05 2010 :  14:50:18  Show Profile  Reply with Quote
You will probably get a much better response on the engines and electric forum. Lots more people read it and it's not really a Wellcraft issue.
Shadowcruzr
RO# 1702
Posted - Aug 06 2010 :  06:08:43  Show Profile  Reply with Quote
There are two fuses/CB for that system: One very large (90 amp) CB in the engineroom that protects the large wires feeding power to the motor. THere is also a small (3 or 5 a fuse/CB) for the control wires. This is inside the helm area. I cant remember if it was an inline fuse or a panel mounted one. Follow the red wire from the switch center position to find that fuse.
Paul
ETC, USCG, Ret
My oath to support and defend the Constitution against all enemies, foreign and domestic..., did not end when I retired. I stand by it till the end.
RBD
RO# 16247
Posted - Aug 06 2010 :  06:40:40  Show Profile  Reply with Quote
Thanks Paul I will continue to try to locate the fuse/cb that should be in the control circuit.
Homeport: Buffalo, NY Go to Top of Page
Posted - Aug 07 2010 :  02:33:07  Show Profile  Reply with Quote
Just shoot the windless and get a new one......
RBD
RO# 16247
Posted - Aug 09 2010 :  07:18:38  Show Profile  Reply with Quote
Well my problem was a circuit breaker that tripped but did not really protrude enough to visually see that it tripped .
Pressed the button with a little more force and it reset.
Operated the windless 5-6 times and no problems.
Also made sure to have my back up anchor rode easy to deploy in case the windless does fail .
