[ Active Members: 5 | Guests: 56 ]  [ Total: 61 ]  [ Newest Member: colrhino ]
 Wellcraft Owners
 How to remove microwave form 2001 Wellcraft Martin
Author Previous Topic: Wellcraft 1986 Engine Timing Topic Next Topic: new wellcraft owner
TJ7777
RO# 27397
Posted - Feb 19 2013 :  12:02:58  Show Profile  Reply with Quote
My microwave needs to be replaced and it will not come out through the front of the cabinet. Does anyone know how to remove the cabinet?
thanks,
TJ
Better boating in the Finger Lakes!
Homeport: NY
Posted - Feb 19 2013 :  12:12:40  Show Profile  Reply with Quote
Do you have it loose yet?
SR holds them in from the bottom with several screws. You have to remove those screws and rotate the unit 90* to remove it.
Pix would help.
danielcooper9
RO# 24397
Posted - Feb 19 2013 :  15:29:15  Show Profile  Reply with Quote
Can you take the top off of the cabinet? It may be screwed to the walls under the trim piece that runs along the outside edge of the top (at least on my 99). The only way to go out the back is to remove the entire cabinet or go through the side of your boat. There has to be a way to get in out without removing the entire cabinet.
TJ7777
RO# 27397
Posted - Feb 20 2013 :  09:46:29  Show Profile  Reply with Quote
Thanks guys,
I have decided at this point that any new microwave is bigger than the cabinet opening of 18x9, so I decided to open the front of the cabinet by 1" and after installing the new microwave, place a "trim kit" around the opening where I cut.
TJ
whitecrystal1
RO# 24497
Posted - Mar 25 2013 :  21:16:26  Show Profile  Reply with Quote
That is what I had to do to mine. Only I went through the trouble of pulling mine out the back before I realized I could not get one to fit without cutting the front out. That sucked!
Ralph
"small batch"
2001 Wellcraft Martinique 2400 5.7L EFI BIII
2010 Silverado CrewCab LTZ 4x4 L9H-6.2L NHT
Homeport: Dumfries, VA on the Potomac River Go to Top of Page
