[ Active Members: 10 | Guests: 117 ]  [ Total: 127 ]  [ Newest Member: luna sea ]
 Antifreeze change.
Author Previous Topic: Mercruiser 8.1L popping above 3400rpms Topic Next Topic: bilge pump float switches
Posted - Oct 22 2017 :  11:12:02  Show Profile  Reply with Quote
How often should antifreeze be changed in FWC engines?
Edited by - Gregory S on Oct 22 2017 12:00:30
Homeport: Norfolk, Va
ranger42c
RO# 32710
Posted - Oct 23 2017 :  06:42:25  Show Profile  Reply with Quote
Manufacturer's recommendation? FWIW, in our case, it's an item called out in the service manual...
-Chris
Selby Bay, South River
Homeport: Londontowne, MD Go to Top of Page
MichaelNJ
RO# 14778
Posted - Oct 23 2017 :  09:13:09  Show Profile  Reply with Quote
General guideline is five years but I used prestone extended life in 2012. My mechanic checked it yesterday with a refractometer and it's still good to -40
2006 Meridian 341 Sedan Bridge
Obsession
Newport Yacht Club, Jersey City, NJ
Flotilla Commander USCG Auxiliary Flotilla 42 1SR
Homeport: Jersey City, NJ Go to Top of Page
Posted - Oct 23 2017 :  10:20:09  Show Profile  Reply with Quote
That's why I asked Michael. Mine is also 5 years old, still looks and smells fine and when I checked it, it registers freeze protection to minus 34 degrees F. Unless someone points me in another direction, I can't see discarding perfectly good antifreeze. Do any of you change your car antifreeze every five years?
MichaelNJ
RO# 14778
Posted - Oct 23 2017 :  14:16:12  Show Profile  Reply with Quote
I think that's where the extended life product comes into play. I was once told that antifreeze becomes acidic after a period of time. So it may still offer freeze protection but lose the anti-corrosive properties. But according to Prestone, the Extended Life product should be flushed every five years. As far as my cars, I follow the car manufacturer's maintenance schedule for everything. Of course Prestone wants you to change it more frequently.
Obsession
Anchor Management
RO# 32420
Posted - Oct 23 2017 :  15:56:57  Show Profile  Reply with Quote
I use the test strips. They tell you exactly the condition of your AF.
2006 52 Searay Sedan Bridge
MichaelNJ
RO# 14778
Posted - Oct 23 2017 :  16:17:28  Show Profile  Reply with Quote
What does is tell you aside from freeze point?
Obsession
Posted - Oct 23 2017 :  16:50:14  Show Profile  Reply with Quote
Test strips are for ph. Base is good, acid is bad. Different then checking freeze or boil point.
Posted - Oct 24 2017 :  09:47:35  Show Profile  Reply with Quote
the anti corrosion additives in Af need renewal after a certain amount of time. The many different materials in today's engines may set up galvanic couples once the AF protection diminishes. Perhaps that can be tested but I don't know. MO use the same type AF you always used. In the past some newer long life AF didn't mix well with old style and was more prone to leaking.
risingson
RO# 29910
Posted - Oct 24 2017 :  14:04:36  Show Profile  Reply with Quote
Hank
What brand test strips do you use and for what type of
antifreeze? ELC caterpillar?
Michael
Homeport: Cos Cob, CT Go to Top of Page
Posted - Oct 24 2017 :  14:58:19  Show Profile  Reply with Quote
Originally posted by Gregory S
Test strips are for ph. Base is good,...
Unless SW is mixing in when when the engine cools in case of pinhole leak at the h.exchanger.
I just test for freeze boil protection and still have the A/F replaced every couple years at yard layup in spite of it's being Dexcool. Likely quite excessive but not a big deal.
But, hmmmm, have never replaced the A/F yet in my 2011 SUV. Gofigger.
Posted - Oct 25 2017 :  09:16:48  Show Profile  Reply with Quote
Yeah,, if your HE is leaking , you have bigger problems than wondering if it's time to change the antifreeze.
Posted - Oct 25 2017 :  09:27:00  Show Profile  Reply with Quote
How do you check for freezing and boil points?
MichaelNJ
RO# 14778
Posted - Oct 25 2017 :  11:09:24  Show Profile  Reply with Quote
My mechanic used a refractometer. It measures burst point. I wouldn't worry about boiling point.
Obsession
Brite Idea
RO# 12714
Posted - Oct 25 2017 :  15:25:28  Show Profile  Reply with Quote
If it's due change it just like oil changes or any other maintenance it's cheap insurance. I change mine every five years with a flush and new thermostats also.
