[ Active Members: 5 | Guests: 202 ]  [ Total: 207 ]  [ Newest Member: Rleemorris ]
 Reviving Paint Sripe
Author Previous Topic: Washing Deck Topic Next Topic: Drilling fiberglass for snap fastener screw stud
Doc
RO# 17228
Posted - Dec 03 2014 :  10:14:58  Show Profile  Reply with Quote
I have a painted on 2" blue stripe around my bride combing. Could I wet sand it to give it enough life to last until my next planned yard visit in a couple of years? Grit?
There is safety in the slip.
42' Nordic Tug
Homeport: FL
Posted - Dec 03 2014 :  18:19:56  Show Profile  Reply with Quote
What have you tried? A good compounding with a buffer may do the trick but a light wet sanding should work as well just may have a bit more risk of damage by sanding thru. Are you sure that it's paint not gel coat? I usually like to start by using the most mild approach I would use buff magic and a buffer and see what it looks like then wax or polish.
Edited by - Audrey II on Dec 06 2014 10:07:58
Bob J
RO# 181
Posted - Dec 05 2014 :  17:52:02  Show Profile  Reply with Quote
Originally posted by Doc
Doc, you could just remove it & replace with vinyl. Had vinyl on my '93, 37C for 21 years & looks good as new. Fact !
BOB J
Bob J
Posted - Dec 06 2014 :  14:53:24  Show Profile  Reply with Quote
Yuck, just got rid of the 20 y/o vinyl boot stripe on my 34 c. New one is 3 coats of sprayed Awlgrip over primer. Should have done it years ago.
What ever you use on your stripe, test a small less conspicuous area first.
Doc
RO# 17228
Posted - Dec 06 2014 :  15:13:14  Show Profile  Reply with Quote
1. I like the look of paint but if I did it myself, it would look like I did it.
2. If I tried to apply tape it would look like I did it.
I think that I will try compound for now and get it painted next time I go to the yard.
42' Nordic Tug
