[ Active Members: 5 | Guests: 175 ]  [ Total: 180 ]  [ Newest Member: colrhino ]
 Hose
Author Previous Topic: Kruzin Kool Owners Manual Topic Next Topic: cam and groove
edcourter
RO# 34011
Posted - Jan 01 2018 :  16:41:56  Show Profile  Reply with Quote
Given that a black water tank is polyethylene and drain fittings (DWV) are PVC, why can't you use any properly rated (press/vac) polyethylene or PVC hose for waste transfer?
Posted - Jan 02 2018 :  10:38:11  Show Profile  Reply with Quote
I replaced as much of my flexible hose with PVC pipe, it will never need to be replaced again.
Posted - Jan 02 2018 :  15:59:07  Show Profile  Reply with Quote
yes you can use PVC sewer rated pipe. Flexible hose must also be rated for sewer use. Most hose is not sewer rated. It is not the pressure or vacuum you need be concerned about but the odoe permeability.
