[ Active Members: 14 | Guests: 96 ]  [ Total: 110 ]  [ Newest Member: horwoodlk1 ]
 Raymarine C120 Locked Up
Author Previous Topic: Manually controlled mounted spotlight Topic Next Topic: Sealing a windshield
JeffR
RO# 19718
Posted - May 15 2012 :  16:32:38  Show Profile  Reply with Quote
When I put my boat away for storage last fall the Raymarine C120 Chartplotter/GPS worked fine. I just got it out of storage last weekend and the C120 is locked up.
When I turn it on it goes to the startup screen and sits there. None of the buttons are responsive - can't even turn it off without killing power to the unit. I've tried the factory reset and still nothing. I've asked around, including Raymarine, and it sounds like I need to send it in to Raymarine for service.
Before I do, has anybody experienced this, and if so, what was the fix?
Thanks!
Homeport: Chicago, IL
destination unknown
RO# 12619
Posted - May 15 2012 :  16:49:42  Show Profile  Reply with Quote
I would hook it up in a another boat and make sure there is no chip in it and see if it starts that way. could be a bad ground in your connections, a bad avionics card, could be a bad GPS antenna or Sounder unit.
Trouble shoot first before sending to Raymarine.
check Ebay for a C120 the prices are coming down. Might be cheeper then repair.
Homeport: Anchorage Yacht Club Lindenhurst, NY Go to Top of Page
Posted - May 15 2012 :  17:09:03  Show Profile  Reply with Quote
Have you tried this?
https://raymarine.custhelp.com/app/answers/detail/a_id/1332
Forget about backing up the unit it sounds like that won't happen. I would skip that part if it doesn't respond.
WirelessOne,
40 Mainship
Sedan Bridge
Posted - May 15 2012 :  17:13:58  Show Profile  Reply with Quote
If you have the manual I think the proceedure is on page 193.
WirelessOne,
40 Mainship
Sedan Bridge
JeffR
RO# 19718
Posted - May 16 2012 :  07:31:57  Show Profile  Reply with Quote
Thanks for the responses. I'm going to try to disconnect all Seatalk connections, etc and power up with only the power cord hooked up to see if I get any changes, but somehow I don't think I will.
Billy - I've looked there and spoken to Raymarine tech support on the phone, and I've pretty much gotten the answer that it needs to be sent in. Simply hoping for one last ditch effort before I remove it and send it in.
Homeport: Chicago, IL Go to Top of Page
Posted - May 16 2012 :  09:05:08  Show Profile  Reply with Quote
I understand you spoke with Raymarine tech services but did they have you try a master reset?
WirelessOne,
40 Mainship
Sedan Bridge
JeffR
RO# 19718
Posted - May 16 2012 :  09:37:11  Show Profile  Reply with Quote
Billy - yes, as mentioned in my original post, I've tried the factory reset and it has not changed anything.
Thanks.
This page took 0.73 seconds to load
