[ Active Members: 0 | Guests: 61 ]  [ Total: 61 ]  [ Newest Member: Rleemorris ]
 Regal Owners
 Bilge pump in salon on a 3780-3880
Author Topic Next Topic: Fresh water tank 3780
bodkin creek george
RO# 32828
Posted - Aug 08 2019 :  19:30:13  Show Profile  Reply with Quote
Has anyone installed a bilge pump in the salon area to take care of A/C condensate. If so where did you run the discharge hose?
Thanks George
"All that is necessary for the triumph of evil is for good men to do nothing"
Homeport: Md.
Posted - Aug 08 2019 :  21:07:45  Show Profile  Reply with Quote
My Salon has a bilge pump.
AC Condensate runs into the bilge.
2020 Cobia 280DC
Posted - Aug 08 2019 :  22:29:51  Show Profile  Reply with Quote
Quite a few boats have sump pumps.
Where does your shower water drain to?
Edited by - cwms on Aug 08 2019 22:33:16
bodkin creek george
RO# 32828
Posted - Aug 11 2019 :  20:35:10  Show Profile  Reply with Quote
I have the standard shower drain pump out. What I am looking for is any path some one with
a 3780-3880 has taken for a pump discharge hose.
Homeport: Md. Go to Top of Page
Posted - Aug 11 2019 :  23:10:36  Show Profile  Reply with Quote
AC condensate shouldn’t go in the bilge... it should go to a sump and dumped overboard.
Kellyg
RO# 19800
Posted - Aug 12 2019 :  01:34:35  Show Profile  Reply with Quote
You can either install a sump pump or bilge pump in that area.you have easy access to install a thru hull.
As mentioned in another thread, I installed a condensator tee from Mermaid.
Gary
Mt. Sinai, NY
2001 Regal 3780
2002 Striper 2101DC
Posted - Nov 07 2019 :  09:44:20  Show Profile  Reply with Quote
Can you run a hose from the AC pan to the shower sump? Shower sump boxes usually have a fitting on top for that purpose. AC makes a considerable amount of water on hot, humid days. I wouldn't want that draining to the bilge.
Posted - Nov 07 2019 :  10:24:05  Show Profile  Reply with Quote
Add a sump pump in a drain box. Guaranteed to stink in n the bilge
RO# 25075
Posted - Nov 08 2019 :  05:13:31  Show Profile  Reply with Quote
factory setup on mine had the condensate going into the shower sump, then pumped overboard.
There is an overflow into the bilge in the event the pump fails
PO was lazy and plumbed the AC into the bilge
I restored the factory setup
When I put the boat up after use, simply pop up the teak shower grate and wipe out the remaining water with a sponge, right into the sink or head.
Twin Yanmar 315 Turbodiesels
Solid Glass Hull
Woodless Stringers
Full Hull Liner
Trojan International Website: http://trojanboat.com/
