[ Active Members: 0 | Guests: 294 ]  [ Total: 294 ]  [ Newest Member: GrecRI2 ]
 Trim tab motor
Author Topic Next Topic: Surveyor
harmsway
RO# 32263
Posted - Sep 07 2020 :  22:22:06  Show Profile  Reply with Quote
I was told ai need a new trim tab motor. Where is it and how much does it cost?
Homeport: Amtiy Harbor, NY
zane
RO# 19940
Posted - Sep 09 2020 :  19:13:04  Show Profile  Reply with Quote
You donít say what kind of boat or motor you have but itís fairly easy to find and replace. Itís gonna be in your engine compartment close to the transom. Small electric motor with the reservoir underneath. Usually with 2 hoses and 3 wire coming off of it. Not a hard fix at all
jpowell
RO# 15168
Posted - Sep 09 2020 :  19:24:29  Show Profile  Reply with Quote
RIP Tabman, Tom would always jump in on a post like this.
Jay Powell
Sailfish 245DC
"Less Cha-Ching"
Homeport: Stevensville, MD Go to Top of Page
harmsway
RO# 32263
Posted - Sep 09 2020 :  20:26:56  Show Profile  Reply with Quote
Thank you for your respnse. I have a 370 aft motoryacht with 454 Crusaders.
Homeport: Amtiy Harbor, NY Go to Top of Page
zane
RO# 19940
Posted - Sep 10 2020 :  08:18:01  Show Profile  Reply with Quote
Most likely a Bennett and they havenít really changed in years. They call it Hydraulic Power Unit. https://bennetttrimtabs.com/products/
In a boat like yours it can be plumbed further from transom. Itís probably under one of your aft hatches mounted to a bulkhead just out of reach! I donít know how handy you are but you can disconnect the unit from wiring harness, usually all plugs, and run jumper wires and wire it directly from battery to test it.There are articles on web that I followed in past to do it. Iíll search around later. Make sure itís the motor and not switch or relay module. I once had a bad relay module. Motor only worked in one direction. If you do remove unit have a container underneath to catch fluid and have plugs or something ready to plug up hose ends right away. Otherwise youíll have a mess in the bilge.
zane
RO# 19940
Posted - Sep 10 2020 :  08:26:00  Show Profile  Reply with Quote
https://www.bing.com/videos/search?q=testing+bennett+trim+tab+motor&&view=detail&mid=4A23DCBEFB528B8334384A23DCBEFB528B833438&&FORM=VRDGAR&ru=%2Fvideos%2Fsearch%3Fq%3Dtesting%2Bbennett%2Btrim%2Btab%2Bmotor%26%26FORM%3DVDVVXX
harmsway
RO# 32263
Posted - Sep 13 2020 :  16:34:00  Show Profile  Reply with Quote
Already replaced. Thank you for your responses.
