captchas
RO# 82
Posted - May 15 2012 : 08:08:01
I want to extend the range for my laptop.. Does anyone have experience on this topic? All help will be appreciated!
Calm Seas and Fair Winds M/V Freedoms Choice |
Homeport: Boynton Beach,Florida
RO# 13885
RO# 24494
Posted - May 15 2012 : 08:17:42
You will probably need more then just an antenna. The link in the above post takes you to a conversation about what will be needed. Bill
Edited by - Billylll on May 15 2012 08:19:29 |
Homeport: Tuckerton, N.J.
captchas
RO# 82
Posted - May 15 2012 : 08:26:41
Thank You!
RO# 12212
Posted - May 15 2012 : 12:28:31
Charles, if you want to extend the range, the Wave is the way to go... plug and play, easy to use, etc... we have one and love it.
Pascal 1970 Hatteras 53 MY 26' Starfish sloop 12' Westphal Catboat 16' Hobie Cat 13' Sandbarhopper
Homeport: Miami, FL
captchas
RO# 82
Posted - May 15 2012 : 13:32:35
Thank you ALL, I read with fascination all the information that you Guys put together on that topic...Way to much for me.. A boating friend of mine over on the Left Coast is sending me a unit from "PDQ Connect" A Slate 1000 N, he says it will do what I need... You Folks are well advanced in this stuff! Again I thank you All!
bradt
RO# 31225
Posted - May 21 2012 : 13:12:02
Pascal...where did you get your Wave unit? Went to the Wave site, looked at 1/2 dozen of their dealer sites and found NO Wave products on any of them. What model do you have? Thanks.
SlapShot Carver 444 CPMY Annapolis, MD |
Homeport: md
RO# 24494
Posted - May 21 2012 : 14:51:02
Call or e-mail a few dealers they will send you the literature. I personally use the EC high power series with the built in access point. Big bucks but it works great. I have tested the ROGUE units and they are nice and easy to use and (DIY) install. Bill
Edited by - Billylll on May 21 2012 14:54:42 |
RO# 24494
Posted - May 21 2012 : 16:42:51
Hot off the Press! TWC, Cox, Bright House, Comcast team up for Wi-Fi roaming Subscribers from Time Warner Cable, Bright House Networks, Comcast, Cablevision and Cox Communications will be able to log in to each other’s Wi-Fi hotspots, thanks to a new roaming agreement.
The deal among five of the top six largest cable operators in the nation will give their respective subscribers access to more than 50,000 Wi-Fi hotspots http://www.cedmagazine.com/news/2012/05/twc-cox-bright-house-comcast-team-up-for-wi-fi-roaming Bill
mixman
RO# 25362
Posted - May 21 2012 : 17:11:17
Dang, Bill, that's awesome. Except from looking at the coverage map it's all NJ/NYC and such only.
The Rogue isn't bad at all. As Bill said, it's very easy to install and use. My only issue to total lack of APs to connect to. Yet again I'm in FL and just got back from the Bahamas and it's been nothing but cellular coverage. What APs are there to connect to have horrible speed. With 4G coming in everywhere, it's going to be a death-blow to Wi-Fi from what I'm seeing/experiencing.
--Kurt
17 knot cruise at 5mpg (3.5/gph). Two hulls are better than one! |
Homeport: Chesapeake Bay
RO# 24494
Posted - May 21 2012 : 17:23:45
I see a need for both in my area. Most of the Cable Hotspots I can connect to run about 10mbps DL and when loaded 4-5mbps. I love Verizon LTE but I could quickly have a huge bill since there are no all you can eat Verizon LTE 4G plans. So on the move I use VZW LTE 4G and AT&T HSPA+ and when anchored or in the marina WiFi. I will find out where Cox Communications have their WiFi Hotspots located Kurt. I suspect it's not on the map. I know they are big from southern Maryland to Newport News Va. Bill
Edited by - Billylll on May 21 2012 17:35:24 |
RO# 24494
Posted - May 21 2012 : 17:38:06
The number of WiFi access points for public use is predicted to increase 4X in the next year. Then again so are the number of Verizon LTE sites and markets going to increase. Bill
mixman
RO# 25362
Posted - May 22 2012 : 08:16:09
Some of us have unlimited Verizon 4G :-)
Bill, I'll keep an eye out for these new cable-company hotspots. I've got Comcast internet at home and work, so I'm good to use their hotspots as soon as I find one :-)
--Kurt
RO# 24494
Posted - May 22 2012 : 08:36:15
Kurt there is no grandfathered unlimited 4G Verizon LTE service. If so I have not been able to find it. The Comcast Hotspots come up as Xfinity on the connection manager. Bill
Edited by - Billylll on May 22 2012 08:38:02 |
mixman
RO# 25362
Posted - May 22 2012 : 08:54:09
Bill,
For smartphones there is unlimited grandfathered 4G. They've been known to throttle 3g on the grandfathered plans, but not 4G as of yet. I pull the SIM out, put it in my Pantech UML290 dongle and plug that into my Cradlepoint Router. The Pantech shows up in my online VZW account and the account still shows unlimited. Another way to do it if you're not grandfathered is to add a tethering plan and then remove it. Adding the tethering plan to a newer account gives the smartphone unlimited usage. Removing it a few days later still leaves the unlimited usage for that SIM card. It might be a glitch in their system, but I keep reading about people doing it recently.
They're also offering 4gigs for for the price of 2 ($30/month). I've personally never gone over 2 gigs (except for the time my brother-n-law - MR. "I Love Sprint" used my hotspot to download 8 gigs worth of crap as he was roaming! :-)
No Xfinity hotspots seen via Rogue here in Stuart, FL. I won't hold my breath for when we get back to MD either. It's a great offer and an awesome service, but I think it's really only in and around your area as of the present time. Hopefully it will be expanded.
--Kurt
RO# 24494
Posted - May 22 2012 : 09:00:55
I typically use 2 to 4 gigs a day when working. Some of our propogation prediction programs are huge. It is unusual from me to use less then 40 gigs a month. This is why I spread my usage out between AT&T HSPA+, VZW LTE and WiFi when on the boat. Since I own the WiFi system and pay for the business class backhaul at the marina I tend to use that as my primary when playing "dock Mary". Bill
Edited by - Billylll on May 22 2012 09:01:55 |
mixman
RO# 25362
Posted - May 22 2012 : 09:11:58
Holy smokes, Batman! That's a heck of a lot of usage. I see your point.
--Kurt
