Author |
bannditt
RO# 24074
Posted - Nov 17 2019 : 06:01:00
GM,and i hope we all enjoyed the season!i seem to have some water in my oil,i constantly check it and i believe the problem happened in the last 2 weeks(the weather took a nose dive last week 30's)i have a 1999 volvo penta 5.0Gipwtr 300 hrs, new manifolds and elbows in 2016(used 4 seasons 120 hrs)raw salt water cooled(fresh water flush out) yesyerday i did 2 oil changes to avoid engine damage, oil came out darker every time(only 5 quarts came out,not alot of water in there)first oil change i ran it and fog the hell out of it,second i didnt start it up).boat is very well maintained and always runs like a champ,i read that after 5 years manifolds have a 50% chance of failure,looks like i need new manifolds and elbows?anything else i can do to prevent engine damage?how else can water get in oil(i am the 2 nd owner,boat always runs at 160,never past 4000 rpm,tbi,no codes in ECM,oil usually comes out like new when changing) ty for your help,Pete
Homeport: ny
RO# 2620
Posted - Nov 17 2019 : 08:17:40
oil/transmission cooler is also a frequent cause.
Homeport: Norfolk, Va
Stephen
RO# 14
Posted - Nov 17 2019 : 08:24:09
I would complete more diagnosis before buying new manifolds. A compression test will help determine if the head gaskets have failed or if there is something more sinister going on.
Homeport: Matts Landing, NJ
RO# 28365
Posted - Nov 17 2019 : 13:23:30
If you suspect the manifolds and water getting in to the cylinders then it’s best to not try to start it. Water doesn’t compress. Pull the plugs before turning the motors so the water has somewhere to escape to.
2002 Sea Ray 410 Sundancer 95 Eastern 22' 05 Maxum 18' Bowrider C6 Corvette Convertible 68 GTO
Homeport: Farmingdale NY
bannditt
RO# 24074
Posted - Nov 18 2019 : 07:32:45
thanks for you reply,the reason i think its the manifold/risers is that the boat runs and idle fine,a blown or defective head gasket or intake manifold should make a rough idle,or at least leave a code in the ECM.oil cooler is a maybe,i can pull it off and take a look.what should it look like?i removed the manifolds and filled the water passages with water,the water level seems to be holding,is that a true test?(4 years old salt water cooled)btw is it normal to see rust in the exhaust manifold ports (on the manifold,part # barr omc 1-914035)ty Pete
Homeport: ny
RO# 2620
Posted - Nov 18 2019 : 08:18:10
To test the oil cooler, you'd have to come up with a way to pressurize it. Regardless, you need to do a compression check when you're sure the water is out.
pstew96
RO# 12527
Posted - Nov 18 2019 : 09:29:38
You need to talk to Tony me thinks....lol
Homeport: Babylon,NY
RO# 28365
Posted - Nov 18 2019 : 12:41:24
Pull the plugs and see what they look like, Search google for an image of a healthy spark plug from an engine that is running well and compare to yours. It’s good that the motor will idle but don’t run it anymore until you figure out what’s wrong with it. The milkshake (water/oil mix) is not good for the running motor under any circumstances. Since you’re taking the cooler off, see if there is a local radiator shop that can check it for you. Re: your manifolds. If you see rust in 4 year old Barr manifolds you should seriously consider replacing them regardless if they are the root of your present problem. I’ve got no knowledge of OMC because I’ve only had Mercruiser, but if there is an OEM replacement option for your manifolds I would go for them instead of Barr if at all possible.
