[ Active Members: 20 | Guests: 122 ]  [ Total: 142 ]  [ Newest Member: Captian Tow-em-back ]
 Sea Ray Owners
 Water Diaphragm Pump Cycles On and Off
Author Previous Topic: 420 A/C opinions Topic Next Topic: Holly teak linoleum flooring
bsquared
RO# 31184
Posted - Nov 29 2010 :  18:53:50  Show Profile  Reply with Quote
My water diaphragm pump cycles on and off every minute or two. Anyone have any idea what the problem could be?
Homeport: Jacksonville Beach, FL
Golfman25
RO# 1239
Posted - Nov 29 2010 :  21:34:12  Show Profile  Reply with Quote
You might want to post in a different forum like electric, plumbing. My guess would be a faulty pressure switch or a leak. Good luck.
Homeport: Algonquin Go to Top of Page
Posted - Nov 29 2010 :  22:43:54  Show Profile  Reply with Quote
Could be air in the lines or a small leak.
I have heard the pump bump now and then, it is under the V-berth.
I just get up and run some water in the sink a few seconds and that usually stops it.
Don't know what makes it do that. It just does. It happens most after we run the water
out and refill the tank. I try to keep fresh water in the tank and lines every other
week.
Posted - Nov 30 2010 :  07:54:07  Show Profile  Reply with Quote
how old is the pump, what model?
could be a faucet that's left dripping (dont forget stern showers and anchor wash down) otherwise could be a defective / leaky diaph or just some debris stuck in the diaph.
bsquared
RO# 31184
Posted - Nov 30 2010 :  20:03:16  Show Profile  Reply with Quote
No faucet is dripping. I'll check for debris and leaks this weekend.
Homeport: Jacksonville Beach, FL Go to Top of Page
dancerscap
RO# 20150
Posted - Nov 30 2010 :  20:41:22  Show Profile  Reply with Quote
My dancer did that for a long time. 'til I got off my butt and looked for the leak. Found it at the discharge fitting. Was barely finger tight and keeping the bilge wet. A little tef tape and pair of pliers applied judiciously fixed it.
Homeport: Hudson,Fl. Go to Top of Page
SCORPIO
RO# 4810
Posted - Dec 12 2010 :  09:56:16  Show Profile  Reply with Quote
I had this happen on my 300 DA. Turned out that the dockside water inlet was leaking just a little bit and allowing pressure to bleed off causing the pump to run, a new inlet fitting and problem solved.
Chris USPS AP
Homeport: Lewes, Delaware Go to Top of Page
Posted - Dec 12 2010 :  10:14:52  Show Profile  Reply with Quote
Best way to test if its the pump is to get a end cap and stick it right after the pump.
If it holds pressure then its not the pump and it has to be a leak.
About Time
RO# 26785
Posted - Dec 13 2010 :  07:30:36  Show Profile  Reply with Quote
Had a similar problem
Finally got ambitious and tightened up all the hoses clamps I
could get to that were on the water system.
Found two that I could tighten about 1/2 a turn.
Bingo, no more pump cycling.
Abouttime
Homeport: Lake Texoma Go to Top of Page
MikeeH
RO# 6342
Posted - Dec 13 2010 :  08:54:55  Show Profile  Reply with Quote
Certainly not an issue that would be limited to Sea Rays. Questions like this would be better served in the other forum as noted by Golfman. BTW, my money is on a small leak somewhere in the system. Had the same issue on my Carver years ago and it took some serious crawling around through the bilges to find it. Turned out to be a cracked fitting.
I recently realized that at this stage of my life I'm now wise enough to know better, but old enough not to give a damn.
Homeport: Still Pond, MD Go to Top of Page
1984richter
RO# 23403
Posted - Dec 13 2010 :  10:13:35  Show Profile  Reply with Quote
had the same problem on a 45 searay eb found it to be a leaking hot water tank safty valve. it would drain into the a/c sump overflow tube and not the bilge. hope this helps.
Homeport: marathon florida Go to Top of Page
bsquared
RO# 31184
Posted - Feb 21 2011 :  11:05:03  Show Profile  Reply with Quote
Problem resolved. It was a leak as most of you suggested. It was a small leak in the hose connecting to the washdown spigot. It was dripping down to the transom and then going down a drain. Thanks for those who replied.
This page took 0.7 seconds to load
