[ Active Members: 2 | Guests: 137 ]  [ Total: 139 ]  [ Newest Member: colrhino ]
 Chaparral Owners
 Cockpit Heater
Author Previous Topic: 2000 Signature 300 Topic Next Topic: Plastic Bezels - wow!
Nibbs
RO# 24454
Posted - Feb 08 2007 :  10:20:13  Show Profile  Reply with Quote
Has anyone installed a cockpit heater in a Chap Sig? The Admiral is often cold when we return after dark, and I thought this might be a good solution (no wise cracks please). HeaterCraft has a version with what they call "hot tubes" which are flexible tubes that can be extended 6-8 feet, and can be used to vent under a blanket, or into a person's jacket (resulting in a Michelin Man affect).
What I can't figure out is where to insall one of these. My first thought was in the engine compartment, but they are not ingition protected, which could result in an un-desirable level of BTUs. I also don't know if the gunnels have enough width.
Your thoughts?
Homeport: The Muddy Midwest
jbacchi
RO# 18970
Posted - Feb 08 2007 :  10:59:35  Show Profile  Reply with Quote
We use a $60 stand up heater from walmart that works great with the isenglass up.
Homeport: Lake Conroe,Texas Go to Top of Page
Nibbs
RO# 24454
Posted - Feb 08 2007 :  11:06:42  Show Profile  Reply with Quote
Does that run off of your genset, or is it DC powered?
I don't have a gennie, so I need either a DC unit, or someting comming off of the engine coolant.
Edited by - Nibbs on Feb 08 2007 11:09:54
Homeport: The Muddy Midwest Go to Top of Page
MAXUM27
RO# 19938
Posted - Feb 08 2007 :  11:34:37  Show Profile  Reply with Quote
Nibs,
Try these guys their coolant heaters look good
http://www.espar.com/htm/applies/marine.htm
"A wise man makes his own decisions, an ignorant man follows public opinion"
Homeport: MA Go to Top of Page
jbacchi
RO# 18970
Posted - Feb 08 2007 :  12:09:32  Show Profile  Reply with Quote
I run it off the genset. Sorry I dont have a solution for you
Type-A
RO# 24241
Posted - Nov 06 2007 :  11:24:19  Show Profile  Reply with Quote
Granted I don't have a Sig 300 but I did install one on my Crownline 225ccr and Crownline 262cr. In the 262ccr, I installed it in a empty compartment down below (that way you will draw air out of the cuddy, plus it is warmer down there). I ran 1 vent in the cuddy and 2 in the cockpit - in the gunwhales.
I have tried a regular 110 volt ceramic heater but that just kills my 2 deep cycles quickly (especially if the engine if off).
Russ
Oshkosh, WI
2005 Cruisers Yachts 300 Express
Homeport: Oshkosh, WI Go to Top of Page