Edited by - JVM225 on Nov 18 2019 12:48:23 |
bannditt
RO# 24074
Posted - Nov 18 2019 : 16:11:53
jvm225 , thanks, basic power marine, has a manifold/riser kit for under 750.00,barr, made in usa,. half price of volvo penta lol and i would still think 5 years at the best either way,two weeks ago i put in bad or too much fuel stabilizer the boat was stalling and not starting,(smell it right away in exhaust)i put in new plugs,cap,rotor,fuel filter and 30 gallons of 93 octane fuel and its fine,i had 120 hours on the old plugs and they we foul beyond recognition!after the tune up started right up and was fine 2 weeks later when winterizing water in oil.yes i have rust in exhaust ports in manifolds,,,,,should i still do compression test?ty pete
Homeport: ny
LouC
RO# 10314
Posted - Nov 18 2019 : 17:03:50
There is nothing at all wrong with Barr aftermarket manifolds, where you can get a leak is the gasket between the manifold and the elbow, this is a known weakness in both this and the previous gen Mercruiser wet exhaust joint, even if the manifolds and elbows have not rusted through you can have a leak there. For one thing in salt water there is no way you will not find rust in a manifold or elbow used for 4 years. Anytime you find water in the oil the first thing you should do is remove the spark plugs, disable the ignition system and crank the engine over; if you get water shooting out of any of the cyls it could be the exhaust but it also could be a blown head gasket or cracked head. So if you do get water then, checking the exhaust is a good first step. If it does not leak then you have to move on to other sources. If you got no water out of the cyls but you have water in the oil, then you can also have a leaky intake gasket (would put water in a cyl and oil) or the area right under the thermostat housing in the intake (water passage between the 2 cyl heads) can rot out and this will put water right into the cam valley (this would put water in the oil but not cyls).
If your exhaust does not leak, but you have water in the oil, I'd do a compression test, this may tell you if you have a leaky head gasket, and then drain the cooling system and pressurize it with air. If it does not hold pressure, then its leaking somewhere the challenge is to find where. I had water in the oil and in 2 cyls a few years ago. I tested the exhaust and it was not from that. While comp test was close to normal, checking for air bubbles in the cooling water revealed that combustion gas was getting into the cooling water, which means there is a breach in the head gasket and/or cracked cyl head. I took it apart and found both head gaskets blown right next to a water passage. I had the heads checked out and both had cracks from a previous overheat. I wound up buying a set of reman heads because the block was still good and putting it all back together with new (Barr) exhaust. The challenge here is in your diagnostics and you really want the water out as soon as possible, changing oil as often as needed to prevent cyl wall rusting and damage to bearings.
A quick test for exhaust gas getting into the cooling water is to replace the manifold feed hoses with clear plastic hose. Run the engine on the water hose till it warms up enough to open the thermostat. Once the 'stat opens, water will flow out of the block into the manifolds, if this water is aireated, than you may have either a blown HG or cracked head.
some pix of the teardown and re-assembly, last one is a vid of it up and running....
https://www.dropbox.com/s/tr23hyy6srwfnqv/4.3%20manifold%20removal.JPG?dl=0
https://www.dropbox.com/s/k18krrafa34899f/4.3%20cleaned%20up%20block.JPG?dl=0
https://www.dropbox.com/s/8fhnjbtutfjejkm/4.3%20reman%20cyl%20head%202.JPG?dl=0
https://www.dropbox.com/s/1yyytu26xgohers/installed%20reman%20cyl%20heads.JPG?dl=0
https://www.dropbox.com/s/55j6h4dd1u8fv0k/top%20end%20rebuild%204.3%20test%20run.MOV?dl=0
1988 Four Winns 200 Horizon 4.3 OMC Cobra 1998 Jeep Grand Cherokee 4.0 Selectrac 2007 Jeep Grand Cherokee 5.7 Hemi Quadradrive II |
Edited by - LouC on Nov 18 2019 17:15:14 |
Homeport: Long Island NY
bannditt
RO# 24074
Posted - Nov 19 2019 : 07:02:58
thank you louc,after the compression test ,should i spray wd 40 in cylinder? new manifolds and risers are on the way.
Homeport: ny
LouC
RO# 10314
Posted - Nov 19 2019 : 14:22:59
I like fogging oil, it is made for that purpose. Did you verify that your old exhaust was leaking? Pay particular attention to the sealing surfaces of the manifolds and elbows, put a straight edge across them and make sure they are really flat. I used Permatex Aviation Sealer on the Barr gaskets for the manifold to elbow joint and had no leaks. For the manifold to the head, that gasket goes on dry.
