[ Active Members: 0 | Guests: 73 ]  [ Total: 73 ]  [ Newest Member: cepaul ]
 Formula Owners
 2009 40 pc
Author Previous Topic: Cup holder in main cabin Topic Next Topic: Sun pads
ChrisCom
RO# 6330
Posted - Aug 09 2015 :  09:45:08  Show Profile  Reply with Quote
Just purchased this beauty. Need some info. Which pump removes the water from the main sump located in the cabin floor(the sump that collects water from shower/sinks etc) It is not working.
I have the hydralic swim platform that worked when we went through survey now it is not. When I press the control the solenoid clicks but that is it....no manual came with the boat.
Roy
RO# 114
Posted - Aug 09 2015 :  21:14:09  Show Profile  Reply with Quote
You may want to press the seller or the broker a bit for manuals. Formula is great about supplying a 3 ring binder full of every manual for every device on board.
Good luck.....Roy
"Livin' life in the laid back lane" - Sunny Jim
Homeport: Sarasota FL Go to Top of Page
AcapulcoSeaMonkey
RO# 33212
Posted - Aug 31 2015 :  20:03:32  Show Profile  Reply with Quote
Congrats on a great boat. Ive had my 2008 41 PC for 3 years now with no major problems, other than my wife wanting to change the name from SeaMonkey to ForSale :(
SeaMonkey
jeff_c
RO# 25917
Posted - Sep 01 2015 :  10:46:33  Show Profile  Reply with Quote
Originally posted by ChrisCom
Congrats. Great boat. I had a '07 31pc
I believe the pump for the shower sump is inside the sump itself.
As for the swim platform...I have no direct knowledge but assuming you checked all breakers and fuses I would be checking to see if there is a microswitch on the transform door that requires it be closed/opened before operating the platform.
Jeff
______________
Current:
2008 Prestige 42 Fly...the "Major Decision"
Past:
1970 13' Boston Whaler Sport...the "Minor Decision"
2007 Formula 31PC...the "Family Decision"
2000 Proline 30 Express...the "Our Decision"
1997 Hydra-Sports 22' Center Console...the "Split Decision"
Homeport: Lindenhurst, NY Go to Top of Page
Posted - Sep 01 2015 :  11:15:17  Show Profile  Reply with Quote
Could even be a pin that locks it to keep it from dropping when underway if loss of hydraulic fluid.
ChrisCom
RO# 6330
Posted - Sep 03 2015 :  15:38:31  Show Profile  Reply with Quote
Swim platform works great. There is a breaker switch located on the firewall in front of the port engine. It was accidently tripped. You can see it from the access hatch in the cockpit but uless you know what it is.......