Edited by - Brite Idea on Oct 25 2017 15:26:30
Posted - Oct 25 2017 :  20:34:28  Show Profile  Reply with Quote
Walter, you can buy an antifreeze tester at Autozone etc. one side shows you freeze point and the other side gives you boil point. Squeeze the bulb, suck up a sample to fill the chamber and the arrow points to the result.
Edited by - Gregory S on Oct 25 2017 20:35:44
Posted - Oct 25 2017 :  20:36:36  Show Profile  Reply with Quote
Posted - Oct 26 2017 :  15:48:40  Show Profile  Reply with Quote
thanks
TJM
RO# 2909
Posted - Nov 14 2017 :  09:55:00  Show Profile  Reply with Quote
Boats need SCA, Supplementary Coolant Additives for corrosion protection, lubricity etc...
Prestone makes an additive that lubricates but I replace mine every 5 yrs.
As others have said, pH should be lower than 7. It is also a good time to change your thermostat.
FWIW, your cars do not run at 75% of WOT for hours at a time like boats do. The potential of reduced coolant properties while at elevated temperatures around seawater gives me the shakes.
Tom
41' President
Homeport: Essex, Ct Go to Top of Page
Posted - Nov 14 2017 :  12:27:05  Show Profile  Reply with Quote
Lower than 7-- that would be acidic?????
GeeBee
RO# 385
Posted - Nov 18 2017 :  22:41:33  Show Profile  Reply with Quote
SCA's are not required in a gas engine, only diesel.
Posted - Nov 20 2017 :  10:04:15  Show Profile  Reply with Quote
TJM--water has a pH of 7, antifreeze undiluted is pH of 10.5. When diluted 50/50 should be about 8.75 which is basic, anything less than 7 would be acidic and that's bad for your cooling system.
Ranger 42 C--WRT the owners manual, I believe mine calls for changing the transmission fluid yearly? I don't know anybody that does that.
Edited by - Gregory S on Nov 20 2017 10:05:47
ranger42c
RO# 32710
Posted - Nov 21 2017 :  06:38:31  Show Profile  Reply with Quote
Yeah, ours does, too... and we do. Always looks clean, but if necessary I can tell the maker that, yes, I change it annually...
Ditto our anti-freeze regime; we do what the manual specifies, including the periodic flush. Ditto mostly 'cause that then shows up in our maintenance logs... if it were to become necessary.
-Chris
Posted - Nov 21 2017 :  10:02:59  Show Profile  Reply with Quote
I'm way out of warranty as I expect you are too, so, my preventive maintenance is based upon what is logical for my systems. That's why I asked the queation in the first place.
ranger42c
RO# 32710
Posted - Nov 23 2017 :  07:06:40  Show Profile  Reply with Quote
Yeah we are, too... A couple dock neighbors have had major engine problems, way past warranty, and were able to get some insurance help... possibly 'cause they could show compliance with manufacturer-recommended maintenance in their logs, I think. Guessing a bit, though...
-Chris
Posted - Nov 23 2017 :  08:51:10  Show Profile  Reply with Quote
yeah, guessing a bit. There doesn't seem to be any rhyme or reason to insurance payoffs.
RO# 28365
Posted - Nov 23 2017 :  10:52:33  Show Profile  Reply with Quote
-Chris
What kind of insurance help? Was it for engine damage due to hitting something in the water or something, running aground, or coverage for general engine failure?
I wouldn’t mind having some additional coverage.
2002 Sea Ray 410 Sundancer
95 Eastern 22'
05 Maxum 18' Bowrider
C6 Corvette Convertible
68 GTO
ranger42c
RO# 32710
Posted - Nov 24 2017 :  08:50:49  Show Profile  Reply with Quote
Sorry, don't really know many details... just that the engine problems weren't from hitting anything, and they were a bit relieved they didn't have to pay the whole tab for a rebuild.
-Chris
Edited by - ranger42c on Nov 24 2017 08:52:02
Posted - Nov 24 2017 :  18:42:41  Show Profile  Reply with Quote
-Chris
Wonder which engines those were, and whether the engines might have damaged by what was not originally engine-related?
ranger42c
RO# 32710
Posted - Nov 25 2017 :  06:18:13  Show Profile  Reply with Quote
Don't know models. One was Volvo something. Two others were Cat.
-Chris
This page took 0.48 seconds to load