There's a trick for making it easier to line up new manifolds, use a longer bolt, same thread, cut off the head, cut a slot in the end to make it easy to remove, you thread in 2 of these to keep the gasket and manifolds lined up, then install the rest of the bolts, finally remove the 2 headless bolts with a screwdriver and install the last 2 regular bolts. https://www.dropbox.com/s/xduba114xng7ecp/Exhaust%20install%20wiht%20headless%20bolts%20to%20line%20it%20all%20up.JPG?dl=0
Edited by - LouC on Nov 19 2019 14:23:53 |
bannditt
RO# 24074
Posted - Nov 19 2019 : 16:05:19
ok,did a compression test today,cylinders 1,3,5 70 psi,cyl.7 90 psi,cyl.2 80 psi,cyl.4 90 psi,cyl.6 80 psi. cylinder 8 had so much fuel spitting out i could not get a reading(240psi)i tried plugging a line by the fuel filter,and empty the filter,but it didnt help,i removed all plugs and cranked the motor to clear the cylinders,no sign of rv anti freeze,oil looks much better,i will research how to cut the fuel(tbi)or plug the 2 lines going into the throttle body.any idea why so much fuel out #8 cylinder?i know compression is low but consistent and it is a year old engine
Homeport: ny
bannditt
RO# 24074
Posted - Nov 19 2019 : 17:01:09
btw when i did the compression test,plugs were in,throttle was closed,ignition disabled
Homeport: ny
bannditt
RO# 24074
Posted - Nov 19 2019 : 20:19:36
permatex aviation form a gasket?item 80019?great tip on the manifolds!!
Homeport: ny
RO# 1159
Posted - Nov 19 2019 : 23:21:27
Throttle should be wide open. Even better is with warmed engine but that can be painful.
You said the crank oil was contaminated with water, but also said cyl. # 8 was pushing out a lot of gas.
Just asking: Could the oil really have been diluted with gas , not water? ( As in possibly leaking mechanical fuel pump diaphragm pushing flow-by gas into the carb's j-valve?) I'd think you would notice the difference but the report of #8 made me wonder.
Sandy |
Homeport: The Vineyard
bannditt
RO# 24074
Posted - Nov 20 2019 : 07:54:49
hey sandy thanks for your reply,i dont have a carb.TBI system ,there looks like only one gas feed to filter,to low pressure pump to the fuel cell to the high pressure pump and into the throttle body,in still have the old oil,i can take a wiff.what do you think about the low compression?to you think a warm engine and open throttle body will increase PSI?the engine is 21 years old!i have the manifold off and i see a lot of fluid shooting out the #8 exhaust port on the head,gonna try to get a sample of it,995 sure its gas as it fills up the comp.tester
Homeport: ny
LouC
RO# 10314
Posted - Nov 20 2019 : 09:48:58
Ideally you would want to do the comp test on a warm engine, throttle plate wide open, ignition disabled. But those readings are very low. It is possible you had a leaking injector causing the engine to run very rich and diluted the oil. I'd try to get it running if possible to do a warm comp test. Then if you get low readings still, squirt motor oil in each cyl on by one and repeat. If results improve, bad rings if not bad valves. You can also do a cyl leak down test which is more thorough. I had better comp test results on my old engine even when it blew both H/Gs! After the rebuild all cyls were from 160-175.
bannditt
RO# 24074
Posted - Nov 20 2019 : 17:39:39
hey thanks for your reply,i did the compression test over today correctly all cylinders were between 110 and 120 psi which for a 21 year old motor aint bad( however could not heat up the motor as manifolds and risers are off,i did notice rv anti freeze shooting out the # 8 exhaust port of the head,(very little)intake manifold gasket bad?
Homeport: ny
bannditt
RO# 24074
Posted - Nov 21 2019 : 16:33:19
cranked the motor over and no more fluid out of #8 exhaust port on the head.
Homeport: ny
RO# 1159
Posted - Nov 21 2019 : 16:51:44
With the better comp test results , signs are pointing more toward riser to manifold leak traveling into the #8 exhaust port.
Sandy |
bannditt
RO# 24074
Posted - Nov 22 2019 : 08:48:36
hey sandy thanks so much for reply,(riser to exhaust manifold leak)i was thinking the same,but i never had the exhaust manifolds and risers on the boat with RV antifreeze in the motor,i pulled manifold and risers right away for inspection and crank the motor no pugs in to be sure to clear the cylinders(and had put fresh oil in twice)i can gravity fill the motor again and crank it to see if rv anti freeze shows up.would that indiciate intake manifold gasket?(with a crank only).or just bolt on the new manifolds start her up and see what happens?
