[ Active Members: 1 | Guests: 179 ]  [ Total: 180 ]  [ Newest Member: colrhino ]
 Cutles bearing
Author Previous Topic: upgrading electronics Topic Next Topic: Mercruiser Service Manuals, Engines/Drives
ga48
RO# 17735
Posted - Feb 15 2016 :  08:54:26  Show Profile  Reply with Quote
Just wondering if anyone has heard of taking the strut off the boat to change the bearing?
Fiddlers Green
Homeport: Merrick,New York
Bruce Herrington
RO# 2612
Posted - Feb 15 2016 :  09:07:56  Show Profile  Reply with Quote
No. Can't imagine why it would be necessary unless strut was damaged.
"Democracy is two wolves and a lamb voting on what to have for dinner. Liberty is a well-armed lamb contesting the vote. Benjamin Franklin
WALSHIE
RO# 2124
Posted - Feb 15 2016 :  09:56:34  Show Profile  Reply with Quote
I agree, makes no sense at all. In fact there are ways to change the cutlass bearing without removing the shaft.
Posted - Feb 15 2016 :  10:02:42  Show Profile  Reply with Quote
You don't need to remove the strut to replace the cutlass bearings
Posted - Feb 15 2016 :  10:04:49  Show Profile  Reply with Quote
Sure... To Charge more labor... :)
smitty477
RO# 31913
Posted - Feb 15 2016 :  12:16:12  Show Profile  Reply with Quote
"Just wondering if anyone has heard of taking the strut off the boat to change the bearing?"
I have done a couple of dozen cutlass bearings on my own boat and friends boats over the years. On a couple of them it was easier to reach and drop the 4 bolts holding the strut and pull the strut/cutlass off allowing us to press the old one out and new one in in my friends heated work shop area with a nice press available. Just need to make sure you support the remaining shaft well until you have the strut back in place. Those were 2" or greater as the smaller ones are usually easier to work with.
No dollars involved just selecting the best way to do the job at the time when its on our dime so to speak.
Stephen
RO# 14
Posted - Feb 15 2016 :  17:16:47  Show Profile  Reply with Quote
When I replaced mine I removed it. That was only because I took it to the prop shop to be tested to ensure it was not bent. They blasted it clean and I never regretted that. But also in my boat's case it was a matter of four bolts with very easy access.
smitty477
RO# 31913
Posted - Feb 15 2016 :  19:52:46  Show Profile  Reply with Quote
"But also in my boat's case it was a matter of four bolts with very easy access."
+ 1 Stephen - same here , only took about 3 minutes with an electric drill and deep socket and then drifted the bolts out. After that we are back in a heated workshop with a nice press and an easy job standing up.
It all depends upon the boat and sometimes the weather.
Posted - Feb 15 2016 :  21:35:17  Show Profile  Reply with Quote
As long as the alignment is completely checked it's ok if that works for you. But if the alignment is good pulling the strut can lead to other issues.
You know, like there is always one bolt that refuses to cooperate and it is the last one so you are committed to mangling it?
Stephen
RO# 14
Posted - Feb 15 2016 :  22:26:53  Show Profile  Reply with Quote
Yep, the bolts were sure stubborn, and if I remember were the wrong type. Of course I happened to be alone and they just spun. I strapped vice grips on the top side of the bolts so they wouldn't spin. If I remember, I ended up finding the proper carriage bolts at a restaraunt supply hardware store in Vineland. I think I was referred to the place by GVP. For those who knew George, he could find ANYTHING or tell you where to find it.
Posted - Feb 16 2016 :  01:36:44  Show Profile  Reply with Quote
ga48- Was there any evidence of leakage at the strut bolts?
smitty477
RO# 31913
Posted - Feb 16 2016 :  08:55:11  Show Profile  Reply with Quote
"As long as the alignment is completely checked it's ok if that works for you"
Regarding alignment - on one 37 Sea Ray we were working on we could not get the alignment in specs easy - V drive and all that. Dropped the strut and shimmed it a few times temporarily tightening it down to see what we needed in thickness to get good alignment. When we were happy with the results we set the strut in permanent with sealant and it worked great - cannot take credit for the idea as it was on Tony Athens site at sbmar(dot)com. Had to do the cutlass and prop anyway as that was part of the problem to begin with.
FWIW - the problems I have seen with strut bolts are most often crevice corrosion. I have not had one spin on me but I did have one break off - a good thing we replaced thopse bolts in that case.
Posted - Feb 16 2016 :  12:25:45  Show Profile  Reply with Quote
This thread got me to thinking. Other than some material improvements, the design hasn't changed in decades. I wonder why that is.
jpowell
RO# 15168
Posted - Feb 17 2016 :  10:22:28  Show Profile  Reply with Quote
Why no design change ? It still works!
Jay Powell
Sailfish 245DC
"Less Cha-Ching"
Homeport: Stevensville, MD Go to Top of Page
Posted - Feb 17 2016 :  12:02:23  Show Profile  Reply with Quote
So did these.
I would have thought over time and with more powerful computers something more efficient would have evolved in the shipping industry that would have trickled down to us mere mortals.
vic33004
RO# 27361
Posted - Feb 17 2016 :  15:32:31  Show Profile  Reply with Quote
it has changed, think IPS and surface drives. based on the efficiency I doubt we will see many more planning hulls in the 10-30 ton range without them. outboard and I/O now pretty much own the under 10 ton planning hull design market.
Vic33004
02 Regal 4260
Homeport: Fort Lauderdale, FL Go to Top of Page
ga48
RO# 17735
Posted - Feb 17 2016 :  19:40:51  Show Profile  Reply with Quote
Nothing was leaking.Clearances were above specs.They need to be done so I an having them done before I bring it up from Virginia. Don't need any problems offshore.
Fiddlers Green
Homeport: Merrick,New York Go to Top of Page
Posted - Feb 17 2016 :  20:40:15  Show Profile  Reply with Quote
Need to be done?
