[ Active Members: 5 | Guests: 95 ]  [ Total: 100 ]  [ Newest Member: Heckjo ]
 Winterizing & Springizing
 winterization oil change
Author Previous Topic: Best Oil Changer Topic Next Topic: Water Plug unable to be unscrewed
dav
RO# 973
Posted - Oct 15 2012 :  11:28:24  Show Profile  Reply with Quote
I have always changed my oil in the fall. My neighbor claims spring is better. He believes condensation is a bigger problem.
Does it matter?
What does everyone else do?
Homeport: indiana
TJ7777
RO# 27397
Posted - Oct 15 2012 :  11:41:55  Show Profile  Reply with Quote
Ok, I own a '01 Wellcraft Martinique 2600
with the Bravo 3 outdrive 7.4 litre.
I will change my oil this year in the Spring because I believe in fresh oil that has not sat in a pan all winter. I think the Marina's do it in the fall because it's convienent to change the oil when they are winterizing your craft.
TJ
Better boating in the Finger Lakes!
Stephen
RO# 14
Posted - Oct 15 2012 :  12:26:13  Show Profile  Reply with Quote
My opinion is that it is better to change in the fall and allow the engine to run on the new oil when you bring it around to be pulled. This way everything is bathed in clean oil instead of sitting all winter bathed in contaminated oil. Regardless of what I may hear about oil sitting, I don't believe (my opinion) that there is any difference between the new oil sitting in the pan or sitting in a bottle for the winter.
maxumaa
RO# 24188
Posted - Oct 15 2012 :  12:43:38  Show Profile  Reply with Quote
I have 454 Mercs. I go with fall for the oil change. Don't want to have any acids/contaminants sitting in the oil over an extended period of time.
Keith
Homeport: Chestertown,Md. Go to Top of Page
LouC
RO# 10314
Posted - Oct 15 2012 :  18:24:39  Show Profile  Reply with Quote
Condensation I doubt would be anywhere near as bad as oil with the past season's wear particles, moisture, fuel dilution, etc. You buy a new car or truck, it could sit on the lot for 6 months easy before being sold with the same new oil in it. So the fall is the best time to change it. For outdrives, and outboard lower units, same thing, if water got in during the season it could crack the housing if it gets cold enough. Plus, if you got water in the lower unit, you will see that when changing the oil and get it fixed over the winter in the slow season, not in the spring rush.
mikeg
RO# 4814
Posted - Nov 03 2012 :  16:31:27  Show Profile  Reply with Quote
I only put 40 hours on my volvo penta 8.1 this year.100 hours are recommended by volvo.Would you put off the change til next year?Would you use synthetic or regular oil?
Riverratt
RO# 12842
Posted - Nov 05 2012 :  07:33:21  Show Profile  Reply with Quote
I have been running Mobil 1 in two different 7.4L powered boats since 1992. I use 15W-50 with a M1-302 filter (your filter would likely be different since you have a 8.1L engine). I would not bother changing oil with only 40 hours on it.
Edited by - Riverratt on Nov 05 2012 07:34:31
Homeport: St Charles, Missouri Go to Top of Page
Captain_Rick
RO# 33100
Posted - Nov 06 2012 :  08:51:37  Show Profile  Reply with Quote
With synthetic oil, I agree. But I know supposedly knowledgable people who use conventional oil, and change it in the fall and again in the spring with zero hours on it. Supposedly it deteriorates over time regardless of having not been "used."
Is there any truth to that?
Homeport: Deleted Go to Top of Page
Posted - Nov 06 2012 :  09:37:11  Show Profile  Reply with Quote
I put 44 hours on my oil this season. Took samples and sent it our for analysis. The numbers came back fantastic, they recommend I put another 20 hours on the oil.
I'm not going to change mine this year.
Captain_Rick
RO# 33100
Posted - Nov 06 2012 :  15:50:19  Show Profile  Reply with Quote
I assume you have diesels in your Trojan. For gas engines, the quantity of oil makes it just about as cheap to change the oil as to have it tested.
I'm running Amsoil synthetic in mine and will be going on my third season next year. At 6 gallons per engine it's a big savings to have it analyzed. And it's such an effort to get to my starboard oil filters that it's worth the price to me to use synthetic.
Posted - Nov 06 2012 :  17:18:17  Show Profile  Reply with Quote
I only put 27 hours on this year. My new motor warranty says I have to do a change at 25 - 30 hours for the first one and recommends 75-100 after that. Since I am changing oil in one I might as well do both. I too am sending out samples of both motors, the transmissions and this year the generator. Just about 20 gallons of oil for the motors and generator, about 5 for the transmission. At $12/gal and another 60-100 in filters it ain't cheap. But having replaced a motor, it is definitely cheaper than that. Getting it tested in the fall and changing in the spring if necessary is a good alternative.
Captain Rick, I don't know what motors you have but have you thought about relocating the filters. Both of mine are on centerline. Very easy access.
1997 Trojan 440 Express
Homeport: Patch of Dirt in Pasadena, MD Go to Top of Page
Captain_Rick
RO# 33100
Posted - Nov 06 2012 :  21:04:06  Show Profile  Reply with Quote
Sure have. But the job pretty much as to be done in conjunction with an oil change. And as hard as it is to simply change the filters (all by feel - can't see them), I'd have to hire a contortionist to do it. If I only have to change oil every 3 to 4 years, it's probably not worth it.
Posted - Nov 06 2012 :  21:43:16  Show Profile  Reply with Quote
It's about acid. You would rather that your engines did not sit in it over the winter if present.
mikeg
RO# 4814
Posted - Nov 22 2012 :  21:36:58  Show Profile  Reply with Quote
Follow up on my question about a volvo penta with 40 hours (now 48) on the oil.I already had the filter and mobil 1 15/50 was $22 for 5 qts at Wallmart so I gave it a quick oil change.The 48 hr oil was black and sludgy (yes it was changed las year by a mechanic).I was suprised it looked so dirty with so few hours.After seeing the condition I'll cont to throw in clean oil before storing the boat.Went synthetic due to advise on the net and volvo recommendations but the mobil 1 was affordable.2 five qt bottles at west marine would have been more than $90.
