woodchuck
RO# 3462
Posted - Jul 20 2011 : 10:20:33
Poll Question:
Do you leave your marine A/C unit on all week while away from your boat? I shut mine off all the time when I leave the boat, but during these heat waves the inside of the boat is over 90 degrees when I get down on Friday. I was thinking about leaving on but turning up to around 80 degrees. My units the fans run all the time and the compressor kicks in and out as needed. I have tried leaving on the humidity setting but does not do enough.
Homeport: Bear, DE
C team
RO# 24911
Posted - Jul 20 2011 : 10:37:19
I've been leaving mine on for years during extreme weather. I normally leave it around 80° to 85° so when I come down; the inside is not over 100°. This also makes it easier on my refrigerator
Craig
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain |
Homeport: Skipjack Cove, Sassafras River MD
RO# 36
Posted - Jul 20 2011 : 10:43:56
Ditto on the extreme weather and reefer deal. When the atrificial plants wilt it's time for action.
| It's easy to be a liberal when you have tons of cash, or, you really need it. |
Edited by - boatbum on Jul 20 2011 10:44:29 |
The Other Gary
RO# 143
Posted - Jul 20 2011 : 10:45:00
We are in extreme weaher here this past week and the boat is 87 when I get home from work Today and tomorrow is even hotter so it will stay on today.
I saw a movie where only the military and the police had guns,,,,, It was called Schindler's List |
Homeport: Toronto, Lake Ontario
SLW
RO# 2186
Posted - Jul 20 2011 : 10:52:39
I adjust my SMX controls to change the frequency and runtime of the De-Hu mode to match the weather conditions, but THIS weather is extreme. It's gotta run nearly all the time to keep up.
Homeport: Cedar Pt, Oh / Mi / Miami
Veg
RO# 20854
Posted - Jul 20 2011 : 10:55:57
I never did, I don't like the idea of a possible leak, but for the first time ever I left it in the HUM mode this week because the heat is like nothing we've had here in years, so it kicks in every 4 hrs for a half hour and until the temp drops by 2 degrees.
| 2001 Tiara 2900 Open - "O Sole Mio" - Stillwater, MN |
Homeport: Stillwater, MN
RO# 16492
Posted - Jul 20 2011 : 11:04:12
To me, high temp is 78*F, which is about where it stays when I am away. The fridge stays cold and it is nice to come to the boat with no to little humidity. I know folks who button their boats up tight and shut down all electric except for the fridge to save money. To me, that is mildew waiting to happen. I figure I am either going to spend the money on electricity or cleaning supplies.
-- Me |
Homeport: Hopewell, VA
getakey
RO# 32379
Posted - Jul 20 2011 : 11:06:18
SF Fog - no A/C required :)
Homeport: CA
Veg
RO# 20854
Posted - Jul 20 2011 : 11:08:26
BTW, I leave the battery charger running as well as the fridge, but I don't "button" up the boat tight. I leave one porthole open on each side which allows air to move through. Never had any mildew and the cabing never feels all that hot when I come back.
And I don't do it to save money, I just like to close all the sea-cocks when I'm away, including the A/C one.
I'd probably do it differently if I were in the south... Though I'm pretty sure I'd go with a covered slip down there.
Edited by - Veg on Jul 20 2011 11:09:06 |
RO# 16492
Posted - Jul 20 2011 : 12:09:00
quote: Originally posted by Ernesto
...I leave one porthole open on each side which allows air to move through....
You don't get the requisite; "Where the hell did that rainstorm come from?"; in Minnesoooooootah.
-- Me |
Veg
RO# 20854
Posted - Jul 20 2011 : 12:12:27
Hahaha. Yes we actually do get a lot of bad thunderstorms in the summer. In fact the past couple of weeks have been crazy, last week we had straight line winds with gusts in the 70mph range. For some reason, water never comes in my portholes even in strong storms. Must be good porthole design (they face slightly down as in most boats), good drip action happening from the hull/deck joint rather than water running down the side of the boat, plus maybe the proximity of boats and dense trees at my marina that mitigate the winds. IDK, but the water stays out.
