[ Active Members: 2 | Guests: 169 ]  [ Total: 171 ]  [ Newest Member: Steve717 ]
 48" Floresent lights in salon behind valances
Author Previous Topic: hydraulic steering -  loss of hydraulic fluid Topic Next Topic: 1996 Voyager 370
DUSTCUTTER
RO# 10885
Posted - Dec 28 2016 :  23:32:11  Show Profile  Reply with Quote
Need voltage requirements of 48" florescent lights behind valances in salon.
Homeport: Bar Harbor, Ohio
Posted - Dec 29 2016 :  00:05:01  Show Profile  Reply with Quote
Stick a volt meter on them.
Or easier yet, what's the voltage of the breaker that feeds the lights?
Edited by - Capt. Bill1 on Dec 29 2016 00:07:24
Posted - Dec 29 2016 :  07:15:02  Show Profile  Reply with Quote
Probably 120v. Which breaker controls them?
DUSTCUTTER
RO# 10885
Posted - Dec 29 2016 :  07:37:28  Show Profile  Reply with Quote
1987 Carver 3807. Blue and black leads from 12 volt panel feeds lights. We can find power from panel to switch. From switch to light is dead. Ground not complete. Are the bulbs regular 48" 120 volt and the fixture converts or are bulbs 12 volt? No power to ceiling puck lights either. Rest of the boat power up fine. We have removed interior wall coverings and counter tops. Now starting to reassemble. No more mauve colors.
Homeport: Bar Harbor, Ohio Go to Top of Page
Posted - Dec 29 2016 :  08:29:41  Show Profile  Reply with Quote
Bulbs are usually marked.
Posted - Dec 29 2016 :  08:46:05  Show Profile  Reply with Quote
I had the exact boat and all the fluorescent fixtures work on the boat's 12 volt circuit.
If I'm not mistaken, all replacement bulbs are the same. They will work on either a 12V or 110V circuit. When they are put in a 110V fixture, the ballast drops the voltage down to 12V. The few times I bought replacement bulbs, I got them at the hardware, not a marine or RV store.
Sounds like you've got a bad switch.
Edited by - cwms on Dec 29 2016 09:22:04
speedo
RO# 14386
Posted - Dec 29 2016 :  09:07:26  Show Profile  Reply with Quote
You need to match the bulbs to the ballast. I had kitchen lights that kept burning out because the were the wrong ones for the ballast. Didn't figure it out until the ballast went out and I had to replace it.
speedo
Redding, CA
