BoatCrazy
RO# 30843
Posted - Jul 12 2012 : 05:05:47
Ive gone and replaced my blown evinrude with a lightly used '92 Suzuki DT 140. Seems to be a good motor thus far. 150 compression on all 4cyl. Since I got the motor, it does not pee out of the pee hole. A new water pump and impeller were done after I got the motor.
Ive put about 10 hours on the motor in the last week, she runs cool as could be so I know there is no overheating issue.
Should I worry? Ive even run the motor WOT for 15 minutes trying to get max RPM and what not, and she still did not overheat....
| "It is what it is and it aint what it aint" |
Homeport: Long Beach NY
The Other Gary
RO# 143
Posted - Jul 12 2012 : 07:30:09
stick a wire up the pee hole in case it is blocked
I saw a movie where only the military and the police had guns,,,,, It was called Schindler's List |
Homeport: Toronto, Lake Ontario
Prospective
RO# 23085
Posted - Jul 12 2012 : 08:08:58
+1 on this. I have a small Suk 6hp dink motor and have to do this every season, sometimes more than once. If it's not flushed with fresh water at the end of the season, I think salt crystals clog up there. But once you get water running thru it will rinsed out.
1990 Tiara 3600 Open Twin 3208 CAT Diesels
Homeport: Barrington, RI
BoatCrazy
RO# 30843
Posted - Jul 12 2012 : 08:12:46
Interesting.
So I am assuming that since the motor is NOT over heating, the water pump and impeller are doing their jobs?
So the water that would be coming out the pee hole, where is it now? It must be pumping, but do not see it leaving...
j-d
RO# 15782
Posted - Jul 12 2012 : 08:17:13
I don't know your model, but on a much smaller Zuki (3-cyl, 40-hp, 4-stroke) there were very small cooling lines associated with its EFI system. With a new pump and mud cleaned out of related passages, it still wouldn't pee till we cleaned out those EFI-related lines. I did not try to figure if plugged lines there would affect actual engine cooling. They were small enough that I'd suspect not.
God Bless, jd 1996 Sea Ray 215EC Alpha One GEN II 5.7L/350CID/EFI/220HP 14-1/2*19 Stainless RWC
Homeport: Sunny Florida
RO# 1159
Posted - Jul 12 2012 : 11:42:47
I'd suggest heavy mono (like trimmer string) in place of wire to lessen the chance of puncturing or pushing that indicator hose off the cowling barb. And check inside to make sure the hose is intact and firmly attached and secured with clamp, and the cowling drain holes are really clear.
A few years ago a friend had her professional O/B mechanic commission the same Suzuki DT 140 motor. It later turned out he had not reattached the hose properly, a little fallen excess grease and paintchip debris had clogged the cowling drain holes which is not uncommon, and after running a bit the 1st day , the cowling /hood filled up with enough water from the detached "pee" hose that salt water level was above the air intakes and drowned the engine... which seized up. Mechanic disavowed and it she had to foot the cost of another new engine.
| Sandy |
Homeport: The Vineyard
BoatCrazy
RO# 30843
Posted - Jul 14 2012 : 20:23:14
A simple piece of wire from a weed whacker did the trick. Cleared the hole, and then replaced the rubber hose to assure there was no clog left in there. She runs like a champ now!
Thanks guys!
j-d
RO# 15782
Posted - Jul 15 2012 : 07:24:14
Good on you!
TIP! Flush that engine thoroughly, NOT using its built-in hose adapter to flush with the motor not running. Rather, flush it on earmuffs with the engine running. The engine won't flush adequately to get salt out of the cooling passages up in the block. At least on some models. Neighbor asked me to look at his Zuki with a salt track on the upper side of the block. I told him "It's Cracked" and it turned out this low-hours motor had a salt block that expanded to where it split the casting.
BoatCrazy
RO# 30843
Posted - Jul 15 2012 : 13:45:16
Only way for me to flush the motor is to haul the boat. She usually stays in the water. How often should I flush her? Once a month?
I only put about 10 hours a month on the boat IF THAT.
My model, does not have the ability to flush using the hose adapter, only can be done on muffs..
mixman
RO# 25362
Posted - Jul 15 2012 : 15:34:33
I believe the correct/technical term for the "pee hole" is a "telltale". It's simply a way to know if the water pump is working or not. The engine, as you have proven will/can run fine when a telltale is clogged. But it's obviously a good idea to unclog it. My Hondas clog frequently after we get back each year from Florida/Bahamas due to the amount of calcium in the water. I have a very long twist-tie that always does the trick.
Flushing? I never flush my engines. They run at least once a week every week of the year and are self-draining. If Suzuki's are self-draining too, I wouldn't think it would be an issue.
--Kurt
17 knot cruise at 5mpg (3.5/gph). Two hulls are better than one! |
Homeport: Chesapeake Bay
RO# 36
Posted - Jul 15 2012 : 16:32:28
I was going to recommend Flomax until I read Kurt's update.
| It's easy to be a liberal when you have tons of cash, or, you really need it. |
BoatCrazy
RO# 30843
Posted - Jul 15 2012 : 19:25:43
Kurt, I knew the name, I enjoy peehole better :)
Ive had outboards no pee out water, however theyve always overheated. In this case, the motor was not overheating, so I was curious.
mixman
RO# 25362
Posted - Jul 15 2012 : 20:27:00
Understood. Peehole it is :-)
--Kurt
j-d
RO# 15782
Posted - Jul 16 2012 : 13:56:22
Motor I found the crack in was a Four-Stroke and this one is Two-Stroke. That, and being kept in the water, might make the flush issue less significant. I have no proof, but I'm starting to think that an OB or I/O kept IN water might experience less internal corrosion than one lifted onto trailer, dry stack or boat lift. Thinking the submerged exhaust cuts off the air supply to the corrosion.
