Author |
Kevdon22
RO# 32964
Posted - Sep 11 2012 : 18:23:24
I am considering purchasing one of those temporary plates that are installed in place of the sea strainer top to winterize engines, etc, via a small connection off the top through which anti freeze is sucked into the engine, etc.
Any one know the source of these temporary plates?
Thanks for leads.
Kevdon Forked River, Barnegat Bay NJ |
Homeport: Forked River, NJ
RO# 7357
Posted - Sep 11 2012 : 20:50:23
Do you really need a plate? For years, all I do is close the sea cock, take off the top of the strainer, have someone start the engine while I pour a couple of gallons of fresh water in (to flush) and then a couple of gallons of AF. Just as I'm running out of AF, I yell to kill the engine. Done.
Homeport: VA
The_Mayor
RO# 19101
Posted - Sep 11 2012 : 21:07:56
I take the hose off the strainer. Connect a long hose (sump pump hose) to it, and then to a funnel up at the dash with me. Pour a gallon in, fire up the engine, and add 2 more while idling.
Homeport: NY
DUSTCUTTER
RO# 10885
Posted - Sep 11 2012 : 21:52:30
We drilled and threaded one strainer lid. Draw AF directly from 5 gal bucket. One lid fits all strainers. Generator, AC, both motors.
Homeport: Bar Harbor, Ohio
Robyns Nest
RO# 4846
Posted - Sep 11 2012 : 22:02:07
If you have gassers, you can do what cwms says and just start the motor and pour the gallons right into the open strainer. No need for anything else. Did that for 20 years.
__________________________________________________ 2003 56 Post Convertible 2x1300HP V12 MAN 2001 26' Boston Whaler Outrage 2 x Mercury 225 Optimax -------------------------------------------------------- "The future ain't what is used to be." - Yogi Berra
Homeport: Monmouth Beach NJ
RO# 30499
Posted - Sep 12 2012 : 05:50:35
I do this with my diesels as well in fact you told me what to do and this has worked just fine for years.
“Time you enjoyed wasting is not wasted time.” – T.S. Elliotcommon. -----------------------------------------------------------
Homeport: Haverstraw, NY
RO# 10265
Posted - Sep 12 2012 : 06:46:42
I have the caps, they used to be made by a company called thoro-flush. They work good, but were costly. I have another cap made from starboard with a hose barb on it that a friend made. Screw it down on cap with a rubber gasket and it works fine too. So depending on how handy you are, there are a couple of ways to make it. I have been winterizing my boats like this for years, works fine.
2009 Regal 4080 Volvo Diesel IPS |
C team
RO# 24911
Posted - Sep 12 2012 : 07:02:08
Hate all this talking about winterization this soon, but I guess i know it's coming.
I winterize through my seacocks that have Groco flush kits and it also acts as an emergency bilge pump.
Craig 1981 Egg Harbor 33'
Homeport: Skipjack Cove, Sassafras River MD
RO# 3813
Posted - Sep 12 2012 : 07:14:16
Yep, that's how I do my diesels too
_________________________ 1999 Trojan 440 Express 2005 Scout 175 Sportfish
Surly to bed, surly to rise... |
Homeport: Haverstraw Marina, Haverstraw, NY
RO# 30499
Posted - Sep 12 2012 : 17:52:58
Hogan actually both you and Robins nest advised me on how to do this so far so good simple easy and quick to do!
Kevdon22
RO# 32964
Posted - Sep 12 2012 : 22:39:59
Thanks for the comments,I recall now that thoroflush was the manufacturer that I was looking for as mentioned. I did not mention it but I also winterize my Generator by pouring antifreeze into the strainer while the engine is running, but this does not work well for by AC system pump, probably because the pump needs liquid at all times to pick up liquid as it is not positive displacement. Therefore I was looking for the thoroflush type lid. They are apparently out of business. Based on a internet search I found reasonable lids for Perco at this site, although I have not confirmed that they are still in business.This would require drilling a hole in the lid and adding a nipple and valve as mentioned by others
http://www.cgedwards.com/Perko/pko305-11.html
Thanks again for helpful comments
RO# 2620
Posted - Sep 13 2012 : 07:07:02
Are you trying to winterize your AC? If so, the easiest way I've found to do it is with a portable 12 volt bilge pump in a bucket of antifreeze. You can either push it thru from the hose from the seacock to the pump and out the discharge port or even easier if on the hard, push it retrograde thru the discharge port and when pink comes out the bottom of the boat, you are done. With ether of these 2 routes, you do not run your AC pump.