Homeport: ny
LouC
RO# 10314
Posted - Nov 22 2019 : 10:31:42
The thing is, the intake gasket water passage is way up front and a water leak there, would be more likely to show up in one of the front cyls, either #1 or #2, however it is possible because, Chevy small block heads are the same casting for each side. So the intake gasket has the same square sealing surface for the very front end and rear end of the gasket. The front ports are open so the hot water flows up and out of the heads into the intake manifold water passage and then out through the thermostat (when open) and finally out through the exhaust system. The rear ports are sealed by the gasket and the rear part of the intake. If the rear part of the intake gasket leaks, it is possible for water to get into one of the rear cyls. If that's your problem, then the solution is relatively easy, remove the intake (after removing the carb, distributor etc) and carefully check the sealing surface of the heads and intake. If this is a Vortec engine (8 bolts on the intake, pre-Vortec uses 12) the torque on these intake bolts is very low compared to the old pre-Vortecs, its like 10 ft lbs. On the early Vortec engines I hear that intake gasket leaks were common. If this turns out to be the case, I'd recommend a set of FelPro marine intake gaskets, and carefully clean the bolts for the intake manifold, and the threads in the cyl heads, so you get proper torque. Note that when removing the intake you should set the engine at TDC of the #1 spark plug with the dist rotor pointing at #1, before removing the dist to remove the intake. Otherwise it may be tough to get the dist back in the correct position.
Keep in mind in my engine I had both HGs blown, the engine had normal comp test results, but the way they were blown I was not losing compression, it was allowing water in a cyl as the engine cooled off. So you might have that problem instead of the intake issue. Only way to know, is to put your new exhaust on, and run the engine to check for air in the cooling water. If you get bubbles (replace your manifold feed hoses with clear hose, then run it till the stat opens up and look at the water in those hoses) then its a H/G or cracked head. If not that's great, probably just the intake gasket. Removing the heads is not difficult, I did it on a raw water cooled engine that was used in salt for 15+ years, I used a De Walt 1/2" drive electric impact gun and did not break even one bolt! The intake on mine was hard to get off due to the intake gaskets being baked on, but the heads came off easy. I would strongly recommend doing the air in your cooling water test first. Intake gasket leaks are more likely to put water in the oil and not they cyls while head gasket leaks can put it in both the oil and a cyl. The reason why is that if a fire ring on the H/G leaks, it is right next to the cyl water passage whereas the intake port, is not that close to the water passage on both ends of the cyl head....when an intake gasket leaks the water will run down the head right into the cam valley right into the oil....
https://www.dropbox.com/s/2pu8ac8x71e5u93/4.3%20starboard%20cyl%20head%20removal.JPG?dl=0
Edited by - LouC on Nov 22 2019 10:48:59 |
RO# 1159
Posted - Nov 22 2019 : 23:41:33
Nice post Lou. Very informative as always! T/Y
Sandy |
LouC
RO# 10314
Posted - Nov 23 2019 : 16:01:05
Thanks, its amazing what you can learn, by taking an engine apart! This job took me a few months because I had never done it before and had to get advice from a few different people (mechanic, machinist at a local hot rod/machine shop). What's good about these old school engines is that they are easy to take apart, the all cast iron construction is very rugged, not as likely to strip threads or break bolts and the parts are really inexpensive compared to outboards.
Edited by - LouC on Nov 23 2019 16:02:20 |
bannditt
RO# 24074
Posted - Nov 24 2019 : 08:00:55
hey LouC thanks for the info,upon careful inspection of manifold,i notice #8 port on manifold very rusty (other ports mostly just black) and it looks like the riser gasket on same might have failed,(hard to be sure)bubble test sounds like a great ,the clear hosed go from thermostat housing to exhaust manifold and look for bubbles there?(the hose should be solid water and no air at all?)BTW i see you are in Long Island/farmingdale?i'm in staten island.
Homeport: ny
LouC
RO# 10314
Posted - Nov 24 2019 : 12:43:22
Yes the water flow from the thermostat housing to the manifolds should not be aireated but you have to wait till the thermostat starts to open up, which can take a while idling on the water hose on a cold day. Get an IR temp gun and read the temp of the hoses from the stat housing, they will be cold at first but then start to warm up when the stat opens to let hot water out of the intake manifold. When the engine is cold, the incoming water from the impeller will just go out the exhaust. If you see air bubbles then, your impeller housing or hoses can be sucking in air and that will skew results. So with a cold engine, good fitting muffs on lower unit, there should be no air in that water flow. Then when the hoses to the manifolds start to get warmer (that is a sign of the stat opening and letting hot water out of the engine) you should still not see air bubbles, if so, that's a sign of blown HGs, or a cracked head or block. If you get bubbles with a cold engine though, the test will not be meaningful.
