[ Active Members: 15 | Guests: 89 ]  [ Total: 104 ]  [ Newest Member: horwoodlk1 ]
 Removal Serpentine Belt Merc 5.7 EFI
Author Previous Topic: ARRRrrggghhh!  This really hurts! Topic Next Topic: Alpha 1, gen 2 shifting, no reverse
Danno
RO# 10045
Posted - Jul 03 2012 :  14:36:02  Show Profile  Reply with Quote
I need to replace the alternator on my '01 Merc 5.7 EFI and am not sure how to remove/replace the sepentine belt. The alternator appears to be on a Fixed bracket unlike older versions with serperate belts and tension adjustment made with the alternator.
Nic-Nac
Homeport: oceanside, NY
Brite Idea
RO# 12714
Posted - Jul 03 2012 :  14:53:19  Show Profile  Reply with Quote
you loosen the idler pulley to remove the belt
Posted - Jul 03 2012 :  17:26:55  Show Profile  Reply with Quote
On my van, there's a 1/2" square hole that a 1/2" breaker bar fits into. Pull down and block or tie the bar to keep the idler pulley 'open'.
JimPend
RO# 5022
Posted - Jul 03 2012 :  17:55:11  Show Profile  Reply with Quote
Sepentine belt, 1/2 inch breaker is the way to go. It's a tension pully not an idler, there will be a socket drive in the middle of it.
Jim P.
Edited by - JimPend on Jul 03 2012 18:33:40
tugboat kevin
RO# 24998
Posted - Jul 03 2012 :  18:41:44  Show Profile  Reply with Quote
there is no spring loaded tensioner you loosen the 5/8 nut on the adjustment idler then turn it with a 3/8s wrench its sorta a sprocket affair and moves up and down take a pic or draw the belt routing first its a bitch to figure out sometimes .....if you have a lot of belt dust you must sand the pulleys then scotch brite them. rust will kill those belts they must be clean ....if a serpentine sqeeks a bit of baby powder stops it
JimPend
RO# 5022
Posted - Jul 03 2012 :  19:27:20  Show Profile  Reply with Quote
Tugboat, that doesn't sound good or right.
Jim P.
Danno
RO# 10045
Posted - Jul 03 2012 :  19:48:06  Show Profile  Reply with Quote
Thank you, I never looked at how simple they actualy made it to change the belt. I always keep 2 spares on board just in case of an emergency while under way but have never had to do it. Replaced the alt in 30 min - all good now.
Nic-Nac
Homeport: oceanside, NY Go to Top of Page
Posted - Jul 03 2012 :  22:38:27  Show Profile  Reply with Quote
You are 1/2 correct. It ain't good, but it's right. BTDT. Spent hours looking for an idler pulley on my 6.2's (same block stroked) until a mech told me exactly what Tugboat posted. The fact you have to adjust an "idler" pulley is a VLPITA, but it is what it is.
This page took 0.62 seconds to load
