[ Active Members: 5 | Guests: 62 ]  [ Total: 67 ]  [ Newest Member: horwoodlk1 ]
 honda 225 gallons per hour?
Author Previous Topic: twisted anchor chain Topic Next Topic: Sea doo explorer RIB
Kehaar
RO# 12312
Posted - May 27 2012 :  10:06:48  Show Profile  Reply with Quote
Anyone know the average gph for a late model bf225a. Mine is on a 24' center console
Homeport: The Northern Neck, VA
Posted - May 27 2012 :  10:28:15  Show Profile  Reply with Quote
depends on how much power you use. at wot my guess would be 18 GPH
Kehaar
RO# 12312
Posted - May 27 2012 :  10:37:51  Show Profile  Reply with Quote
Thanks. I was just looking for an avg. I am never at wot. Maybe 3500 rpm..
Homeport: The Northern Neck, VA Go to Top of Page
saltysam
RO# 26
Posted - May 27 2012 :  10:46:42  Show Profile  Reply with Quote
Factors such as weight, hull shape, hull condition, water conditions, etc. may drastically affect consumption figures.
Most often the numbers one hears about are reckoned at wide open throttle. A traditional Rule of Thumb is 1 gal/hr for every 10 HP at normal operating power. Not difficult to start to amass your own actual calculations. Why don't you stake out a decent visual range and start to calculate your own situation. Quite easy and well within the ability of moct boat owners.
Cheers!
Posted - May 27 2012 :  13:15:03  Show Profile  Reply with Quote
The good news is it has to be less than "225 gallons per hour."
rommer
RO# 12280
Posted - May 27 2012 :  21:48:52  Show Profile  Reply with Quote
I was wondering what Honda burned 225 gallons per hour?
Boats, yup, 5 of em...
WLC - We love Champlin's!
rbmitchell
RO# 3641
Posted - May 28 2012 :  04:47:28  Show Profile  Reply with Quote
Modern four stroke diesels will produce about 20 hp for each gph burned. Therefore, 225gph would be about 4500 hp. Gasoline is less efficient and would burn about 30% more or, at 225 gph, would reflect a 3500hp motor. That is, of course, maxed out.
A forty foot open fisherman with triple 1100s could do that. Or perhaps four "smaller" engines.
Sounds like decimal was left out and the fuel burn is actually 22.5 gph or somewhere around $100 per hour. Hardly more than hiring a babysitter.
Tim Bromund
RO# 18797
Posted - May 28 2012 :  07:48:07  Show Profile  Reply with Quote
I think he was referring to a 225 HP Honda OB an asking what the GPH burn rate is.
Tim
1986 Thompson 8652 Offshore Hardtop "FishStyx"
Salad is what FOOD Eats
Homeport: Olcott Beach, NY Go to Top of Page
JeffN
RO# 3672
Posted - May 29 2012 :  09:57:55  Show Profile  Reply with Quote
A 225 Yamaha we rent on a 23' Godfrey seems to get 2-3mpg at mainly cruise speeds.
Kehaar
RO# 12312
Posted - May 29 2012 :  11:31:56  Show Profile  Reply with Quote
I was mainly trying to get an idea because my fuel gauge was down and I wanted to sort of have a rough idea so I'd know about when to think about getting gas. Since then I messed around with my fuel sending unit and got the gauge working again. I do have an interest in knowing the gph and couldn't find it anywhere in my manual.Thanks for the input.
tugboat kevin
RO# 24998
Posted - May 29 2012 :  11:35:31  Show Profile  Reply with Quote
we average 250 per hour in poker runs running hard with a pair of 700ci 1500hp and thats wide open just a small fraction of the time
rbmitchell
RO# 3641
Posted - May 30 2012 :  04:24:10  Show Profile  Reply with Quote
I have a Bayliner 265 with a single 250 hp injected Mercrusier that burns 12-13 gph at 25 mph. That's 2 mpg. The numbers come from a fuel rate meter and GPS.
mixman
RO# 25362
Posted - May 30 2012 :  06:32:14  Show Profile  Reply with Quote
I don't think any manufacturer is going to list such as it will vary too much based on the vessel design.
--Kurt
This page took 0.89 seconds to load
