[ Active Members: 22 | Guests: 104 ]  [ Total: 126 ]  [ Newest Member: horwoodlk1 ]
 Fuel bladder
Author Previous Topic: 2007 Crusader Diagnostics Topic Next Topic: AC sea water shut off valve leaking
deltabighat
RO# 14904
Posted - Apr 20 2012 :  21:21:52  Show Profile  Reply with Quote
My 24ft Bayliner Trophy looks to have a fuel tank leak. It's a 1995. My options I am told is to remove the engine or cut the cockpit deck as the tank is sealed under the cockpit flooring. Someone told me today that in airplanes, they have collapsible bladders that fit thru small openings in the old tank, are filled with high pressure air to expand the bladder to fit all corners of the old tank and then used as a New
fuel tank. Anyone ever here of this?
Dbh
"the only time the boat has too much fuel is when its on fire"
Posted - Apr 20 2012 :  21:28:33  Show Profile  Reply with Quote
Does your tank have baffles in it? If so, that option will not work.
Great, now take it to NBR.
deltabighat
RO# 14904
Posted - Apr 20 2012 :  22:12:55  Show Profile  Reply with Quote
Great point........have no idea. Anyone know out there?
Cam
RO# 1558
Posted - Apr 21 2012 :  05:58:04  Show Profile  Reply with Quote
So far, all of the fuel tanks that I have seen opened, and the new ones being built, all had baffles in them.
Homeport: Bentley Yacht Club- Staten Island, NY Go to Top of Page
Posted - Apr 21 2012 :  08:41:06  Show Profile  Reply with Quote
What year is the boat?
Posted - Apr 21 2012 :  10:36:09  Show Profile  Reply with Quote
All tanks have baffles... This is not going to work.
Posted - Apr 21 2012 :  16:20:14  Show Profile  Reply with Quote
Just as you describe, I think Mike Rowe was involved with replacing a fuel bladder on a military(?) aircraft on Dirty Jobs.
But as wise men above point out, trying this with your boat tanks would likely be a baffling experience.
Posted - Apr 21 2012 :  17:01:49  Show Profile  Reply with Quote
Could you perhaps put a new tank forward under the V-berth? The make V-shaped inflatable fuel bladders that could do the trick. Might be worth it in your situation.
CapnJakVa
RO# 2192
Posted - Apr 21 2012 :  17:17:41  Show Profile  Reply with Quote
At about 6 pounds per gallon, that could be a lot of weight in the bow of a 24ft boat if the tank is decent size.
Homeport: Lottsburg, Virginia Go to Top of Page
Posted - Apr 21 2012 :  17:21:33  Show Profile  Reply with Quote
The boat of which I know, of similar size, did that used the trim taps to compensate.
Posted - Apr 21 2012 :  18:04:25  Show Profile  Reply with Quote
Trim tabs will push the bow down by creating lift at the stern. They can't create lift at the bow...
I don't like the idea of a soft fuel tank at the bow... Lots of banging, high risk of leaks
Posted - Apr 21 2012 :  19:43:07  Show Profile  Reply with Quote
Not so. I had an old Formula F233. I removed the deck and the tank. The tank did not have baffles. 85 Gallons.
Posted - Apr 21 2012 :  23:03:36  Show Profile  Reply with Quote
You are correct. It's not uncommon for smaller tanks in smaller boats to not have baffles.
troublemaker
RO# 32512
Posted - Apr 22 2012 :  00:25:32  Show Profile  Reply with Quote
Locate a plumber that has a camera they use to check drain lines.
TM
Homeport: British Columbia Go to Top of Page
Posted - Apr 22 2012 :  08:21:45  Show Profile  Reply with Quote
Or just open the access plate (or gauge hole) and use a piece of stiff wire to poke around
Posted - Apr 22 2012 :  08:41:29  Show Profile  Reply with Quote
I'm not even sure if the bladder/liner is really even an option. I would think it would have to be made to fit the specific size and dimensions of the tank it is going into. I can't see how sticking a bladder into and tank and just filling it with air would get it to mold itself to the shape of the tank and stay like that after the air pressure is removed.
rnbenton
RO# 31163
Posted - Apr 22 2012 :  10:11:19  Show Profile  Reply with Quote
Personally, even if you can insert a bladder it seems akin to using band-aids to treat a heart attack to me.
I'd do it right and remove the old tank and put in a new one. The glass work isn't all that hard.
Captain, Sea Tow Central Florida, St. Johns River
The Other Gary
RO# 143
Posted - Apr 22 2012 :  10:12:20  Show Profile  Reply with Quote
Pulling a gas engine is not a big deal, pull it, repair or replace the tank and you are good to go for years.
The logistics of setting up the fuel fill and vents with a bladder in the old tank or replacing the old tank don't compute.
Do it right the first time, it is gasoine after all.
I saw a movie where only the military and the police had guns,,,,, It was called Schindler's List
Edited by - The Other Gary on Apr 22 2012 10:14:50
Homeport: Toronto, Lake Ontario Go to Top of Page
absolute
RO# 31985
Posted - Apr 22 2012 :  10:45:01  Show Profile  Reply with Quote
Cut the deck, pull the failed tank, clean up any foam, remove hoses and clamps. Install new coated tank with new sending unit, hoses & clamps. Before deck is re-installed make sure the tank is properly grounded and be ready for another twenty years of boating.
Absolute
"Suckin Sludge & Havin a Gas"
Homeport: fl Go to Top of Page
Posted - Apr 22 2012 :  11:47:37  Show Profile  Reply with Quote
+1.
Depending on the year, the deck is glass over plywood. Removal, replacement and redecking is not hard and may be quicker.
Additionally, if you have a leak, that gas had to go somewhere. Some of it may be in the foam.
Thudpucker
RO# 10503
Posted - Apr 22 2012 :  15:58:59  Show Profile  Reply with Quote
Absolute and Dave are right. That's the best way to handle your problem.
I had a 30 Gal tank below deck with no baffles and never noticed a problem. In an old boat we had a 40 Gal Hot water tank athwart the Fwd Deck.
No baffles in that one either and no noticeable problems with it either.
Maybe they make an inflatable bladder with inflatable baffles?
Edited by - Thudpucker on Apr 22 2012 16:00:28
GeeBee
RO# 385
Posted - Apr 23 2012 :  19:28:28  Show Profile  Reply with Quote
Aircraft fuel bladders have clips which suspend the bladder within the wing to prevent collapse. You access the clips though various inspection panels in the wing. Even if you could get someone to make you a bladder, it would be dangerous because in the event of a leak, it would leak into the old tank, which would leak into your bilge. Oh, and aircraft bladder do have baffles.
Edited by - GeeBee on Apr 24 2012 06:17:03
This page took 0.78 seconds to load