LouC
RO# 10314
Posted - Nov 24 2019 : 12:46:36
PS those riser gaskets are problematical. This is why Merc went to the dry joint system which is a better system for avoiding leaks at the gasket, although the parts do cost a good bit more. So, when you install your new exhaust carefully follow the instructions for those manifold to elbow gaskets. I used the Barr ones on mine, coated both sides with Permatex aviation sealer, torqued to 25-30 lbs, warmed up the engine and then retorqued. So far (2 years later) no leaks. I'm on the North Shore of LI, near LI Sound.
LouC
RO# 10314
Posted - Nov 24 2019 : 13:11:21
If you google "Volvo Penta Gas Engine Overheat Diagnosis" you will find a publication where VP explains how to troubleshoot overheating. One of the tests is to find out if there is air in the water flow from the impeller but they also cover air getting into the flow from the thermostat housing and how to test further if its a cyl head gasket leak or cracked head. I read through this and then came up with my own test for HG leaks, you have to do it fast because you don't have water flow to the exhaust manifolds but if you watch the vid to the end, you can clearly see bubbles in the water in the funnel on the port side and some on the starboard side. Took it apart and sure enough both HGs blown.
https://www.dropbox.com/s/ur4ny75jwrtd1to/OMC%204.3-5.0-5.7%20thermo%20housing.jpg?dl=0 this pic shows the flow through the stat housing....
https://www.dropbox.com/s/8lz4p4e7pdrtqr2/testing%20for%20blown%20head%20gaskets.MOV?dl=0 this is my dynamic test (engine running) to test for blown head gaskets...watch to the very end....I had removed the stat to make it easier to see air bubbles in the water flow.
So what was happening was...I'd run the motor, Let it cool, then take plugs out and crank it over to check for water. Did not get water at first....till engine cooled all the way down....then next day there was water in cyl #2 and just a mist of water in cyl #1. So what was happening was the HG leak, was becoming apparent as the engine cooled off. It would run, not overheat and had close to normal comp test results but had water in the oil and those 2 front cyls. Eventually I had sticking valves due to the water and corrosion. However, taking it apart revealed very little corrosion on the valve train, heads, pushrods etc. Cam and lifters looked like new. I used Merc's 25/40 marine oil maybe that helped.
Edited by - LouC on Nov 24 2019 13:19:09 |
bannditt
RO# 24074
Posted - Nov 26 2019 : 18:31:15
i started the boat up today with new exhaust manifolds and elbows,started right up, idle fine,very little sign of water, i changed the oil and filter again and ran it again(10 minutes) no sign of water in oil.i will run it next couple of days and see what happens.
Homeport: ny
LouC
RO# 10314
Posted - Nov 26 2019 : 20:17:21
Good deal you may have gotten lucky! Just keep an eye on those manifold to elbow gaskets....
bannditt
RO# 24074
Posted - Nov 29 2019 : 07:48:18
thanks again LouC, yea, its still looking good,going to do one more oil change before i winterize the boat,i coated the elbow gaskets with permatex as you said all though vendor(ebasic said not too ???)in the past i have used the starboard side elbow as a step stool when climbing out of engine compartment(for years) i am thinking that was a real bad idea with an old gasket and 18 ft lbs of torque(may have caused my problem!after heating and re torque the bolts i would say average 1/3 to 1-4 turn more(seem normal?)BTW i bought a brand new torque wrench for the job)happy holidays to you and your family,Pete
Homeport: ny
LouC
RO# 10314
Posted - Nov 29 2019 : 11:21:28
Sounds good, I used the Permatex based on advice from a tech guy from Barr Marine. I retorqued the bolts once after warming up the engine and that was 2 years ago all good since. My engine (1988) originally had the OMC one piece batwing exhaust manifolds (you can see em in my last vid above) and I had changed them 3 times over 15+ years of salt water use. Being one piece, they never leaked water into a cyl. But as with a lot of older stuff they became No Longer Available so I had to convert over to the 2 piece exhaust used on later OMCs and Volvos.
interesting about stepping on the starboard exhaust elbow and your leak was at cyl #8 which is the last one on the starboard side. like I said Volvo knew there were issues with those gaskets and they revised them several times. The new style Volvo OE elbow gaskets do not need sealer but its a good idea I think to use them on the Barr ones. They are different types of gaskets.
PS I don't know what the forecast low temps are where you live (Staten Island right) but here it will be cold enough that until you can winterize it fully I'd drain the block and manifolds.
