[ Active Members: 5 | Guests: 203 ]  [ Total: 208 ]  [ Newest Member: Rleemorris ]
 interuptor switch
Author Previous Topic: Fuel injector service Topic Next Topic: Best Way to Clean Holding Tank Probes?  - Resolved
memaw777
RO# 15246
Posted - Sep 08 2019 :  17:48:01  Show Profile  Reply with Quote
1978 mercruiser 260 hp how do I know which interuptor switch I need I understand the old switch needs to be replaced with new shift plate and switch but which one
Posted - Sep 08 2019 :  22:09:33  Show Profile  Reply with Quote
Perhaps this will help ID the part #?:
https://www.sterndrives.com/shiftinteruptorswitchkits.html
alien1952
RO# 32487
Posted - Sep 09 2019 :  10:43:44  Show Profile  Reply with Quote
Are you sure the switch itself is bad? using a meter it will red open, no continuity until depressed, then will read short , continuity
The switch grounds out the ign coil to aid in coming OUT of gear only .To use the new style switch you need to connect 12v to one side of the switch and the other side to the pos side of the coil to interupt the 12 volts
The new one is a normally closed switch vs the normally open old style
aka Bt Doctur
memaw777
RO# 15246
Posted - Sep 09 2019 :  14:46:01  Show Profile  Reply with Quote
I found the old switch probably the only one left in existence. the new one required me to change my trim pump thanks for your help
alien1952
RO# 32487
Posted - Sep 09 2019 :  17:31:12  Show Profile  Reply with Quote
Ah, you must have the older MC1 type
aka Bt Doctur
memaw777
RO# 15246
Posted - Sep 12 2019 :  18:47:40  Show Profile  Reply with Quote
well I installed the new interuptor switch same problem evry time I goto neutral it dies I have made all the adjustments to cables if I try to bend the arm on the switch very slightly then it wont shift to neutral wondering if you guys think it could be a weak coil since the switch interrupts the coil maybe its to weak to come back any thoughts will be appriciated
alien1952
RO# 32487
Posted - Sep 12 2019 :  21:06:46  Show Profile  Reply with Quote
sticky shift cable or corrosion in the shift system
aka Bt Doctur
memaw777
RO# 15246
Posted - Sep 12 2019 :  21:52:46  Show Profile  Reply with Quote
can you lube the cable
alien1952
RO# 32487
Posted - Sep 15 2019 :  12:36:53  Show Profile  Reply with Quote
shift into F and pull the drive to inspect
aka Bt Doctur
memaw777
RO# 15246
Posted - Sep 20 2019 :  15:53:58  Show Profile  Reply with Quote
ok I had the cable replaced everytime I go to neutral it dies any ideas will be appreciated
This page took 0.37 seconds to load
