[ Active Members: 1 | Guests: 163 ]  [ Total: 164 ]  [ Newest Member: colrhino ]
 starb engine wont start (2007 Bayliner 325)
Author Previous Topic: Bent Propeller shaft strut Topic Next Topic: MerCruiser 454 Misfiring . Possible head gasket?
griff4
RO# 33534
Posted - Oct 08 2018 :  08:59:32  Show Profile  Reply with Quote
I had a strange sound coming from the starb engine on starting. also noticed the starb starting battery had become pretty low on electrolite. On sea trial, meter showed excessive charging rate. Changed the battery with new then tried to start. This engine is a sb 350 carbed. No alarm, no start, no nothing! I suspect the starter and or the 90 amp fuse are NG. Any thoughts would be appreciated. Thanks, Bruce.
Bayliner 325
Homeport: FL, Gulfcoast
Posted - Oct 08 2018 :  09:08:51  Show Profile  Reply with Quote
No alarm when you turn the key on means no power to it. That is not the starter but some open connection. Turn on the key and use a test light or volt meter sand start at the battery and keep testing for voltage all along the circuit to the key and starter. Dont assume the new battery is good test it at its terminals then the cables as you are looking for a bad connection somewhere. test the fuse the same way.
describe the strange sound.
Edited by - pdecat on Oct 08 2018 09:10:05
Cam
RO# 1558
Posted - Oct 08 2018 :  09:09:51  Show Profile  Reply with Quote
First thing I would do before anything else is to check all electrical connections from the battery. More often than not, there is corrosion keeping the battery from getting a proper charge or not starting at all.
Homeport: Bentley Yacht Club- Staten Island, NY Go to Top of Page
griff4
RO# 33534
Posted - Oct 08 2018 :  16:11:45  Show Profile  Reply with Quote
The strange sound was like the starter and flywheel teeth clashing when releasing the key after startup. I checked and found 12 volts at the large red power line that feeds the starter. Also found the 90 amp fuse assembly that attaches to the starter solenoid to be visibly burnt. I ordered a starter and a 90 amp fuse today. What would cause the unusually high voltage at the instrument volt gauge just prior to the 90 amp fuse burning? Typically, at 3500 rpm my volt gauge reads 11 1/2 volts. Last time the gauge was reading 16 or so volts at 3500 rpm. Both engines are bone stock since new 10 years ago.
Bayliner 325
Homeport: FL, Gulfcoast Go to Top of Page
griff4
RO# 33534
Posted - Oct 10 2018 :  09:18:56  Show Profile  Reply with Quote
Also ordered a new alternator today.
Bayliner 325
cmariner32
RO# 7269
Posted - Oct 10 2018 :  23:18:42  Show Profile  Reply with Quote
And I thought it sucked to be me-welcome to my club!!!!!!!
Posted - Oct 12 2018 :  15:45:01  Show Profile  Reply with Quote
voltage regulator thinks the batt is low, probably from bad connection, so it's sending a full charging rate to the batt.
griff4
RO# 33534
Posted - Oct 23 2018 :  17:01:05  Show Profile  Reply with Quote
Thanks to pdcat, cam, cmariner32, and jtybt15 for technical advice. The alternator must have overcharged and did in the starboard battery and starter. What a job! Wishing the best to all. The boat purrs like a kitten now. Griff.
Bayliner 325
cmariner32
RO# 7269
Posted - Oct 23 2018 :  23:13:43  Show Profile  Reply with Quote
Glad to hear you solved the problem-Congrats!!! Care to share how many stitches it took to close all the wounds?
