[ Active Members: 6 | Guests: 213 ]  [ Total: 219 ]  [ Newest Member: Tolly34ss ]
 Sailing and Sailboats
 Sailboat on a lift
Author Previous Topic: Catamaran Charter in the Keys Topic Next Topic: Sailboat recommendation?
JeffN
RO# 3672
Posted - May 31 2011 :  15:57:16  Show Profile  Reply with Quote
Can a sailboat, 26' be lift kept? Swing keel so no problem there. It's water ballasted so perhaps the ballast need to stay full for balance but it sits nicely on a trailer so maybe not...
When I was 5 years old, my mother always told me that happiness was the key to life. When I went to school, they asked me what I wanted to be when I grew up. I wrote down "happy." They told me I didnít understand the assignment, and I told them they didnít understand life. ~John Lennon
Homeport: Vero Beach FL
Posted - May 31 2011 :  16:58:53  Show Profile  Reply with Quote
http://airdock.com/frame_1.htm
scroll down to see a picture of a sailboat [picture #9 on the page]. "The Air-Dock Boatlift works with trimarans and retractable keel sailboats."
The owner is very helpful in answering your questions.
Just think about the mess Obama inherit this time. And it ain't Bush's fault!!!
JeffN
RO# 3672
Posted - Jun 12 2011 :  21:06:42  Show Profile  Reply with Quote
Thanks Liz, found the same model that lived on a lift so it's do-able.
Posted - Jun 13 2011 :  06:43:58  Show Profile  Reply with Quote
sure, it is done often here
Posted - Jun 13 2011 :  07:26:30  Show Profile  Reply with Quote
Not far from our marina is a 40 foot catamaran on a lift. If you can put that on a lift, no reason not to put a 26 footer on one.
I've seen a number of sailboats at least as large as yours on lifts.
Peleka7
RO# 691
Posted - Jun 14 2011 :  09:04:43  Show Profile  Reply with Quote
Not sure about any advantage of the air lift. Seems you will have a major problem with the air pontoons.
Another issue is you can't get to the hull bottom. Another issue is the boat hull will still get wet from even small wave action...growth and slime.
I guess it would keep the boat from sinking...unless rain filled the boat beyond weight capacity.
Somebody explain this to me as I don't get it.
Homeport: O'ahu Go to Top of Page
JohnC
RO# 204
Posted - Jun 14 2011 :  15:38:15  Show Profile  Reply with Quote
A friend of mine has the air dock. This is his 4th or 5th season with it and no problems so far. The primary advantage in his case is it's not a fixed structure and doesn't require permits, so he's able to use it in his marina in a regular slip. It does keep the boat completely out of the water and no growth or slime.
Homeport: Long Island, New York Go to Top of Page
JeffN
RO# 3672
Posted - Jun 14 2011 :  18:17:21  Show Profile  Reply with Quote
I was concerned about the mast and any ballast being out of the water. Seems like there'd be a big loss of stability especially ina water ballasted hull(sans water ballast).