Edited by - Veg on Jul 20 2011 12:14:38 |
RO# 842
Posted - Jul 20 2011 : 12:27:04
I do it only to keep humidity down.
Homeport: Gulf Coast FL
nwaring
RO# 16045
Posted - Jul 20 2011 : 12:44:11
We live onboard so yes I do leave it on but I am having such a issue with the through hull plugging up I watch it like a hawk. With all the things I have been going this year with water flow problems I would shut it off if gone for more than a day.
Niles
"Interlude" 87 Mainship 36DC
Edited by - nwaring on Jul 20 2011 12:45:42 |
Homeport: Ashtabula Oh - Lake Erie
Robski97
RO# 7334
Posted - Jul 20 2011 : 12:46:15
I leave mine set to HUMIDITY control. ( then Adjust the run time as required ) Extreme heat will take its toll on the Frig !!
| 2006 44 Sundancer |
Edited by - Robski97 on Jul 20 2011 12:47:44 |
Homeport: Merrick, NY
jlmanatee
RO# 9726
Posted - Jul 20 2011 : 14:09:30
Our marina has stated that if folks keep leaving their AC on all the time when the boat is not occupied, they will have to raise the rates.
On the Upper Mississippi 1988 Carver Mariner |
Homeport: Red Wing, MN
GeeBee
RO# 385
Posted - Jul 20 2011 : 15:13:13
You don't leave the A/C on here in Georgia expect mold the size of cocker spaniels somewhere on your boat.
Homeport: Lake Lanier, GA
OLD HOUSEBOATER
RO# 9099
Posted - Jul 20 2011 : 15:56:44
We have always run a dehumidifer when not on the boat.
OLD HOUSEBOATER The French fries are cold so we gave you extra. |
Homeport: GULF SHORES AL.
Bluto
RO# 31838
Posted - Jul 20 2011 : 16:21:45
I turn it off because it's so hot, it won't cool the cabin until the sun sets.
Homeport: Cincinnati, OH
RO# 10265
Posted - Jul 20 2011 : 17:30:24
Leave it on all the time, set to 78. That is why my electric bill is so high but it's nice to come to a dry cool boat. Mold will grow quick if not on.
2009 Regal 4080 Volvo Diesel IPS |
RO# 12640
Posted - Jul 20 2011 : 17:32:57
I like what Ernesto does, me, its on 24/7 from the time the boat goes in till the time it is hauled. Early in the season and late in the season I have it set in the humidity mode, rest of the season I have it set at 75 degrees.
I hear those that close all sea cocks, me I don't, I do exercise them though. I inspect my hoses every time I am in the bilge and have changed them when I see signs of wear, IMHO, if you properly maintain your boat and are on top of it, there is very little chance of a leak. Also, I have a lot of wood in my boat, lots of glued molding, heat, humidity, and wood is not a good mix. Electronics like routers, tv's, satellite boxes, DVR, etc also like an environment that is stable. Also I think it also depends on what model boat you have, my boat being a fly bridge boat has lots of big windows, unlike my Searay I had. My salon can get real hot, even with the tinted windows, shades, and cover on the front window.
George Carlin |
RO# 12640
Posted - Jul 20 2011 : 17:35:03
Also, Having the Ac running all the time you are less likely to develop growth in the AC lines and unit. The flip side to that is (where I boat) you need to clean the strainers more often.
George Carlin |
RO# 2017
Posted - Jul 20 2011 : 18:10:25
"Having the Ac running all the time you are less likely to develop growth in the AC lines and unit."
Actually you are more likely to develop growth in the lines and sometimes the coils. Because you are circulating nice clean water with food in it through the system.
Homeport: Sarasota/Ft. Lauderdale
mintregila
RO# 13060
Posted - Jul 20 2011 : 19:17:01
It's on Friday through Sunday. Humiditgy control on the rest of the time.
