VTBoater
RO# 30718
Posted - Feb 28 2012 : 19:26:48
Hi, I have the Kohler 7.3E genny, from year 2000. It always starts hard when cold, starts right up if shut down and warm. Is there an anti-siphon valve for fuel for these that might remedy the issue? Thanks!
2000 Carver 356 All Good! |
Homeport: Colchester, VT
jpowell
RO# 15168
Posted - Feb 28 2012 : 19:35:55
You are not getting siphon problems. There is a solenoid valve that keeps the fuel shut off when not in use and under certain trouble conditions.Willing to bet you have a plug problem,choke problem, carb problem or the cylinder heads are carboned up due to inadequate load while running.
Jay Powell Wellcraft Martinique 30' The World Ends in 2012 ! |
Homeport: Edgewater, MD
VTBoater
RO# 30718
Posted - Feb 29 2012 : 10:58:53
It is not a plug problem, I changed them mid summer last season after it was shutting down after running a while. Plugs cured the shutting down issue, but it still started hard when cold.
RO# 16492
Posted - Feb 29 2012 : 11:07:33
Carb or FI? My W'beke carb gives me fits cold. I was told it's because no fuel in the bowl due to evaporation.
YMMV.
-- Me |
Homeport: Hopewell, VA
VTBoater
RO# 30718
Posted - Feb 29 2012 : 11:46:15
Its carb'd. I am heading to the boat now to take a few measurements for upcoming projects, I may consider pulling the carb off and bringing it home to get rebuilt.
boatcomfort
RO# 32076
Posted - Feb 29 2012 : 18:18:30
90% of these genny's 5E and 7.3E always start on the second attempt specially on cold weather. Carburetor rebuild is not a solution just replace it. I doubt is carb problem. Chokes yes I replaced a bunch of them. On the bottom of the cup there is the "anti-Diesel" solenoid if you have water or other type of fuel will shut the genny down.. You can clean and reassemble. But that's a common issue on cold weather.But if after start runs and when you restart runs on 1st attempt. I won't bother.
Homeport: New york
VTBoater
RO# 30718
Posted - Feb 29 2012 : 19:08:48
Thanks, I'm glad I did not pull the carb off today, it was cold in the boat and hard to get motivated to get much done. I will order a new choke for it and replace it before trying anything else.
