How to replace aft A/C in Sundancer
Bob7135
Hi- newcomer here...
I need to replace the aft A/C unit in my 96 370 Sundancer and it appears that the drawers need to come out to access the A/C. The problem is I do not see how to remove the drawer unit, there seems to be no screws or anything to remove. If anyone has done this before, I would appreciate any tips on replacing the unit.
TIA Bob
I had mine done this past spring.
Remove both draws.....there are 4 screws holding in the draw slide assembly...( you'll see them )....remove the screws. REMEMBER to remove the control unit ...and the wire ties that hold the wire....on the inside of the cabinet. Grab the draw slide assembly.....and pull evenly outward. It WILL slide out as one unit. You may need to spray a little WD-40 on the sides. Becareful not to chip the formica when the assembly slides out flush with the face of the cabinet.
There are also 2 access panels....you need to remove in the bottom/side of the closet.
Good Luck.....