Mark I - 05 290 Amberjack 90 Viking 38 - Sold "Perfect Timing" |
Homeport: Long Beach, NY/Pompano Beach, FL
parkrode360
RO# 25031
Posted - Jul 20 2011 : 19:19:08
+1 on hunidity setting during the week, goes on twice a day for a limited time.
George & Gloree 2006 Rinker 360 Express "Bright Star" |
Homeport: Stony Point Bay Marina, NY
RO# 12640
Posted - Jul 20 2011 : 20:37:57
I thought having water always moving would not allow attachment and therefore no growth. Kinda like not using your boat or running it. Is this your opinion or do you have fact to back up what you are saying? In my case, it was simply my opinion.
Thanks walter
George Carlin |
mixman
RO# 25362
Posted - Jul 20 2011 : 22:00:18
I think Bill might be right on that point. The "critters" that are in the lines will die if the water flow stops. But keep the flow going and they will get food and grow.
As for me, I shut mine off. I have a friend who's boat caught on fire when their a/c burned up (they were near the boat in time, saw the smoke, and put the fire out). My catamaran came with a forced air system that draws cooler air up from under the boat (between the hulls) so I do run that in the summer plus an exhaust fan to help pull the hot air out. Since I've done that I've never seen it over 100 in the cabin which ain't going to hurt anything. The refrigerator and freezer do work harder, but they seem to put up with it.
--Kurt
17 knot cruise at 5mpg (3.5/gph). Two hulls are better than one! |
Homeport: Chesapeake Bay
RO# 12640
Posted - Jul 20 2011 : 22:11:55
The great thing about this site is being able to learn. "The "critters" that are in the lines will die if the water flow stops. But keep the flow going and they will get food and grow."
If they can't attach, due to flow, how can they grow??? Attachment makes a home, flow does not allow attachment, sh-t in sh-t out.
George Carlin |
Edited by - walterv on Jul 20 2011 22:14:44 |
mcarrigan
RO# 25569
Posted - Jul 21 2011 : 13:56:18
I can only get to the boat on weekends so I never leave mine running. I just received an email from my marina today about this very subject. It stated:
"It has been brought to our attention that many boat owners are leaving the air conditioning running on their boats while they are not on the vessel. This is against harbor policy. Heat and A/C units can only be run off harbor electrical while the boat owners is actually present on the boat. The constant use of these AC units causes power outages in the harbor and then other customers loose power to refrigerators and chargers. We will be doing daily checks of the marina and we ask that all AC units be turned off while you are away from your boat."
Homeport: St. Clair Shores, MI
RO# 16492
Posted - Jul 21 2011 : 14:08:33
Sounds to me like you are over "marina'd" or underpowered. Same problem at my marina on weekends when the place is packed.
-- Me |
RO# 28365
Posted - Jul 21 2011 : 17:27:11
I suppose that there probably is no harm in leaving it on, and the electric bill is not really a factor because I wind up paying the basic rate most of the time anyway, but I just can't warm up to the idea of having water pump in to my boat when I'm not around, so I turn it off. But, I have an express style boat and I keep the cabin very dark with the hatches covered when I'm not around so mold is not a problem in there. The AC also cools the relatively small cabin down very quickly, so it's not too bad. If I had a cabin with big windows that let a lot of sunlight in I would probably be more inclined to leave it on.
87 Sea Ray, 30' Sundancer Merri Mack MMSI #338122779 95 Eastern 22' C6 Corvette Convertible 68 GTO
Edited by - JVM225 on Jul 21 2011 17:28:45 |
Homeport: Farmingdale NY
RO# 3813
Posted - Jul 21 2011 : 18:00:42
I leave mine on in dehumidifier mode.
