[ Active Members: 22 | Guests: 120 ]  [ Total: 142 ]  [ Newest Member: horwoodlk1 ]
 Carver 3207 shaft packing size?
Author Previous Topic: Diesel Engine Flush Topic Next Topic: Overheating at idle.
mjkkemper
RO# 21252
Posted - May 19 2012 :  16:51:20  Show Profile  Reply with Quote
I have a 86' carver 3207 merc cruiser
I wanted to see of anyone knows the stuffing box packing size
Is it 3/16 or 1/4"?
http://i1238.photobucket.com/albums/ff498/mjkkemper/27003.jpg
Homeport: Grosse Pointe Farms, MI
Posted - May 19 2012 :  20:15:18  Show Profile  Reply with Quote
Don't know, but you can use drill bits as a "feeler gauge". The snug one is the correct size.
Edited by - Gregory S on May 19 2012 20:15:57
mjkkemper
RO# 21252
Posted - May 19 2012 :  20:34:46  Show Profile  Reply with Quote
With only a 1/16 of difference a with the packing nut lose either or seem like they would work
I packed it with 3/16 and it seem loose. I packed it with 1/4 which fit snug
I don't want to heat up the box if 1/4 is to tight and I dont want a leaky shaft when i spash if the 3/16 is to small
Homeport: Grosse Pointe Farms, MI Go to Top of Page
Posted - May 19 2012 :  22:04:19  Show Profile  Reply with Quote
Use 1/4 GFO packing and it won't be a problem. And you can run it dripless.
Great, now take it to NBR.
32carv
RO# 24150
Posted - May 19 2012 :  23:12:39  Show Profile  Reply with Quote
I use 1/4" GFO in my 1985 Carver 3227. Yours should be the same. I'm not sure about running them dripless. I think you need some water to lubricate the packing or it will overheat and wear too fast or damage your shaft. (Nobody wants that!)
Check this out, it helped me:
http://www.pbase.com/mainecruising/stuffing_box&page=2
Edited by - 32carv on May 19 2012 23:17:53
Posted - May 20 2012 :  08:00:32  Show Profile  Reply with Quote
You can run it dripless. Tighten it just till it stops dripping and you'll be fine.
Posted - May 20 2012 :  12:31:08  Show Profile  Reply with Quote
You might also care to consider Duramax Ultra X packing material . It looks like it may be yet a step above the Gore GFO though both should do very well with no water drip required, .
http://www.youtube.com/watch?v=3hBHnOqR9NU (Duramax Ultra X vid )
http://www.gore.com/en_xx/products/sealants/packing/gfo_packing_fiber.html
Posted - May 20 2012 :  15:44:00  Show Profile  Reply with Quote
Should be a snug fit. If you can push 1/4" into the packing gland, then that's the size.
mjkkemper
RO# 21252
Posted - May 20 2012 :  17:06:51  Show Profile  Reply with Quote
Thanks, yep it's 1/4". 1/4 fit nice and snug. The port side had 3/16 in it and starboard 1/4". Why I don't know but when I asked the question I only had pull the port side and the 3/16 didn't seem right.. Today I pulled the packing on the starboard side and it had 1/4"
Posted - May 20 2012 :  22:08:31  Show Profile  Reply with Quote
Interesting. Looks like a GFO knock off. As you said, looks like either would work.
