[ Active Members: 6 | Guests: 121 ]  [ Total: 127 ]  [ Newest Member: tonyj ]
 Winterizing & Springizing
 Antifreeze: -50, -60, -100???
Author Previous Topic: Winterizing the hot water heater Topic Next Topic: To do while still in the water?
GripB
RO# 18473
Posted - Sep 23 2011 :  16:29:55  Show Profile  Reply with Quote
Putting together my winterization list and was doing some price shopping today at West Marine (they have rebates on antifreeze). While I was there, a salesman suggested that I use -60 antifreeze (I'll be storing the boat on the hard in northern MD). Must I use -60? Would -50 be OK? Let me know. Thanks.
Greg
2003 Cruisers Yachts 3372 (sold)
"More Lee'Sure Time"
2011 Boston Whaler 150 SS
"Just 4 Fun"
Homeport: Lakeland, FL
Posted - Sep 23 2011 :  17:19:43  Show Profile  Reply with Quote
have you ever been in -50 degree weather? Or even - 20 degrees? I would hope that -50 AF is more than sufficient in MD.
32carv
RO# 24150
Posted - Sep 23 2011 :  17:37:03  Show Profile  Reply with Quote
The value of getting the -60 would be that if you had some water left in the system and it mixed with the antifreeze, the net dilluted result would be slightly better and have a lower freeze point than -50. Not much, but enough to make a difference?
GripB
RO# 18473
Posted - Sep 23 2011 :  17:41:49  Show Profile  Reply with Quote
I hear ya cwms and that's exactly what I was thinking, though I'm curious as to how accurate those ratings are.
Greg
"Just 4 Fun"
Edited by - GripB on Sep 23 2011 17:44:08
Homeport: Lakeland, FL Go to Top of Page
GripB
RO# 18473
Posted - Sep 23 2011 :  17:43:23  Show Profile  Reply with Quote
Interesting point Jim.
Greg
"Just 4 Fun"
Posted - Sep 23 2011 :  17:44:01  Show Profile  Reply with Quote
I use -50, as does our marina, you'll be fine with it.
Posted - Sep 23 2011 :  17:45:25  Show Profile  Reply with Quote
Been using -50 for years.
If done right, there is not water hiding anywhere!
Run engine up to temp before doing it.
GripB
RO# 18473
Posted - Sep 23 2011 :  17:53:16  Show Profile  Reply with Quote
-50 it is, especially after hearing from the boys in NY (HOGAN and CurrentSea) with their comparable (if not colder) winter climate than me.
Off to composing my next winterization question(s) .
Thanks again!
Greg
"Just 4 Fun"
boatcomfort
RO# 32076
Posted - Sep 23 2011 :  20:09:27  Show Profile  Reply with Quote
-50 great enough for any winterization using the right amounts. One gl never enough just for a generator.
Homeport: New york Go to Top of Page
Golfman25
RO# 1239
Posted - Sep 23 2011 :  20:55:57  Show Profile  Reply with Quote
I use both. There is always a little residual water in my tank. I run the -50 thru to get most of the water out. Then 2 gal of -60 to give me piece of mind. After it mixes with the water, it is something less than -60. Good luck.
Homeport: Algonquin Go to Top of Page
LouC
RO# 10314
Posted - Sep 23 2011 :  22:58:21  Show Profile  Reply with Quote
Try putting a bottle of each of them in the freezer at zero, they will slush up and get hard, but not expand. That -50, or -60 is the burst temp of a water pipe, not freeze temp. They will start to solidify at about 15* F for the -50 and a bit lower for the -60. I use the -100 because it stays liquid way down to about -60 or so, that way even if some water did not drain, you will not have a problem...
rbeachhouse
RO# 32506
Posted - Sep 30 2011 :  08:46:14  Show Profile  Reply with Quote
I use -60 for engines and genny and -50 for the water system and AC. If you are thinking hard about it then the price difference is worth the peace of mind for $1 per bottle more for the -60.
R BEACH HOUSE
1988 34 Searay
1984 22 Mako
seabew
RO# 22559
Posted - Oct 26 2011 :  12:34:27  Show Profile  Reply with Quote
I have always followed my mechanics advice, start with -50 and finish with.
-100. The extra $$ is sure to be less than almost any repair.
Greg
Trojan 36 "Missy's Way"
Homeport: Stratford,Ct Go to Top of Page
Posted - Oct 26 2011 :  13:54:30  Show Profile  Reply with Quote
- 50 is fine, anything else is overkill
RO# 28365
Posted - Oct 26 2011 :  20:11:17  Show Profile  Reply with Quote
I use -50 and never had a problem.
2002 Sea Ray 410 Sundancer
95 Eastern 22'
05 Maxum 18' Bowrider
C6 Corvette Convertible
68 GTO
