[ Active Members: 2 | Guests: 187 ]  [ Total: 189 ]  [ Newest Member: Rleemorris ]
 Will I freeze
Author Previous Topic: Starboard volt meter about 1 volt less than port Topic Next Topic: Too Much Fuel Stabilizer?
WALSHIE
RO# 2124
Posted - Nov 08 2019 :  13:58:04  Show Profile  Reply with Quote
Life got in the way of winterizing and usually we are good until Thanksgiving weekend but tonight it is predicted to go down to 20 degrees.
Water system, Air conditioning, head, engines are not winterized....any suggestions or will I be ok?
6pm - 33deg
9pm - 29deg
12am - 27deg
03am - 24deg
06am - 22deg
07am - 20deg
08am - 25deg
09am - 29deg
10am - 33deg
Homeport: Hudson River
Posted - Nov 08 2019 :  14:03:29  Show Profile  Reply with Quote
In the water? What is the forecast for next days? Do you have n electric heater you could hook up? If closed coolant then all that needs draining is the heat exchanger.
Regardless not much sleep tonight.
Edited by - pdecat on Nov 08 2019 14:08:24
WALSHIE
RO# 2124
Posted - Nov 08 2019 :  14:04:16  Show Profile  Reply with Quote
Nope, on land
Posted - Nov 08 2019 :  14:14:54  Show Profile  Reply with Quote
If I was you, I would get to the boat ASAP and winterized everything. Below freezing for that long could cause serious issues.
Posted - Nov 08 2019 :  14:35:13  Show Profile  Reply with Quote
I m obviously no expert with winterizing but what if the temp drops a little early and doesnít get back up quickly enough. Is it worth the risk?
WALSHIE
RO# 2124
Posted - Nov 08 2019 :  14:40:26  Show Profile  Reply with Quote
Thanks guys, left work, on train, will take care of as much as I can. Then pray.
I cant believe it got so cold so quick. Ugh!!
alk
RO# 5508
Posted - Nov 08 2019 :  14:51:35  Show Profile  Reply with Quote
it's harder to find light bulbs that give off a lot of heat these days, but in the past when I've been caught unprepared on a cold night, I filled the engine room ( and anywhere else at risk) with a bunch of shop lights, and left them on all night. That's worked for me, but never tried it with temps going down to 20 - generally used when forecast is right around freezing. And generally that only works if the boat is sitting in your own driveway / yard. Marinas, around here at least, don't like the fire risk of people using electricity to heat their boats sitting on blocks - so most of them walk around and unplug everyone at the end of the day, or just shut the power off.
hopefully you will at least be able to get the motors and air conditioners taken care of today.
Edited by - alk on Nov 08 2019 16:42:42
Bob J
RO# 181
Posted - Nov 08 2019 :  15:16:17  Show Profile  Reply with Quote
Last year I bought 250W INFARED HEAT LAMPS at ACE Hardware. Bought for fridge I keep in unheated garage. Compressors don't like temps below freezing. I leave them on 24/7.
Bob J
Edited by - Bob J on Nov 08 2019 15:17:12
Posted - Nov 08 2019 :  16:04:52  Show Profile  Reply with Quote
If it was me I would worry, but with that said, it takes quite a few days of freezing weather before you may have a problem.
Posted - Nov 08 2019 :  17:12:55  Show Profile  Reply with Quote
+1 Walt. My experience is that it takes a couple of days at a hard freeze. This was also related to me by the manager at a very large boat yard in Connecticut. It is certainly better to be in the water.
RO# 28365
Posted - Nov 08 2019 :  19:09:27  Show Profile  Reply with Quote
If you can get to anything tonight I would get to the motors and generator first.
Everything else can wait if you set the cabin up.
I donít have anything winterized yet either, but Iím still in the water so my motors and generator arenít an issue.
I left the heat on in the cabin with cabinets doors open. I donít usually come out until a couple of days before Thanksgiving and have endured one or two early freezes a couple of times with no problems by just running heat in the cabin.
If you can set up a few space heaters in the cabin your water and head systems should be fine.
If the seacock is open for your AC then itís likely that most of the water in it has drained out.
2002 Sea Ray 410 Sundancer
95 Eastern 22'
05 Maxum 18' Bowrider
C6 Corvette Convertible
68 GTO
Edited by - JVM225 on Nov 08 2019 19:16:08
WALSHIE
RO# 2124
Posted - Nov 08 2019 :  22:52:36  Show Profile  Reply with Quote
Thanks guys
All done. Had some issues but pushed through them.
Ready for wrap ... and a good night's sleep!
RO# 28365
Posted - Nov 09 2019 :  08:59:16  Show Profile  Reply with Quote
Originally posted by WALSHIE
Thanks guys
Nice!
I hold off as long as possible so I get a good spot and can get back in about April 1st.
The downside is freezing my butt off getting her ready to in to hibernation.
But itís worth it.
Iím taking a last ride to a pumpout Dock today and hoping to get a good jump on oil changes and winterizing, generator, waste and freshwater systems this weekend.
Calling for a fuel delivery to top off the tanks this week.
Last ride will be a short one over to the boatyard for haul out.
Once sheís out and blocked, all I have to do is run antifreeze through the motors and AC units.
95 Eastern 22'
68 GTO