Edited by - LouC on Nov 29 2019 11:24:14 |
LouC
RO# 10314
Posted - Nov 29 2019 : 11:45:02
Hey Lou, Thanks for contacting us. If you are using our gaskets (not the carbon type usually supplied by Volvo-otherwise follow their specs) I usually recommend using a Permatex “Form A Gasket” that can be purchased from any automotive parts supply house. I use this on the riser mating surface and put a little on the threads of the bolts. I take a sharp putty knife and scrape the paint off the riser surfaces and clean up with a “Scotch Brite” pad with lacquer thinner or rubbing alcohol. Place the riser gaskets on cardboard, brush on the sealant and bolt the risers tight. I don’t use a torque wrench but I would say somewhere between 36-38 Lb-Ft. I re-torque after the first warm-up and after the first 10 hours or so (obviously if there are no leaks at the gasket during the process). I hope this helps. Please feel free to call me if you have any questions or concerns. Thanks, David
PS I found this e-mail from the tech guy at Barr from 2 years ago.....
bannditt
RO# 24074
Posted - Nov 30 2019 : 08:09:20
yea,ty,cold here at night! i have filled the engine with RV fluid twice already$, as temps dip into 20's,or had a heater in the engine compartment$,no water in oil filter yesterday,oil seems clear,i have the old oil in jars, dated, for inspection, and its looking good,3rd oil change in yesterday(always use mobile 1 full synthetic 20w-50)fram oil filter 3.99, volvo penta filter 9.99,do you think there is a difference?(besides the size of the filter?)i have on board oil changer pump installed so its easy to do oil changes. i bought a set of volvo penta spark plugs 3.99 each, the box said volvo penta, when i opened the a box it was a champion rs12yc,which sells for 2.00 each anywhere!
Homeport: ny
LouC
RO# 10314
Posted - Nov 30 2019 : 12:12:56
The 20/50 Mobil 1 is fine, as far as oil filters I use either the Merc/Quicksilver or the Sierra Marine filters, Fram does not have a good rep but that might be old information at this point. For oil I use the Merc/Quicksilver 25/40, I think it has superior corrosion resistance and to prove it, take a look at the pic of my engine with the intake removed. You can see there is no corrosion in the cam valley, on the heads, or pushrods and that engine had salt water in it for over a week before I figured out what was wrong with it. When I took it all apart I was amazed that the cam, lifters, pushrods and rocker arms all looked like new. No rust, etc. Spark plugs I like the AC delco MR43 or MR44, for the older non vortec engines, if you have a Vortec, (8 bolts on the intake, non Vortec has 12) the plugs are different. AC Delco plugs have superior corrosion resistance in salt water use, at least in my experience.
So your main thing now is keep an eye on those elbow gaskets. Here's a tip, what I do at the end of the season is I fog the engine. To not foul my new plugs, I put in a set of old plugs just to fog it. When you take the plugs out, check for water ingestion. If you catch it then, instead of it sitting over the winter like that, you save having to pull the cyl heads off, or worse, putting in a new or reman long block! One extra step that can save a lot of cash!
Keep up the good work!
bannditt
RO# 24074
Posted - Dec 01 2019 : 17:53:20
ty LouC,when you winterize do you leave the block drained or fill with RV antifreeze,do you gravity feed the block with antifreeze or use muffs?how long do you keep batteries i have 2 1000 mca,6 years old they load test at 500 mca ,the rs12yc is the volvo penta factory plug so thats what i used,last set had 120 hrs on them,boat is covered and put away for the winter in the spring i will start her up do an oil change,fresh plugs,if we get a warmer day maybe i'll pull the plugs just to take a look,shoot some fogging oil in the nmotor
Homeport: ny
Bob J
RO# 181
Posted - Dec 01 2019 : 18:13:17
bannditt; just my 2 cents. I was always told to store boat for winter with fresh oil. Always did it that way on 3 boats since '76. Just getting that old acid ladden oil out of engine. Worked for me !
