[ Active Members: 7 | Guests: 173 ]  [ Total: 180 ]  [ Newest Member: john kalinowski ]
 Wellcraft Owners
 V drive shaft packing? 94 Martinique 3200
Author Previous Topic: Putting together a Wellcraft Martinique Manual Topic Next Topic: 2600 Martinique Leaking Windshield
charliekeri
RO# 30755
Posted - Nov 30 2010 :  13:46:15  Show Profile  Reply with Quote
I have a 1994 3200 Martinique 3200. Twin 330 V drives. Has anyone ever done this on their own? Any tips/tricks greatly appreciated. My mechanic is trying to tell me I might be better off converting to dripless packing which involves big $$$$
Is there ever a point where conventional packing will not work any longer? Shafts scored? etc.
Homeport: Charlestown, MD
Posted - Nov 30 2010 :  15:56:21  Show Profile  Reply with Quote
YOu can get the shafts fixed if they are not scored too bad.
Bent shaft can mess up packing too.
There is no reason to switch, if the shaft and packing gland are in good shape.
How often do you change the packing?
It is not hard to do, but you shouldn't have to do it that often.
We have had our boat for 5 years. The Stbd. packing is the same packing when we got the boat. Tightened once in that time.
The Port packing has been tightened a few times and changed out once. When we pull her this winter, we are going to check the shaft.
The_Mayor
RO# 19101
Posted - Nov 30 2010 :  15:59:28  Show Profile  Reply with Quote
Can you even get to the packing? I have a 2000 3300 martinique with big blocks. There is no way I would be able to get to them. Check this site out. He has some awesome step by step instructions on how to do the job. Good luck.
http://www.pbase.com/mainecruising/boat_projects
Golfman25
RO# 1239
Posted - Nov 30 2010 :  22:55:42  Show Profile  Reply with Quote
I would consider the gore dripless packing. Do it once and you're done for a while. Not significatly more expensive than the regular stuff. Good luck.
Homeport: Algonquin Go to Top of Page
charliekeri
RO# 30755
Posted - Dec 01 2010 :  16:46:55  Show Profile  Reply with Quote
I have big blocks and getting to them is going to be very tough. I have never done it myself. I just want to find out what my options are besides lifting the engines and putting in dripless. It might be that my mechanic is just too big and doesnt want to deal with it the way it is.....Supposedly they were changed when I purchased the boat 3 years ago. Why they are leaking so bad and have gradually gotten worse as this past season went on I have no idea.
Homeport: Charlestown, MD Go to Top of Page
This page took 0.65 seconds to load