_________________________ 1999 Trojan 440 Express 2005 Scout 175 Sportfish Achilles LEX 96 MMSI# 338049724
Surly to bed, surly to rise... |
Homeport: SS3 @ PennyBridge Marina, Stony Point, NY
bobalong
RO# 19429
Posted - Jul 21 2011 : 21:17:22
My units are circa 1993 Cruisair. They are digital. And I don't have the owners manuals, being able to set to a humidity setting sounds good, if it had that feature.
Homeport: Sutherrrn Indianannna
rbmitchell
RO# 3641
Posted - Jul 22 2011 : 06:33:27
The control head should have a mode selection button. You simply select "dehumidify" and the unit will come on every four hours and run until a half hour has elapsed or the temperature has dropped two degrees (°F, that is) which ever comes first.
If there no selection, then the function is not part of your units brain.
| "The solution to this problem, when found, will be obvious." |
Homeport: Beach Haven NJ&KeyWest FL
rbmitchell
RO# 3641
Posted - Jul 22 2011 : 06:37:22
Our marina is in the process of resolving the question of leaving the air conditioning running (or heat or lights, et cetera) by metering every slip. Use it? Pay for it. Waste your own money.
This was precipitated, I heard, by the presentation of a recent electric bill which exceeded the annual budget and we're just starting the season.
pgilbert
RO# 17740
Posted - Jul 25 2011 : 07:51:53
Mine is on 7X24 and each slip renter pays their own electricity. Marina has no say in whether you run it or not. I do, however, turn off the cockpit refrigerator in this extremely hot weather.
Phil G 2005 Chaparral 310 |
Homeport: Lake Norman, NC
SLW
RO# 2186
Posted - Jul 25 2011 : 08:06:00
That's not actually true. The "dehumidify" button came WAY after the functionality. CruiseAir SMX controls have all sorts of user adjustments, but because it's not intiutive, many owners don't know about them. The "dehimidify" function on a SMX is activated by simultaniously pressing "HEAT", "COOL" & "FAN". The display will blink: "HU"
Other useful adjustments of the older SMX's include the dimming of the display LED's, adjustment of fan speed (to make low even lower for example) and changing of the runtime and duration of compressor cycles in HU mode.
The SMX manual is available in PDF format on the Dometic website.
MarineAir also produced control pads that offered a dehumification mode without a specifically labeled key.
SLW
RO# 2186
Posted - Jul 25 2011 : 08:15:25
MarineAir refers to the dehumidification mode as "moisture mode". Moisture Mode in the older digital controllers is activated while the unit is ON. Simultaneously press the PWR and the DOWN button.
Older digital MarinaAir units are also programmable and the manuals are found on the Dometic site as well.
marsij
RO# 9858
Posted - Jul 25 2011 : 08:44:15
I use that "moisture mode" when temps are in the 80's or less. When it gets into the 90's my cabin is like an oven & moisture mode just doesnt cut it. Then I put the a/c on but I set at 80-84. It makes a huge difference & I don't have to worry about my refrig frying.
Homeport: Penny Bridge Marina, Stony Point, NY
woodchuck
RO# 3462
Posted - Jul 25 2011 : 21:21:22
I did leave my A/C on all week last week. Canceled a family outing scheduled for last saturday (too hot). Changed settings on humidify for this week, every 8 hours runs 40 minutes. Probably still not enough.
Homeport: Bear, DE
Dani-Lu
RO# 19601
Posted - Jul 25 2011 : 22:34:43
I leave mine on humidity setting during the week when not on boat. Run AC 100% of the time on weekends at dock or on generator. Not only for temperature but to keep the cabin dry. Rather not have a boat that smells like a boat, if I can help it.
__________________________________________________ "Dani-Lu" - 2001 - 410 Sundancer - Cat 3126's |
Homeport: Lindenhurst, NY
LuBell
RO# 30482
Posted - Aug 01 2011 : 14:01:18
With this season's extreme heat, I leave my a/c on to keep my bottles of wine from boiling.
LuBell Playing, Being, Driving "SEA SHARP" |
Homeport: Chicago, Illinois