Bob J |
Homeport: Waretown, NJ
LouC
RO# 10314
Posted - Dec 02 2019 : 09:42:20
I have always changed the oil when I winterize it. As far as draining, I manually drain poke all the drain holes and then manually fill with either -100 (-45 freeze protection) Marine AF (if I'm too lazy to mix up my own) or, I mix up 4 gallons of Sierra PG antifreeze 50/50 with water, that gives a -26 freeze protection (plenty good for our winters). I do not use either the -50 or -60 since they get hard (but don't expand) at between +7 and zero. Even West Marine in their recommendations, advises that -50 and -60 are for winters where it doesn't get colder than 20 degrees. I don't want an antifreeze that will get hard in a cast iron block, even if it does not expand. This point is not well understood by do it yourselfers. I do think that adding antifreeze with corrosion inhibitors helps reduce corrosion, just like spraying trailer leaf springs with Corrosion X does, but you need to use the right stuff for your climate. Remember you DRAIN For freeze protection and add A/F for corrosion protection. The way I do it is:
Put the drive down, start engine on the muffs. Warm it up, change oil and filter. Then remove the plugs, disable ignition briefly crank over engine, check for water in cyls. If none put in old plugs, run engine again and fog through carb if a carbed engine. If not follow manufacturer's instructions for fogging mix in fuel filter or remote tank.
Once fogged, let it cool off. Then remove: 2 block plugs, poke holes, 2 manifold plugs, same, let it drain. After draining, replace plugs, put some Permatex Aviation sealer on the threads (prevents corrosion and leaks) Then disconnect: big hose from thermo housing at bottom, this lets water drain from front circ pump, and raw water intake hose at thermo housing (Alpha, Cobra) or impeller housing (Bravo, Volvo). Hold it down in the bilge, to drain, then hold it up and fill it with AF till it runs out the drive water intakes. Reconnect both hoses. Then disconnect big hose at thermo housing, fill it with 2 gallons and a bit more of AF that will fill engine, till you see some AF spurt out the housing neck. Then reconnect upper end of that hose. The next day will change the drive oil check for water in the oil. Pull drive for winter storage check bellows for water, grease gimble bearing and u joints.
Batteries, I usually use em till they won't take a full charge, I have a battery capacity tester now, and they do come back to their rated capacity, one batt is 5 years old the other is 7. In spring I'll test them again, if not good I will replace both. Also going to replace the old heavy direct drive starter with an ARCO PMGR starter, they draw less current and spin the engine faster.
In spring after the first start up, I take out the plugs used to fog it, check for water in the cyls and put in my newly cleaned plugs. Grease steering, drive shift linkage and re-install the drive. I usually get 10 years out of the Cobra style bellows. The I/O is a good bit of maintenance but it is simple for the most part, engines are simpler than outboards by far.
bannditt
RO# 24074
Posted - Dec 03 2019 : 07:10:38
hey LOU C,ty, you use battery load tester, and after 5 - 7 years they are still at full charge?what brand batteries? i have 2 west marine 1000 mca after 6 seasons they are at 500 mca on the load tester,i always keep the switch on both when using boat.i dont leave them in the boat over the winter and charge when needed.auto zone sells marine batteries dirt cheap a 900 mca about 100 bucks but i know there not the best.
Homeport: ny
LouC
RO# 10314
Posted - Dec 03 2019 : 07:57:30
Deka Marine Master group 27 dual purpose batteries. If you are using starting batteries, the dual purpose batteries which are kind of a hybrid between a starting and a true deep cycle hold up better than starting batteries to loads like bilge pumps, etc. When you use the boat you can leave it on both but if you leave the boat after using with the switch on both, the weaker batt will pull current out of the stronger one. You MIGHT get better results by doing this, just alternate battery use by trip, because that way your alt only has to re-charge one battery at a time, otherwise it has to charge both simultaneously. I have always run the boat this way, I leave it on the one I used (have to leave batt switch on when its on the mooring because of how the bilge pump was wired from the factory) for that trip. Then when I use the boat next time, flip the switch to the other batt. Maybe that's what made them last as long as they have. I leave mine in the boat over the winter and charge em when I close it up, then on a nice crisp winter day when its sunny I open up the cover and charge em up.
what is your charging voltage when running, it should be approx. 14.2 V....
https://www.dropbox.com/s/25070o8154sswaq/%2788%20FW%20instrument%20panel.jpg?dl=0
but check at the batt with a digital voltmeter more accurate than the dash gauge...
I'm using this battery capacity tester with a Schumacher smart charger...this is a spare batt for my '07 Jeep:
https://www.dropbox.com/s/g8aimr1zge76yj4/battery%20capacity%20tester.MOV?dl=0
Edited by - LouC on Dec 03 2019 08:03:09 |
BoaterEd |
© BoaterEd |
