[ Active Members: 6 | Guests: 155 ]  [ Total: 161 ]  [ Newest Member: Steve717 ]
 Winterizing & Springizing
 Winterizing boat A/C
Author Topic Next Topic: Engine Freeze?
ddurand
RO# 5015
Posted - Nov 13 2020 :  21:19:16  Show Profile  Reply with Quote
Can I winterize a boats A/C with air vs antifreeze? I have a Ryobi cordless combo tire inflator and air inflator for air beds or similar things to be inflated.
I was thinking to use the air from the air inflator to blow out the seawater. It's high volume low pressure. It needs to blow air past the A/C water pump that won't be running.
Homeport: Hyde Park, NY
Posted - Nov 13 2020 :  23:23:09  Show Profile  Reply with Quote
I have a problem winterizing by just eliminating water. Everything is still wet and put air in there and you promote a lot of rust. Replacing that water with rust inhibited antifreeze is the only way to go.
Posted - Nov 14 2020 :  07:51:40  Show Profile  Reply with Quote
I was up in Kingston NY at RYB. I used air exclusively for the whole boat. Two ACs, icemaker, water system. The only AF I used was in the engines, the toilets and sink drains. However, I used a compressor set to about 40 PSI so I had plenty of air coming from the small tank. I applied short bursts, then allowed the compressor to catch up to the tank (the compressor stopped at almost 200psi I think).
ddurand
RO# 5015
Posted - Nov 14 2020 :  09:06:35  Show Profile  Reply with Quote
Is it necessary to run the A/C to fill it with antifreeze? If I hold a container of antifreeze up high connected to the A/C intake will that cause the system to fill with antifreeze by gravity?
Posted - Nov 14 2020 :  09:11:02  Show Profile  Reply with Quote
I only use compressed air on my A/C and water systems. No need to add pink.
Posted - Nov 14 2020 :  09:44:19  Show Profile  Reply with Quote
More specifically I pull the hoses from the AC pump output and pop the inlet cap off to make sure it is dry.
Posted - Nov 14 2020 :  10:07:38  Show Profile  Reply with Quote
Dont your systems drain down when off except for the pump? That would also drain when on land.
Planeguy
RO# 1963
Posted - Nov 14 2020 :  14:47:11  Show Profile  Reply with Quote
I built a pump system so I can run barnacle buster thru my system when it is on the hard and then pump antifreeze thru it.
My tolerance for Islam ended on 9-11-01!
Homeport: Huron, Ohio Go to Top of Page
Posted - Nov 14 2020 :  14:50:19  Show Profile  Reply with Quote
My gut answer is no. You need to run the AC.
My current boat, I just close my seacock, open the strainer and start pouring AF when my wife turns on the AC Sytem. A couple gallons and I'm done. Takes me 2-3 minutes. Same procedure for my main engines and genset. Easy Peasy.
