[ Active Members: 7 | Guests: 174 ]  [ Total: 181 ]  [ Newest Member: john kalinowski ]
 Sea Ray Owners
 2004 420 DA - fix up questions
Author Previous Topic: 410, 415, 440 AC Topic Next Topic: wanted - Sundancer 40 - 42 2005 or newer
BVasily
RO# 18136
Posted - Jul 21 2014 :  15:13:31  Show Profile  Reply with Quote
Proud new owner of a 2004 420 DA. Several items need fixing up and I am hoping to get some advice from DA owners.
1. Water pump very loud, vibrates and periodically will not shut off. HAve checked for any signs of water leaks in system and there appears to be none. Is the repairable or am I better to purchase a replacement ... or other?
2. Master Stateroom head appears to lose its seal. I suspect this is simply a Vac-u-Flush maintenance kit.
3. Top side fridge vibrates, is loud, and seems to run +70% of the time. Any advice short of replacement?
4. Generator not pumping water now. Suspect an impeller which I will check.
Appreciate any advice from seasoned owners.
Bob V.
Seeleys Bay, Ontario, Canada
Homeport: Kingston, Ontario
Posted - Jul 21 2014 :  17:23:42  Show Profile  Reply with Quote
I think you have answered most of your own questions but I wanted to point out that these questions really are not specific to your brand and you may have better luck getting them answered in their specific category. Such as the marine head question.
Robski97
RO# 7334
Posted - Jul 23 2014 :  13:48:13  Show Profile  Reply with Quote
Water pumps suck....If its running water is going somewhere.... Lots of places to check.
GENSET is the impeller
Cockpit fridge vibrates... its the interior shelf.
FWD head... could be gasket. Id flush it a lot ... pour alttle bleach in the bowl. wait a few and flush some more...
its usually junk that stops the seal.
What else u got .
ROb
2006 44 Sundancer
BVasily
RO# 18136
Posted - Jul 23 2014 :  14:04:32  Show Profile  Reply with Quote
Thanks Rob.
Replaced impeller and Genset works well now. Water pump intermittent. Sometimes runs constantly, othertimes fine. No sign of water leaks ... but also seems to be no air charge in the Sureflo Accumulator. Will try that first. Any simple solution to the fridge shelf? Will also try your solution for head.
Bob V.
Homeport: Kingston, Ontario Go to Top of Page
Posted - Jul 23 2014 :  14:06:53  Show Profile  Reply with Quote
Agree with John...your questions would be better in specific forums as they really are not SeaRay issues.
However...
No water flowing from the genset...have you checked to make sure your seacock is open?
Refrigerator...could be any number of issues, maybe small, maybe not.
Vac-u-flush...as you mentioned, maybe time for a re-build. Very common in most marine heads. Putting bleach in the head is not a good idea per Peggy Hall, well known "Head" mistress and expert in all issues regarding marine sanitation devices.
Water pump...most are on the loud side but agree with others...keep looking for a leak. Sounds like you have one somewhere.
jpowell
RO# 15168
Posted - Jul 24 2014 :  00:18:46  Show Profile  Reply with Quote
Water pump, undue connections between tank and pump, then redo.
Jay Powell
Sailfish 245DC
"Less Cha-Ching"
Homeport: Stevensville, MD Go to Top of Page
