Underwaterwelder
New member
- Jul 5, 2021
- 34541
- 27
Went to go to the local lake today and realized I had a flat. Boat lives on the trailer in our driveway. Swapped it for the spare and started inspecting the flat for the cause. Soaped up the tire and rim looking for punctures, and I found an air leak at the seam of the rim where the center rim portion connects to the portion that holds the air, the little red line on the photo, (stock photo… not my actual rim). A solid but slow leak.
Last trip out was Lake George NY, about 220 miles from my house. It was about two weeks ago. No issues on the drive home, didn’t hit anything, etc. We always do a walk around before leaving and at any stops, no noticeable issues. Checked air pressure on the ride up to the lake, but not on the way back. We chock our wheels every time we park the boat/trailer with 4x4 between the two axels. So we would have seen it if it was fully flat when we arrived home (if we hadn’t noticed it earlier). So my assumption is somewhere between pulling out of the lake and parking in the driveway was the failure, and then slowly leaking until flat now.
This is the second cracked rim we’ve had. Last one was summer of 2021. That time it was on the trip to Lake George from our house, and we noticed it at the marina after loading the boat to go home. Exact same issue. Failure at the same spot. Slow leak, flat after a weekend of being parked and not used. I believe it was the opposite side of the trailer that time. But again, nothing memorable as to why or how it happened. Just a crack/air leak in the rim at the same location
Any thoughts? Things I should look out for? Is there a better rim I should be buying? Both came straight from the trailer manufacturer. Do rims come in different capacities with the same bolt patterns? Just bad luck? Any help or insights would be appreciated.
2001 245 SeaRay Weekender
2017 LoadRite trailer dual torsion axels, surge disc brakes. (attached is the sticker on the trailer with all the info) Load Star Karrier Radial Tires (came from manufacturer)
2022 Chevy 2500 custom HD
Thanks!!
Thanks!!