Edited by - Gregory S on Sep 13 2012 07:08:07 |
Homeport: Norfolk, Va
Prospective
RO# 23085
Posted - Sep 13 2012 : 08:00:20
I would second greg's comment. You don't need any fancy attachments to do the a/c. I use a pump you attach to the end of a drill. Pull the hose off the sea cock, hook it to the pump and pump a gallon of pink thru the system. Takes all of about 5 min.
1990 Tiara 3600 Open Twin 3208 CAT Diesels
Homeport: Barrington, RI
Robyns Nest
RO# 4846
Posted - Sep 13 2012 : 09:15:54
If you want to winterize your a/c even easier use an air compressor. No spending on pink, no carrying to the boat, lugging into boat.
Simple and easy.
CPSS
RO# 13031
Posted - Sep 13 2012 : 12:51:34
Simple and easy.
Or just use a shop vac. Stick it over the AC discharge port, turn on vac, stop when all the water is out.
1989 Avanti 34'
Edited by - CPSS on Sep 13 2012 12:52:20 |
Homeport: Clifton Park, NY
Dusty Rhoads
RO# 10868
Posted - Sep 13 2012 : 13:45:01
We have thoro-flushes, and I believe they are out of business. My only problem I have ever had, was bumping the valve on top, and suckin air into my impeller vs water. The air won,,new impeller,,however it taught me to screw a nipple into each one for the boating season. Last yr. I put flexible hose to each strainer with a multiple gate valve, so I never moved the bucket,,just open active valve.
Dusty "Moon River" |
Homeport: Annapolis, MD
CRay
RO# 32502
Posted - Sep 13 2012 : 16:39:24
Made covers with hose fittings for the 2 sea strainer sizes out of 3/8" plexi glass. Drilled hole for hose barb and attched with JB Weld. Use the 5 gallon witerizing kit attached to it and it's a 1 man operation.
BTW, was in WMart a few days ago and -50 was $2.97 gallon, got 16 and save $20-$30.
Homeport: Braintree, Ma
bobalong
RO# 19429
Posted - Sep 13 2012 : 18:36:36
Drilled and tapped the existing lids. Installed a shut off valve and nipple. Doubles as an emergency suction pump in case of a leak, and makes for easy suction of anti freeze in the fall.
Homeport: Sutherrrn Indianannna
Veg
RO# 20854
Posted - Sep 13 2012 : 19:07:46
As mentioned above, not really necessary to buy anything else, I just take the cap off and pour the antifreeze in as I run the engine until pure pink comes out the exhaust. Always done it that way with no problem.
2001 Tiara 2900 Open - "O Sole Mio" - Stillwater, MN |
Homeport: Stillwater, MN
RO# 10265
Posted - Sep 13 2012 : 20:46:48
I wouldn't leave thoro flush or anything But the original strainer cap on. Thoro flush is pressure fitted. If that thing pops you will suck air or sink your boat.
ranger42c
RO# 32710
Posted - Sep 14 2012 : 06:51:09
Simple and easy.
Not so easy if winterizing with the boat in the water...
-Chris
Selby Bay, South River
Homeport: Londontowne, MD
alien1952
RO# 32487
Posted - Sep 15 2012 : 16:06:04
Exactly what is so hard in draining the heat exchangers and risers? You guess wrong or if the thermostst dosent open ,you just cracked something. Small block Chevy is 2 gal. in the block, and 1/2 gal in each manifold.
aka Bt Doctur |
Homeport: nj
GeeBee
RO# 385
Posted - Sep 15 2012 : 16:51:35
Nothing hard, but a little list can create entrapped water which could freeze and do damage. Nice thing about pouring in some A/F is no matter what happens, you are covered.
Homeport: Lake Lanier, GA
RO# 7357
Posted - Sep 15 2012 : 18:21:28
If you have a FWC engine, you do not have to worry about the thermostat being opened or closed.
Edited by - cwms on Sep 15 2012 18:23:31 |
Homeport: VA
Veg
RO# 20854
Posted - Sep 15 2012 : 20:09:36
My engines are FWC, so no such worries.
BoaterEd |
© BoaterEd |
