JZ
RO# 11176
Posted - Apr 09 2012 : 14:42:33
Turned on the head system. Noticed the 1/2 inch white tubing directly on the back had come off of the toilet. Some gas smelling liquid came pouring out. Turned off the head system switch and it stopped.
What the heck does this pipe do?
EcoVac has two other lines, 1/2 inch blue (water?) and a 2" white drain.
Edited by - JZ on Apr 09 2012 14:59:36
Homeport: Camarillo, CA
RO# 842
Posted - Apr 09 2012 : 14:51:37
smelled like gasoline or sewer gas????????
Homeport: Gulf Coast FL
JZ
RO# 11176
Posted - Apr 09 2012 : 14:57:31
Gasoline.
RO# 842
Posted - Apr 09 2012 : 15:02:46
did someone put gasoline in your fresh water tank?????
JZ
RO# 11176
Posted - Apr 09 2012 : 15:11:12
Well I sure as hell didn't. I ran the sink and it didn't smell like gas. I'm assuming the blue line is water? What's the white line is the question?
rblochli
RO# 644
Posted - Apr 09 2012 : 18:41:18
the freshwater comes into the back of the foot pedal and when depressed the fresh water travels up the hose to the back of the toilet (usually has a siphon break on it) into the bowl. Fresh water is in it, if you have a gas smell my guess would be the same as Bruce's. If you goggle ecovac (I think it is made by Sealand) I'm sure you'll find a schematic.
Bob PartyTime |
Homeport: Forked River, NJ
realrez
RO# 5522
Posted - Apr 09 2012 : 22:52:44
i had the same gas smell before on my boat after an hour of panically looking for a fuel leak found out it was stagnant water and moldy crap.
Homeport: LBI,NJ
RO# 842
Posted - Apr 10 2012 : 08:10:30
Thats why I asked the question.quote: smelled like gasoline or sewer gas????????
Most likely is water gone bad. That usually smell like rotten eggs. Very common with raw water flushing.
JZ
RO# 11176
Posted - Apr 10 2012 : 10:59:31
Well going to the boat today. The water has been sitting for a long time. I never use it. We'll see.
rblochli
RO# 644
Posted - Apr 17 2012 : 18:41:35
how did you make out?
Bob PartyTime |
JZ
RO# 11176
Posted - Apr 17 2012 : 21:13:04
Had someone check it out:
"I checked the toilet and found that the valve is staying open because of toilet paper not being flushed all the way down. It is a sewer smell that is caused from the toilet paper leaving the valve open. The smell is coming from the holding tank. The smell is not gasoline."
False, alarm, but three of us thought it smelled a lot like gasoline.
RO# 13885
Posted - Apr 18 2012 : 03:08:46
Maybe look into you diet? ;-)
_ Cruisers 5000 Sedan Sport/CAT 12LTR's - Light travels faster than sound. This is why some people appear bright until you hear them speak......... |
Homeport: Long Island, NY
