- Jan 1, 2000
- 775
- 1,222
On my 1999 SeaRay with a 190hp 4.3 and Alpha I drive. I am having a tough time deciding which propeller is right. I've been boating all my life and should know this, but sometimes it's good to hear it from someone else. I've got two propellers that put me at both ends of the WOT RPM range, with very little difference in performance.
14 x 23 Aluminum - RPM 4500, top spead 49mph
14.25 x 21 Aluminum - RPM 4900. top speed 47mph
WOT range for this engine is 4400 - 4800.
With the 21, hole shot is slightly better, but at WOT, rev limited will cut in. The 23 performs pretty well all around, but you can tell the difference pulling up a skier. We usually run the boat lightly loaded, just me and my daughter skiing. Another interesting thing, we boat year around in NC, during the winter when it is colder, the 23 will turn more at WOT, closer to 4600-4700rpm.
Also, from what I can see there is nothing in between these propeller sizes -- these are both Quicksilver propellers that uses the Flow Torqe hub.
There probably is not a right or wrong answer here, I'm more curious as to what others think.
