[ Active Members: 2 | Guests: 172 ]  [ Total: 174 ]  [ Newest Member: Steve717 ]
 Cloudy lenses
 Forum Locked |
Author Previous Topic: Clean Stamoid Topic Next Topic: Removing mildew stains on fabric/cloth headliner
Posted - Mar 04 2013 :  14:40:26  Show Profile
OK, this is for my car, not the boat, but a lense is a lense.
I've got a 10 year old Accord and the headlight lenses are Very cloudy. All you detailing gurus...what's the best way to clean them up?
Homeport: VA
carver 2557
RO# 11591
Posted - Mar 04 2013 :  14:54:37  Show Profile
Rubbing compound. Same as you would so your boat. I did mine and they came out almost as good as new...
Posted - Mar 04 2013 :  15:09:23  Show Profile
That's what I was thinking. I tried some heavy duty cleaner/wax that didn't do much. I guess it just wasn't aggressive enough.
carver 2557
RO# 11591
Posted - Mar 04 2013 :  16:29:07  Show Profile
If there not to bad, try some toothpaste first..It will work if they arnt totaly fogged....
williamabernathy
RO# 32322
Posted - Mar 04 2013 :  17:04:21  Show Profile
I've had good luck with a Turtle Wax lens cleaner (I think it was TW, may have been Rain-X). It came with some rubbing compound, different grit sponges, etc.
Bill A.
'68 Bertram 38AC
Homeport: hampton, va Go to Top of Page
yamadon7
RO# 23522
Posted - Mar 04 2013 :  17:19:11  Show Profile
Headlamp lenses are clearcoated just like paint.
If the clear has yellowed severly it has to be removed. Wet sand with 600 grit followed by 1000. Then finish sand with 2000, then wheel with a fine grit compound,then follow with 3M Finesse It. It should look like new. Unfortunately it has to be polished once or twice a year to stay that way.
Don
Don
"Debra May"
85 Chris Craft 425
Homeport: Harrison Twp, MI Go to Top of Page
DeeVee
RO# 645
Posted - Mar 04 2013 :  17:19:51  Show Profile
You can use any rubbing compound then hit them with a final wax, they'll looks like new, toothpaste works too but it'll takes little longer, if you want them to last, wet sand them then polish/wax them.
Posted - Mar 04 2013 :  22:01:04  Show Profile
http://www.youtube.com/watch?v=_t1RBw0IGXA
Posted - Mar 04 2013 :  22:07:22  Show Profile
Glitz or Wenol and a harbor freight buffer.
Homeport: Richmond, VA Go to Top of Page
j-d
RO# 15782
Posted - Mar 04 2013 :  22:23:52  Show Profile
Our 2006 Corolla has sat in the FL sun since new. I was polishing it last month and decided to try the dulled headlights. I was using a one-step liquid polish/wax called Blue Poly. Don't know if it's even still available since I'd had it a long time. The lights turned out like new with only hand rubbing.
God Bless, jd
1996 Sea Ray 215EC
Posted - Mar 05 2013 :  04:44:38  Show Profile
Thanks guys for all the suggestions.
Carvervirgin
RO# 32836
Posted - Mar 05 2013 :  21:18:24  Show Profile
Flitz has a plastic restorer kit as well.
Bucket List, 2001Carver 356
Lake Champlain, Vermont
Bliss
RO# 2743
Posted - Apr 04 2013 :  12:37:30  Show Profile
My 2001 Lexus' lens weren't real bad. I used my huge Milwaukee buffer and some rubbing compound. I made sure not to gouge or heat up the lens. I finished with Fineset(?) Looked great 'til the wife totaled the car!
getakey
RO# 32379
Posted - Apr 04 2013 :  12:50:32  Show Profile
I bought a Restore Kit made by Sylvania. It was a 4 or 5 step process. The final step is a UV Blocker application which if you do not apply, the lenses will just fog up again.
My lenses were pretty bad and I had serious doubts about the Restore kit. I was amazed at the results. Looks new
Homeport: CA Go to Top of Page
rawidman
RO# 25110
Posted - Jan 27 2014 :  09:02:22  Show Profile
Back in the "good old days", headlights were made of glass and didn't need to be polished. One of these days I'll have to tackle the headlights on my wife's 2007 car. Or trade it in!
2000 Camano Troll
Edited by - rawidman on Jan 27 2014 09:02:41
wezie
RO# 32638
Posted - Aug 19 2015 :  13:54:04  Show Profile
They forgot that lexan or polycarbonate, while tuff, is not UV stable.
So we polish and wax.
Homeport: TX Go to Top of Page
Mike McManus
RO# 958
Posted - Aug 19 2015 :  23:49:40  Show Profile
I got this at Walmart worked pretty well
Homeport: Port charlotte , Florida Go to Top of Page
Posted - Aug 20 2015 :  04:27:25  Show Profile
I have a '95 integra with those small round plastic lenses. I also have a buffing wheel on my grinder. Get white buffing compound on a clean buffing wheel. Comes out 100% new as long as you don't buff too long on a single spot(gets hot)
Robyns Nest
RO# 4846
Posted - Aug 20 2015 :  12:05:24  Show Profile
If you have a can of spar varnish you can also restore using that.
1000 grit sandpaper first, then a coat of varnish.
Presto.
Clear and like new.
2020 Princess F62 1200 MAN's
2020 Sea Hunter Tournement 350 Triple 300 Yamaha
- Yogi Berra
Homeport: Hollywood Beach FL Go to Top of Page
Posted - Aug 20 2015 :  12:40:00  Show Profile
She blamed you for the lights being too bright didn't she?
Stolat
RO# 13929
Posted - Aug 27 2015 :  21:02:40  Show Profile
Finesse it II Polish with a buffer at low speed.
Just my .02
--Steve
Morgan Rose
1993 330 Sea Ray Sundancer
Patchogue, N.Y.
Homeport: Patchogue, N.Y. Go to Top of Page
Posted - Sep 07 2018 :  21:29:28  Show Profile
Isn't the dulling of headlight lenses sometimes partially due to evaporated moisture residue on the inside surface? Or does the exterior compound and polish procedure always seem to work as it sounds so far, above.
Posted - Sep 07 2018 :  21:29:29  Show Profile
PJ
RO# 396
Posted - Sep 08 2018 :  15:09:03  Show Profile
I just replaced the entire headlamp assembly it was very simple. Then I aligned the head lamps by shining on the garage door. And OH they look like new.
Paul aboard Ocean Maid
Edited by - PJ on Sep 08 2018 15:10:39
 Forum Locked |
This page took 0.55 seconds to load
