[ Active Members: 5 | Guests: 268 ]  [ Total: 273 ]  [ Newest Member: Rleemorris ]
 1987 3297 Mariner - Crusader 270 timing ??
Author Previous Topic: New floor in my 440 Express Topic Next Topic: 1990 Carver help!
Rybad
RO# 16624
Posted - May 29 2017 :  13:51:36  Show Profile  Reply with Quote
I recently bought a 1987 Carver Mariner 3297. We absolutely love the boat, the layout for a 32' simply cannot be beat including newer 32's. Anyway, since my wife and I love it so much, I wanted to do some upgrade. One of the upgrades was to remove old points/condenser and replace with Pertronix electronic ignition retro-fit. As part of this install, I need to adjust timing. Here lies my problem. I simply cannot find any service manuals or references to the timing on a 1987 Crusader 270 5.7l GM 350.
For the love of God man.. does anyone know the timing, and correct idle for this year model. And preferrably the total advanece timing?
I currently set to 10*BTDC but both engines run much worse than with old fashioned points
I did purchase the correct Pertroinx kit for my Malory distro
Homeport: Gibralter, Michigan
Posted - May 29 2017 :  20:05:12  Show Profile  Reply with Quote
You might want to ask your question over in the engines forum. You have an engine issue, not a Carver issue.
cmariner32
RO# 7269
Posted - May 29 2017 :  23:41:15  Show Profile  Reply with Quote
As a previous owner of a 3297, and to quote GVP (previous boatered partner and engine guru)you should invest in an adjustable timing light as it really doesn't matter what the timing is at idle-you want the correct timing at cruise. Timing should be done with a adjustable (digital) timing light. Based on what grade of gas you use, set the timing light to 32 degrees advance for high test, 30 for mid-grade. Run the engine at 3000 RPM and the timing mark on the harmonic balancer should be adjusted and set for 0 degrees TDC.
